Jumpers LED's
Discussion in 'Jumper's LEDs' started by csjumper2003, Sep 11, 2011.
  1. Apr 6, 2019 at 6:54 PM
    #5821
    csjumper2003
    csjumper2003 [OP] Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Got you covered.
    But can’t send you a pm bc of your privacy settings. Pm me.
  2. Apr 22, 2019 at 4:37 PM
    #5822
    LS74
    LS74 Member
    2011 Silver Tacoma PreRunner TRD Sport crew cab long bed
    Do you have a tailgate light bar with reverse lights?
  3. Apr 25, 2019 at 9:16 AM
    #5823
    triad
    triad Member
    Houston, Tx
    11' TRD TX|Pro Speedway Blue
    Undercover, TRD Cold Air Intake, WeatherTech Mats
    Can I get a quote for...
    DTRL Amber
    DTRLs White/Amber kit
    LED High powered Headlights. Hi/Lo
    2011 Tacoma
  4. Apr 25, 2019 at 9:59 AM
    #5824
    csjumper2003
    Savannah, GA
    Sorry this is one thing I do not.
  5. Apr 25, 2019 at 9:59 AM
    #5825
    csjumper2003
    Savannah, GA
    Pm coming your way.
  6. Apr 28, 2019 at 9:18 AM
    #5826
    jhinderliter
    jhinderliter Well-Known Member
    West central il
    2009 Double Cab TRD Off Road
    I’d pass on the marker lamps , they fail after 7 months and start to flicker ..
    Also pass on the license plate lights , they never worked...
    The reverse lights fell apart after 7-8 months and rattled around in the lense Assy...
    The headlights and fogs work very well ...
  7. Apr 28, 2019 at 10:41 AM
    #5827
    csjumper2003
    Savannah, GA
    Not sure exactly what you mean by this statement but tried to help you out even with being out of warranty. The basic option are not meant to be in a small housing but offer them as a cheaper alternative to the others. When there is a warranty issue I ask for You to let me know. I’m sorry you had an issue and have changed the type that was causing a flicker issue. Basic LEDs can depending on the weather and environment flicker, but have since added 2 new options that do not. That’s why I was gonna help you out with an upgraded type pair in the pm I sent you.
  8. Apr 28, 2019 at 3:42 PM
    #5828
    jhinderliter
    West central il
    Not offense intended...
    That being said a flickering marker or license plate light could get a guy pulled over , I don’t like getting pulled over, if you know or knew certain lights were prone to fail or flicker then maybee don’t sell em..
    I was just giving feedback to the guy with the 08 based on my experiences ....
    I’m generally happy with the $450 I’ve spent with you and I appreciate the legwork and research you did for us all...
    And you’re right , I was out of warranty by 50 days ...
    If you have marker lights and license plates lights that don’t flicker I’ll take em..
    The threaded portion of the upgraded reverse lights rattle apart and that was honest feedback for you..
    I’d still like an under hood light set as well, I think that the only thing you offer that I don’t have on my truck yet ..
  9. Apr 28, 2019 at 3:51 PM
    #5829
    jhinderliter
    West central il
    And your headlights and fogs were a game changer on dark deer infested IL blacktops ...
  10. Apr 28, 2019 at 4:15 PM
    #5830
    csjumper2003
    Savannah, GA
    That’s wierd I sent that quote to your phone. After you sent me the pic of the bulb. Do you want me to send it to you in a pm as well?
    Sorry you had an issue with smaller housings heat can bulb up. And cause issue with solder. That’s why they can flicker. I keep them around as a low alternative but usually try and recommend the upgrade version for these applications. Let me know if you didn’t get the text. It was toward the end of March
  11. May 2, 2019 at 2:42 PM
    #5831
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Im in need of a dome light for a first gen and i'm also hoping you can provide a recommendation on some LEDs to light up my bed. I have a shell on and would like the bed to light up when I open the back glass.
  12. May 2, 2019 at 4:37 PM
    #5832
    csjumper2003
    Savannah, GA
    I have both of these.
    Pm incoming
    BeLance89[QUOTED] likes this.
  13. May 3, 2019 at 5:29 PM
    #5833
    MI-FLoffroader
    MI-FLoffroader Brett
    Brett
    Merritt Island, FL
    12' T4R LE/2003 SR5 SPORT V8/1988 DLX 22RE AUTO
    2012 T4R LE -Shoreline Blue Pearl 2003 T4R SR5 Sport V8 -Stratosphere Mica
  14. May 3, 2019 at 6:35 PM
    #5834
    csjumper2003
    Savannah, GA
    Got you covered
  15. May 9, 2019 at 6:52 PM
    #5835
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Quote for 2011 LED license plate lights. Please and Thank you!
  16. May 9, 2019 at 7:47 PM
    #5836
    csjumper2003
    Savannah, GA
    Sounds good.
  17. May 10, 2019 at 10:14 AM
    #5837
    gregc70
    gregc70 Member
    Greg
    09 Tacoma Crew TRD
    Do you have a webpage with all your items on it?
    Brutus likes this.
  18. May 10, 2019 at 10:25 AM
    #5838
    csjumper2003
    Savannah, GA
    The first post on my page has everything I offer but the website was taken down due to changing to a diff format.
    Click on the link in my signature and it will bring you there. Also if you ha e any questions feel free to pm me and I’ll get back to as quickly as possible.
  19. May 12, 2019 at 4:49 AM
    #5839
    MI-FLoffroader
    Brett
    Merritt Island, FL
    Received and installed yesterday. Thank You jumper.
  20. May 16, 2019 at 8:45 AM
    #5840
    jhinderliter
    West central il
    Found it .. I’ll txt back ..
    Thanks
