Jumpy Speedometer
Discussion in '1st Gen. Tacomas (1995-2004)' started by jcemitte, Jan 28, 2011.
  1. Jan 28, 2011 at 3:10 PM
    jcemitte
    jcemitte [OP] Livin' the taco life
    Jake
    Tulare CA
    04 Taco SR5 5 lugger
    Deck Plate mod, Knock Off Flowmaster,billet grill, alpine HU w/kicker amp and pheonix gold 12" sub stock componets
    hey guys, my buddy has a 96 and he says when he starts his truck the speedo jumps up to the 40mph mark and bounces up and down making a chirping noise and rattling....is there a gear he can get or is it possible/worth it to update the gauge cluster? what do you guys think
  2. Jan 28, 2011 at 7:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The '96s actually have a speedo cable, unlike later models. Your friend could try lubing his cable, they make a graphite lube for this purpose. Or just replace the speedo cable altogether. There is a gear that drives the cable but its unlikely that is the problem or the cluster itself.
  3. Feb 3, 2011 at 9:13 AM
    jcemitte
    Jake
    Tulare CA
    he said he'll give it a try and let me know, thanks for the advice
  4. Feb 3, 2011 at 9:37 AM
    northside
    northside Member
    canadian rockies
    96 XtraCab V6 4x4
    307,xxx miles
    2 days ago I was driving to go snowboarding and as soon as I got on the highway and gassed it my dash started screaming like a banshee for about 30 long seconds and the speedo needle was jumpy. This was about 80-90 kph and about -15C so the cold might have had something to do with it...
    It went away and didn't come back. I'm guessing a speedo cable lube issue.
