Jump start fail.
Discussion in '1st Gen. Tacomas (1995-2004)' started by oh no not again, Apr 27, 2013.
  1. Apr 27, 2013 at 10:37 AM
    oh no not again
    oh no not again [OP] Member
    Monterey, CA
    97 Tacoma Regular 2.4L
    Good morning (or afternoon for you east coasters)!
    My girl fiend killed her corrola's battery last night, and my manly moment of jump starting her car with my 97 taco ended with "i'll just call AAA in the morning."
    wtf? Bottom line, the jump was unsuccessful. I did it exactly as per the manual, and as I've always jumped other cars:
    start on dead battery (+), connect to good battery (+), then connect good battery (-) to a ground on dead car....
    so AAA pulls up this morning, and does the same EXCEPT they actually ended by connecting to the dead battery's (-) terminal- and not grounding- something i've been taught NOT to do.
    in the words of Tim the Toolman Taylor. "EEhhhhrrruhhh?"
    I let the cars sit, connected appropriately for a minute.... revved up taco just a tad.... and the corrola ignition resulted in CLIKCLIKCLIKCLIKCLIKCLIKCLICK (super rapid)..... waited another minute and retry. same deal.
  2. Apr 27, 2013 at 10:41 AM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    2016 Sierra Denali
    I've always went battery to battery. Not sure what you want help on though.
  3. Apr 27, 2013 at 10:45 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    connect it straight from terminals to terminals. no need to go to a ground on the vehicle, most likely why it did not work for you
  4. Apr 27, 2013 at 10:48 AM
    oh no not again
    Monterey, CA
    Rodger that. Method revised. Thanks!
  5. Apr 27, 2013 at 10:49 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    I do terminals to terminals to...A ground is only useful if you have a complete circuit...
  6. Apr 27, 2013 at 10:50 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5
    2007: Avid sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, blisten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scanguage, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload
    I always go battery to battery, never ground. It never works when I ground it, but works like a charm when I don't.
  7. Apr 27, 2013 at 10:51 AM
    offroadwonder
    offroadwonder Well-Known Member
    Jared
    Aurora, CO
    '10 Tacoma DCSB 4x4 TRD Off-Road
    Chopped mud-flaps (yup, I'm hardcore)
    I am confused... so did AAA get it started, or did they have no luck either. If they did then you probably just didn't have a good ground on the GF's car. There is no reason not to connect directly to the post on the battery. What you don't want is for a major spark to possibly ignite gases from the charging battery. That is why some people will suggest that you make the final connection away from the battery.
    I always connect both terminals on the dead car first (the risk there is the danger of letting the other ends of the jumper cable set touch. Just be very cautious to ensure the other ends are not near each other). Then I connect the (+) on the running car followed by the (-) on the running car.
    So yes, my method does produce a minor spark near a battery (on the running vehicle). But the risk is very small and it ensures you have a good ground connection.
  8. Apr 27, 2013 at 11:20 AM
    chich2000
    chich2000 Well-Known Member
    AK
    Tacoma 4WD TDR
    Sounds like the GF battery was completely dead, because of this it can take more than "just a minute" to charge. When this is the case, it may take longer to jump, I've had to wait up to 5 min on occasions. I always use another ground (not battery) to be safe, but it's personal preference.
  9. Apr 27, 2013 at 11:27 AM
    joes06tacoma
    Joe
    Central Coast, CA
    You probably had one or more connections with your jumper cables too loose.
    I normally go terminal to terminal as well, because I find it hard to get a good connection away from the battery. The idea with connecting the last cable away from the battery is to prevent a spark and explosion if the battery is emitting explosive gas. It's a small risk. I definitely would not want to make a spark next to a recently charging battery, but most of the time with a dead car, it's been sitting, and I feel safe.
    I have had the click, click, click response when jumping before, I just dug the jumper cable clamps in real hard on the terminals and it started right up. Both vehicles had lead cable clamps on them, and they both had dent in the terminals when we were done. Not pretty, but it worked. BTW, during this incident, a "Helpy Helperton" type appeared and told me I was doing it wrong connecting without the remote ground connection. LOL:)
  10. Apr 27, 2013 at 11:52 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    What grounding point did you use on the Corolla? Hope it wasn't the center shaft on the strut tower?
  11. Apr 27, 2013 at 12:00 PM
    EVE Designs
    EVE Designs GNAR Member
    Craig
    Valle Vista, Ca
    13 Offroad
    + on terminal and - on alternator has always worked for me perfectly.
  12. Apr 27, 2013 at 12:22 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid light bar, KC Daylighters
  13. May 4, 2013 at 11:23 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Positive to positive and negative to ground jumping is recommended for safety. It is to reduce the possibility of igniting any residual hydrogen produced by the battery during charging. One of the most common starting problems is high resistance caused by corrosion between the battery's terminals and the cable clamp. Corrosion can also occur on the ground cable connections to the frame or engine also causing electrical problems. A healthy battery, charging system (to keep the battery charged), cabling, and starter are codependent to start an engine.
