Jumpers LED's
Discussion in 'Jumper's LEDs' started by csjumper2003, Sep 11, 2011.
  1. Dec 22, 2020 at 5:33 PM
    #6001
    JALLENC
    JALLENC Active Member
    I wanted to get a quote on some leds when you get some free time to shoot me a pm
  2. Dec 22, 2020 at 7:32 PM
    #6002
    csjumper2003
    csjumper2003 [OP] Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    got you covered.
  3. Dec 31, 2020 at 2:53 PM
    #6003
    OC 714Taco
    OC 714Taco Well-Known Member
    Richard
    SoCal CA
    14 DCSB TRD OR
    QUOTE for:
    1. Under hood lighting. Is this kit plug and play?
    2. Reverse lights 700 lumen floods
    3. Led headlights Hi/Low
  4. Dec 31, 2020 at 3:19 PM
    #6004
    csjumper2003
    Savannah, GA
    No problem. Pm incoming
  5. Feb 2, 2021 at 2:04 PM
    #6005
    jarebear74
    jarebear74 Bar down or it doesn’t count
    Colorado Springs, CO
    2010 OR DCSB
    Just wanted to write a little kudos. Got the switchback LEDs back in 2017 and they're still holding strong. Not faulting at all. Absolutely incredible stuff. If ya need LEDs that you know will last, won't cause a fire, or look awful. Jumper's are the way to go!
    scottalot and csjumper2003[OP] like this.
  6. Feb 9, 2021 at 9:56 PM
    #6006
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Hey man I’m currently looking for the fuse/relay to prevent hyperflash. I had gotten some free tail light turn signal bulbs on Amazon in exchange for a good review. They were great but I took them off because of hyperflash. Can you steer me in the right direction? I have a 2008 without DRL
    PM incoming for Amber side parking lights too :thumbsup:
  7. Feb 9, 2021 at 10:11 PM
    #6007
    csjumper2003
    Savannah, GA
    I carry resisters for that but your 2008 being a non dtrl truck there is a led flasher made for those trucks.
  8. Feb 9, 2021 at 10:19 PM
    #6008
    ALI3N_123
    Eric
    Austin, Texas
  9. Feb 10, 2021 at 7:57 AM
    #6009
    csjumper2003
    Savannah, GA
    The short answer is no. If you use the dtrl flasher relay to get the oem dtrls, there isn’t an led flasher made. There is a way to modify the flasher to change the shunt loop inside of it but that requires soldering a new one on the board.
    ALI3N_123 likes this.
  10. Feb 10, 2021 at 3:53 PM
    #6010
    ALI3N_123
    Eric
    Austin, Texas
    Hmmm. Do front LED amber bulbs with built in resistors exist?
  11. Feb 10, 2021 at 7:45 PM
    #6011
    csjumper2003
    Savannah, GA
    Not reliably
  12. Feb 11, 2021 at 11:11 PM
    #6012
    horchata
    horchata Member
    Davis
    2013 Taco TRD Sport
    Hey there, looking to purchase a set of DTRL Amber LED lights to replace my factory bulbs for my 2013 DCLB. Would also like to include an interior kit in white. Can you please shoot me a quote with lead time :) ?
  13. Feb 12, 2021 at 7:11 AM
    #6013
    csjumper2003
    Savannah, GA
  14. Feb 23, 2021 at 10:04 PM
    #6014
    ALI3N_123
    Eric
    Austin, Texas
    Installed the $20 side marker LED bulb with protective cover. They glow nicely and are pretty bright. Appreciate it @csjumper2003!
    csjumper2003[OP] likes this.
  15. Feb 28, 2021 at 9:34 AM
    #6015
    antsinyourpants
    antsinyourpants 562amocat
    So Cal
    04 PreRunner & 2015 TRD Sport
    Upgraded LEDS, Stereo, rims and tires
    Quick question, looks like this thread started 10 years ago. Has anything changed since then?
    Also, I'm interested in the following:
    Amber- white switch backs
    Interior white
    Hood kit
    Shifter
    Any accessories needed
  16. Feb 28, 2021 at 10:25 AM
    #6016
    csjumper2003
    Savannah, GA
    things are always changing. The options are the same as far as application but leds get better and better. When I can change something for the better I do.
    Pm incoming
  17. Mar 10, 2021 at 11:06 AM
    #6017
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    Hello Chris. Sent you a private message regarding the lights I bought. Just had a question. Thank u
  18. Mar 13, 2021 at 5:30 PM
    #6018
    SeaLegs257
    SeaLegs257 New Member
    Jaocb
    2016 T4R Trail Edition
    Do glovebox organizers and floor mats count?
    Hey, Chris. Looking to get a kit to upgrade all of the interior LEDs on my 2016 T4R Trail Edition. Looking at the post from @Jester243 over on 4runners.com was what did it for me. I'd like to get them all in white.
    I look forward to hearing back from ya
    -Jake
    2016 T4R Trail
    Current Modifications:
    More to follow...
    Currently in West Central PA
    Formerly of South Florida
    Formerly of the Land of Sand
    Formerly of South Texas
    Formerly of Virginia
    Originally of Louisville, KY
    Jester243 likes this.
  19. Mar 13, 2021 at 5:32 PM
    #6019
    csjumper2003
    Savannah, GA
    Pm incoming
  20. Mar 16, 2021 at 1:50 PM
    #6020
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Hello! Interested in the amber interior kit + reverse 700 lumen for a 2002 3.4 V6. Thanks!
    Add rear brakes if available.
