June Citrus meet
Discussion in 'Florida' started by 4banger4x4, May 15, 2014.
  1. May 21, 2014 at 6:06 PM
    #181
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Pretty sure that's the hole that Eric and I went through back in January. Deep as hell but wasn't a problem. :cool: Of course, over a couple months, everything changes. Ruts fill back in or get dug out deeper. Holes you got stuck in on a previous trip you drive through in 2WD like it was nothing. Holes you didn't have a problem with last time now swallow your truck whole. Never really the same experience twice. ;)
  2. May 21, 2014 at 6:18 PM
    #182
    4banger4x4
    4banger4x4 [OP] Probably should'nt have done that.
    Eric
    Whorelando, Fl
    that looks like the one me and you both hit, and the one in the back is the one only i hit :]
    Ill be staying out of them this time though. i wanna try and avoid mud...
  3. May 21, 2014 at 6:34 PM
    #183
    Taco No Baka
    Lee
    Tampa, FL
    Negative. I went through that one too. I just came through from the other direction you went through.
  4. May 21, 2014 at 6:52 PM
    #184
    Tacomanimal
    Tacomanimal Well-Known Member
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    If you are attending and don't see your name below, please add your name.:)
    1. 4banger4x4 (Eric) +1 Jeep JK
    2. Tacomanimal (Fredo)
    3. A Nori (Adam)
    4. Michaelrussell (<- self explanatory)
    5. GuyHuey (<- also self explanatory )
    6. gearheadesw
    7. blackhorse (Rick)
    8. Taco No Baka (Lee)
    9. Austin07 (duh)
    10. SheepdogGadget
    11. hookemhorns47
    Maybe dirtymike (aka mr.37's)
    Maybe xweslingx
  5. May 21, 2014 at 6:56 PM
    #185
    Taco No Baka
    Lee
    Tampa, FL
    Only because that one the jeep is stuck in was so deep. I had water come up on the hood when I dropped off in it. Otherwise, it was kind of an anti-climax.
  6. May 21, 2014 at 7:00 PM
    #186
    4banger4x4
    Eric
    Whorelando, Fl
    Yeah that one made me mash the ohshit pedal a little harder.
  7. May 21, 2014 at 7:45 PM
    #187
    hookemhorns47
    hookemhorns47 Well-Known Member
    Chas
    Tampa, FL
    06 Prerunner
    Front 5100's, debadged, derped bumper, colormatched satoshi, cbi ditch brackets + leds, 4' firestik, 12" JL in a big ass box
    Yea I have a video of it too, everything was goin good till he got stuck and then the engine cut off....
  8. May 21, 2014 at 7:55 PM
    #188
    4banger4x4
    Eric
    Whorelando, Fl
    Thats never good. Was that the only vehicle out there?
  9. May 21, 2014 at 7:58 PM
    #189
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    :spy: Gotta check my schedule
  10. May 21, 2014 at 8:15 PM
    #190
    4banger4x4
    Eric
    Whorelando, Fl
    your schedule is already booked. your going to citrus on the 7th
  11. May 21, 2014 at 8:40 PM
    #191
    hookemhorns47
    Chas
    Tampa, FL
    06 Prerunner
    Nah the red xj was the one that pulled him out actually
  12. May 23, 2014 at 7:25 AM
    #192
    Tacomanimal
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    Cb radio , antenna, etc arrived! Now I have to make a mount to the bed rail with my very limited steel working tools :homer:
  13. May 23, 2014 at 7:40 AM
    #193
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    If you have a torch grinder and drill you can make a fairly simple bracket
  14. May 23, 2014 at 7:51 AM
    #194
    Tacomanimal
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    :laughing: I have a small dremel and a drill with wood bits. :itllbuffout:
  15. May 23, 2014 at 8:04 AM
    #195
    michaelrussell
    Michael
    belleview,FL
    Actually if you get a piece of angle you won't need a torch
  16. May 23, 2014 at 8:18 AM
    #196
    Tacomanimal
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    I'm definately going to be able to cut it but it'll be slow going. I guess i'll have to buy the correct drill bit. :proposetoast:
  17. May 23, 2014 at 10:37 AM
    #197
    Austin07
    Austin07 Well-Known Member
    Austin
    Lake County Florida
    Stock 2011 Tacoma 4x4 TRD off road
    Haha!
  18. May 23, 2014 at 1:35 PM
    #198
    dirtymike
    dirtymike Well-Known Member
    mike
    orlando fl
    2nd gen
    Fiberglass,spindles, coils, 4"leafs, gears&locker, no skids :-/
    Yeah I wonr be able to attend on this one guys my cousin has his 16th birthday on the 7 and they will be doing it in new smyrna I won't be able to swing all of that driving
  19. May 23, 2014 at 4:36 PM
    #199
    Tacomanimal
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    Affirmative.
    If you are attending and don't see your name below, please add your name.[​IMG]
    3. A Nori (Adam)
    6. gearheadesw
    9. Austin07 (duh)
    10. SheepdogGadget
    11. hookemhorns47
    Maybe xweslingx
  20. May 24, 2014 at 2:39 AM
    #200
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Guys we can't make this event, have other plans that weekend. If things change then maybe. Would have been nice to have plans to attend as it would force me to build on the truck a bit more. Have parts waiting just no time.
    Have fun.
    PK
