Jumpers LED's
Discussion in 'Jumper's LEDs' started by csjumper2003, Sep 11, 2011.
  1. Feb 7, 2013 at 7:32 PM
    #1621
    comiesutra
    comiesutra Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
    TEASE. Youtube is still processing the video.
  2. Feb 7, 2013 at 7:58 PM
    #1622
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Its done now!
  3. Feb 7, 2013 at 8:01 PM
    #1623
    comiesutra
    Greenwood, IN
    Looks great. How hard was it to do the DTRL?
  4. Feb 7, 2013 at 8:10 PM
    #1624
    csjumper2003
    csjumper2003 [OP] Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    A 2010 is a little different than a 2012, but i have instructions for both
  5. Feb 7, 2013 at 8:12 PM
    #1625
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Wasn't too hard for myself but I have some electrical background. For the complete novice it may seem a bit overwhelming but trust me...if you can read and follow pictures you will be just fine. Instructions were pretty straight forward and easy to follow. Only item not listed as a needed item are screws you will need to mount the resistors. I used some #6 1/2 inch long sheetmetal screws and mounted them near where the instructions picture them.
  6. Feb 7, 2013 at 10:38 PM
    #1626
    comiesutra
    Greenwood, IN
    That doesn't sound to bad.
    What are the steps needed for the resistors so that the Taco doesn't think that the bulbs are burnt out? I would like to avoid cutting up wires if possible.
  7. Feb 8, 2013 at 8:57 AM
    #1627
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    It's those little clamps that cut into the existing wires.
  8. Feb 8, 2013 at 9:14 AM
    #1628
    csjumper2003
    Savannah, GA
    You get ttaps that snap on the 2 wires and the resisters plug right in
  9. Feb 8, 2013 at 9:18 AM
    #1629
    comiesutra
    Greenwood, IN
    If that's all it takes then I'll be ordering some and a few others LEDs next paycheck.
  10. Feb 8, 2013 at 9:18 PM
    #1630
    MEMO CAMPOS
    MEMO CAMPOS Well-Known Member
    Westminster, Ca.
    05 PRERUNNER
    TC Upper Arms, ICON coilovers, Camburg spindles, AP standard leaf packs, ICON Resi.'s, AFE intake, Magnaflow Magnapack, Defiant Light Bar with PIAA 580's, 6K HID's top and bottom
    Hey chris is there different wattage or brightness levels for the reverse led's? Also are they plug and play?
  11. Feb 8, 2013 at 9:50 PM
    #1631
    csjumper2003
    Savannah, GA
    Pm sent. And yes they are plug n play.
    I carry 400 and 800 lumen ones
  12. Feb 8, 2013 at 10:57 PM
    #1632
    MEMO CAMPOS
    Westminster, Ca.
    05 PRERUNNER
    Any pics on both? Sorry had to ask...
  13. Feb 8, 2013 at 11:08 PM
    #1633
    csjumper2003
    Savannah, GA
    There are some in the thread somewhere from people but let me see if i can get some taken tomorrow night.
  14. Feb 8, 2013 at 11:10 PM
    #1634
    MEMO CAMPOS
    Westminster, Ca.
    05 PRERUNNER
    I'll try to beat you to it! Thanks! I'll quote it if I find it!
  15. Feb 8, 2013 at 11:17 PM
    #1635
    csjumper2003
    Savannah, GA
    Here is a camera phone pic of a comparison between the 886 mod, and my 800 lumen reverse. Cant see the coverage but if you know all the people that have gone to the 886 to get brighter lights these beat the 886s
  16. Feb 8, 2013 at 11:19 PM
    #1636
    csjumper2003
    Savannah, GA
    here's the post that I snatched it from.
  17. Feb 9, 2013 at 7:35 AM
    #1637
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    800 lumen left, 886 right. Both are bright.
  18. Feb 9, 2013 at 7:48 AM
    #1638
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    Do you by chance have one from behind the dash at night so we can see the light fall on the road...one that actually shows the difference of how much road is lit up between the two bulbs.
  19. Feb 9, 2013 at 7:53 AM
    #1639
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    I dont have that pic. There is a little dark spot just behind the bumber (in the camera) with the 800 (projector). Other than that, they both reach out about the same. The main differance is that the LED is not going to melt anything. I added some aux. reverse lights to take care of window tint issues. Its like a clear sunny day behind my truck now!
  20. Feb 9, 2013 at 3:46 PM
    #1640
    Ntenna
    Ntenna Member
    Suffolk, VA
    09 Sport 4x4 DCSB
    MBRP duals, TRD CAI, LEDs, Sony DVD w/Sound Ordinance
    Want the white/amber DTRL and third brake light LEDs for sure. I'm in VA. How do we do a deal?
    Thanks much. Jh
