July 24-25 Camino Del Diablo Trip
Discussion in 'Arizona' started by 08pretaco, Apr 26, 2011.
  1. Apr 26, 2011 at 10:19 AM
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Postponed
    Camino Del Diablo,
    Starting point: I-8, exit 30 at Wellton
    Finishing point: Arizona 85, 2.2 miles south of Ajo
    Total Mileage: 114.1
    Driving Time: 2 days
    Remoteness rating: scale is 0 to 2, this is a +2...as remote as it gets
    This trail will require more than just a sack lunch...
    Rating for the trail 4: High-clearence required, 4WD's prefered. Expect a rough road surface with rocks larger than 6" but reasonable driving lines will be available. Sands will be deep and will require low tire pressures. Substantial sections of single-lane shelf road, moderate grades, and sections of moderately loose road surface.
    To obtain the range permits please either visit in person or by mail all any of the following locations:
    There is a 20 minute video that you need to watch in order to obtain the pass. Everyone that will be going on this trip will need to go get a pass, not just the people driving...passengers as well.
    Luke Air Force Base Gila Bend Auxilary Field
    Gila Bend, AZ 85337
    (928) 683-6220
    Range Management Department
    Box 99160
    Marine Corps Air Station
    Yuma, AZ 85369-9160
    (928) 341-3402
    Bureau of Land Management
    Yuma Field Office
    2555 E Gila Ridge Road
    Yuma, AZ 85365
    (928) 317-3200
    Phoenix Field Office
    21605 North 7th Avenue
    Phoenix, AZ 85027
    (623) 580-5500
    Cabeza Prieta National Wildlife Refuge
    1611 North 2nd Avenue
    Ajo, AZ 85321
    (520) 387-6483
    Map of trail
    Before the trip:
    Go over your vehicle: make sure battery is good, good hoses and belts, no leaks from anywhere, ball-joints/uniballs and suspension components are good.
    Items needed:
    Food and water
    Small shovel or multipurpose ax, pick, shovel, and/or sledgehammer
    Recovery straps/heavy duty yank straps/ratchet tie-downs
    2 spare tires with wheels (if your a boss and can pop the beads on/off then thats on you)
    Hi-lift/off-road jack with base plate for soft sand
    Emergency medical kit
    Spare key just in case
    Jumper leads
    Flashlight
    Portable Air compressor
    Gas, engine oil, other vehicle fluids
    Worth Considering
    Tool kit with some spare parts: you know what breaks on your truck, be prepared
    Tire repair kit: ARB makes a bad-ass one
    Fire extinguisher: 5lbs is basic minimum for actually putting a fire out
    Pop-up tents for shade during breaks
    List of people:
    Oliver (pass)- OBA, stand alone compressor, 60" Farmer Jack
    Scott
    David
    Josh
    Eric- Strap, shovel
    George (4runner)
    Carlos
    Brian (pass)
    Possibles:
    Garrett
    Brian
    Patrick
    Reads on the trail with photos
    http://www.markdstephens.com/el_camino_del_diablo/
    http://www.desertusa.com/mag02/may/diablo.html
    http://hikearizona.com/photoset.php?ID=7356&start=15
    http://hikearizona.com/photoset.php?ID=19482
    http://hikearizona.com/photoset.php?ID=13701
    http://www.4x4now.com/pp001.htm
    http://www.bajataco.com/caminodeldiablo06/index.htm
  2. Apr 26, 2011 at 10:22 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Maybe some truck trails off of the 260?
  3. Apr 26, 2011 at 10:31 AM
    08pretaco
    az
    Hmm I will have to look into that, thanks Matt.
    Unfortunately I am not to informed of trails such as this throughout the valley or nearby so I might have to do a good bit of research!
  4. Apr 26, 2011 at 2:26 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    im down. theres some high speed washes out in florence. or we can hit sycamore and stay in the 2wd areas like the wash and what not? but its not like a far ride or anything
  5. Apr 26, 2011 at 2:34 PM
    08pretaco
    az
    I want to be out all day!
  6. Apr 26, 2011 at 2:37 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Damnit...........
  7. Apr 26, 2011 at 4:43 PM
    97yota4wd
    Eric
    Mesa, AZ
    lol..
    yeah i want to be out all day... thats where 4wd comes in handy haha..
    ill be checking back often!
  8. Apr 26, 2011 at 5:22 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Prerunning trail would be closer to the sand dunes near Yuma. Lots of open space to reach those speeds.
    There is mexico as well.
    Ill be in depending on location of trail
  9. Apr 26, 2011 at 6:24 PM
    08pretaco
    az
    Hmm, David do you know of places to go in Yuma...I will take a look online to see what I can find!
  10. Apr 27, 2011 at 12:53 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    There are no 2 hour trails near Yuma, mostly because the surrounding desert is either military testing grounds or a nature reserve. But Cliff was thinking about a trail that might fit what your looking for.
    http://azt4wda.com/index.php?topic=200.0 :cool:
  11. Apr 27, 2011 at 12:54 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Im down :D
  12. Apr 27, 2011 at 12:58 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    You know I'm in!
  13. Apr 27, 2011 at 7:03 AM
    08pretaco
    az
    AN ERROR HAS OCCURRED!
    The topic or board you are looking for appears to be either missing or off limits to you.
    Guess I dont have access to view it
  14. Apr 27, 2011 at 10:04 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    are you logged on with your account for AZT4WDA?
  15. Apr 27, 2011 at 10:46 AM
    TidalWave
    TidalWave I have a shovel and no one will miss you...
    Mendy
    Surprise, AZ
    05 TRD DCLB
    4" Maxtrac Spindle lift, 33" BFG A/T, Avid weld on rock sliders and rear bumper, Smoked Projector Headlights, smoked tails and fogs, HID healights and fogs, flowmaster exhaust, Wet Okoles, debadged. Ready to take your milk money.
    Id be interested as long as we stay on this side of the border :)
  16. Apr 27, 2011 at 10:58 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    were a long ways from Canada so we should be fine :D
  17. Apr 27, 2011 at 5:51 PM
    ColtsTRD
    Scott
    AZ
  18. Apr 27, 2011 at 8:41 PM
    08pretaco
    az
    ya I am logged in...
  19. Apr 27, 2011 at 8:47 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    So.. I'm pretty much jealous.
  20. Apr 27, 2011 at 8:48 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    go into the off road events, and its the thread called "Camino del diablo"
