Jumpers LED's
Discussion in 'Jumper's LEDs' started by csjumper2003, Sep 11, 2011.
  1. Feb 18, 2015 at 6:40 AM
    #4101
    CCSO2542
    CCSO2542 Member
    Andrew
    Cullman, AL
    17 TRD Sport 4x4
  2. Feb 18, 2015 at 12:56 PM
    #4102
    csjumper2003
    csjumper2003 [OP] Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Pm sent
  3. Feb 19, 2015 at 11:06 AM
    #4103
    youngbuckcody
    youngbuckcody Well-Known Member
    Cody
    Mililani, HI
    12 Pryite Mica TRD Sport DC 4x4
  4. Feb 19, 2015 at 3:51 PM
    #4104
    YankNeckEddie
    YankNeckEddie New Member
    Eddie
    NC by way of NJ
    2014 Taco
    can you pm me a price on led headlights hi/lo and white/amber switchback for a 2014
  5. Feb 19, 2015 at 9:44 PM
    #4105
    csjumper2003
    Savannah, GA
    Pm sent
  6. Feb 19, 2015 at 9:45 PM
    #4106
    csjumper2003
    Savannah, GA
    Looking good.
  7. Feb 20, 2015 at 12:14 PM
    #4107
    silvertaco12
    silvertaco12 Member
    James
    Warwick, R.I.
    12 TRD Sport
  8. Feb 20, 2015 at 12:33 PM
    #4108
    csjumper2003
    Savannah, GA
    Pm replied
  9. Feb 20, 2015 at 7:00 PM
    #4109
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Do you have the light that goes inside the fog light switch on 2nd gen?
    T3 I think is what it's called.
    Base attached to the bulb is 8mm diameter. Stock bulb+base is 10mm tall. If it goes too tall the switch can't be pressed.
  10. Feb 20, 2015 at 11:20 PM
    #4110
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    I want to order how do i do so did i miss that??
  11. Feb 21, 2015 at 2:00 AM
    #4111
    csjumper2003
    Savannah, GA
    Yes I do. Send me a pm and I'll get you taken care of.
  12. Feb 21, 2015 at 2:01 AM
    #4112
    csjumper2003
    Savannah, GA
    Pm replied.
  13. Feb 21, 2015 at 11:53 PM
    #4113
    youngbuckcody
    Cody
    Mililani, HI
    Just daylight running are whites and switches to Amber blinker when you use your turn signal . It's awesome
  14. Feb 22, 2015 at 3:05 AM
    #4114
    2020tacoma
    2020tacoma Member
    shaunt
    palmdale
    2015 trd sport
    Purchased a 2015 trd sport couple days ago. Ive been Reseraching came across the superbrightled sight i was about to order map, dome, plate lights then i came across this tread. First message on any forum so im still learning how this all works. Can you please give me the pricing for pretty much a complete set for the entire car. dome+map 'including visor 30mm' if you have those. Daylight white/amber switchbacks, plates, fog, brake light, 3rdbrake, head lights. Every light that can be replaced to LED pretty much if im leaving anything out. 'Bright White' the brightest possibble.
  15. Feb 23, 2015 at 4:54 AM
    #4115
    MTyota86
    MTyota86 Well-Known Member
    Haverhill, MA
    09 TRD Off-Road
    Airaid Intake, Magnaflow Exhaust, Diff Breather, SOS Concept Sliders, OME 3" Lift, SOS Concept rear bumper, Plasti-Dip grill and Badges.
    PM sent. Hoping to pick up some LEDs for my car.
  16. Feb 23, 2015 at 8:29 AM
    #4116
    csjumper2003
    Savannah, GA
    Pm sent and replied
  17. Feb 23, 2015 at 11:43 AM
    #4117
    dh920trd
    dh920trd Well-Known Member
    david
    s.california
    pm sent...need some leds
    3rd brake
    main brake
    reverse
  18. Feb 23, 2015 at 11:49 AM
    #4118
    sberkley92
    sberkley92 Saturdays Are For Tacomas
    Bakersfield, CA
    '15 DCSB PreRunner TRD OR
    Bilstein 5100's, Deaver AAL, SCS SR-8's, 285 KO2’s, LED Interior Lights, Debadged, Hella Optilux Extreme Yellow fog light bulbs, Super 44 series flowmaster muffler, color matched grille surround..
    can i get a quote for the hi/lo's and white fogs
  19. Feb 23, 2015 at 1:11 PM
    #4119
    dh920trd
    david
    s.california
    pm sent
    thanks chris again now i will be all led out just need to do the switchback in the future
  20. Feb 24, 2015 at 4:27 PM
    #4120
    immski
    immski Well-Known Member
    Paul
    Omaha, NE
    SR5 4X4 4 Cyl
    Can I have a quote for
    - 3rd brake light
    - rear turn signals with resistors
    - license plate
    All as bright as they can go! Thanks. I bought from you before and am very happy.
