Jumpers LED's
Discussion in 'Jumper's LEDs' started by csjumper2003, Sep 11, 2011.
  1. Dec 24, 2012 at 5:32 PM
    #1381
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Negative....I think painting would defeat the purpose of adding LEDs on there
    It would be alot better just to stay with the stock bulb if you want that orange look to it :thumbsup:
  2. Dec 24, 2012 at 5:45 PM
    #1382
    csjumper2003
    csjumper2003 [OP] Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Are you talking about having just amber dtrls no white?
  3. Dec 24, 2012 at 5:49 PM
    #1383
    wacked
    wacked Well-Known Member
    Katy, Tx
    2013 Tacoma Prerunner
    Thanks, I thought I saw somewhere that you could do something to get that "look" from the reflector inside.
  4. Dec 24, 2012 at 6:04 PM
    #1384
    Jerez
    Rod
    Ontario Ranch
    Estock
    Ya that would look nice tho!!
  5. Dec 24, 2012 at 6:52 PM
    #1385
    wacked
    Katy, Tx
    Kinda, I know I may be a little weird but I like the orange reflection in the bowl but not the big orange bulb.
  6. Dec 24, 2012 at 6:55 PM
    #1386
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Cost for license plate lights as well as interior map lights for 2nd gen?
  7. Dec 24, 2012 at 7:50 PM
    #1387
    wacked
    Katy, Tx
    When the light itself is off and not in DRL mode, if that makes sense.
  8. Dec 25, 2012 at 3:00 PM
    #1388
    Buff
    Buff Well-Known Member
    Buff
    NEPA
    V6 TRD Sport 4x4
    Removed the damn stickers!
    Has anyone done the DTRL switchbacks, white/orange, and had the mod to use the outer parking lights as turn signals also? If so, did it work? Did you have LED or incandescent parking light bulbs?
    Reason I'm asking is I installed my DTRL from Chris and also did the turn signal /parking light mod and the DTRL lights would blink on and off randomly for no apparent reason. Thought I had some bad connections or shorts. Then I decided to disconnect the outer parking light incandescent bulbs. DTRL became stable and worked fine through all modes. I could have sworn I saw someone with this setup and it worked. They may have had LED parking lights but I don't know.
    So I'm thinking my choices are to replace the parking lights with LED or get rid of that mod. Any thoughts?
  9. Dec 25, 2012 at 3:27 PM
    #1389
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    never seen it but the incadescent bulb may be messing with the resistance. I would personally try LED parking lights.
  10. Dec 25, 2012 at 3:41 PM
    #1390
    csjumper2003
    Savannah, GA
    X2
    I havent done the mod but if there is an incandescent in the mix it can always change the way things are powered and could cause the others in the series ti act wierd.
  11. Dec 25, 2012 at 4:26 PM
    #1391
    Mudphish
    Mudphish Member
    Andre
    Martha's Vineyard
    13 TRD OR Tacoma
    Hello Merry Christmas I have a quick question for you, is there any other mods that need to be done in order to swap over to LED's ? I am thinking about a blue dome, common third brake and license plate LED's.
    I have a 2013 TRD Tacoma.
    Thanks, Andre.
  12. Dec 25, 2012 at 4:29 PM
    #1392
    Jerez
    Rod
    Ontario Ranch
    Estock
    My parking lights run as turn signals at night....I used led lights on my truck now.
  13. Dec 25, 2012 at 5:13 PM
    #1393
    WrathRacing
    WrathRacing Member
    Marco
    Fontana Cali
    06 Tacoma
    i need some of these lights on my truck...messaged u siR
  14. Dec 25, 2012 at 6:07 PM
    #1394
    csjumper2003
    Savannah, GA
    Dtrls need some modding for the white/ambers , but the ones yu have stated do not.
  15. Dec 25, 2012 at 6:07 PM
    #1395
    csjumper2003
    Savannah, GA
    pm replied
  16. Dec 25, 2012 at 6:12 PM
    #1396
    Buff
    Buff
    NEPA
    V6 TRD Sport 4x4
    Guess I'll have to try the amber LED parking lights. And if I do that I might as well do the rear turn signals in amber too.:)
  17. Dec 25, 2012 at 6:22 PM
    #1397
    csjumper2003
    Savannah, GA
    I agree :bananadance:
  18. Dec 25, 2012 at 7:24 PM
    #1398
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    How much would brake lights+reverse lights be?
  19. Dec 25, 2012 at 7:51 PM
    #1399
    csjumper2003
    Savannah, GA
    Pm sent
  20. Dec 25, 2012 at 11:04 PM
    #1400
    87twentytwor
    87twentytwor Well-Known Member
    Jake
    Hawaii
    Sport
    none
    are the map light LEDs and license plate LEDs the same size?
