June Citrus meet
Discussion in 'Florida' started by 4banger4x4, May 15, 2014.
  1. Jun 9, 2014 at 12:02 AM
    #461
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
  2. Jun 9, 2014 at 11:08 AM
    #462
    Tacomanimal
    Tacomanimal Well-Known Member
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    Thanks for recording videos Rick.:proposetoast:
    Finally opened the hood today & was surprised this much mud made it up in there. Anyone else got muddy engines?
    [​IMG][​IMG]
  3. Jun 9, 2014 at 11:52 AM
    #463
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I did & in the same area. Took about 4 hrs to clean my truck.
  4. Jun 9, 2014 at 11:56 AM
    #464
    Tacomanimal
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    4 hours?! :facepalm:
    As clean as your truck looks, you must've used a toothbrush and a toothpick! I'm thinking soak and rinse and repeat with spray on cleanser.?
  5. Jun 9, 2014 at 12:19 PM
    #465
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I didn't go that far but I did wash it & hit all the scratches with scratch x.
    It took forever to do underneath, all the nooks & crannies. I thought the mud would never stop coming out. haha
    You should've seem me rolling around on my creeper with the pressure washer.
    And now it's raining on it damn it.
  6. Jun 9, 2014 at 12:26 PM
    #466
    Taco No Baka
    Lee
    Tampa, FL
    It took me about 2 hours to clean the outside of the Odd Green Taco. Still have to vacuum all the dirt out of the inside though. My engine bay didn't have anything like what you guys had. Just a light spray.
    I've reached a conclusion after that trip though. I've been pushing the old girl trying to find her limits and I think I did on that trip, not just because of the busted CVs, but from some other damage as well, like the left rear fender the tire self-clearanced and I took a pretty hard hit on the fwd skid that buckled the mounting point it bolts to in front which I think is the core support, although I'm not entirely sure about that. I've getting more confident and less cautious with her but, after this trip, I think I need to back it down a notch or five. :eek:
    Doesn't mean I'm not going to wheel hard, just that I'm going to easy up on putting her in insane situations and then continuing to hammer on her once she's wounded. :p
    I'm going to adopt a more Colson-type approach, as opposed to the Eric-type I've been working on. :D
  7. Jun 9, 2014 at 12:27 PM
    #467
    Tacomanimal
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    :laugh:
    I also use Scratch X. How did that scratch on the fender turn out Mike?
    I polished and washed before i went out with ya'll. The pressure washer took care of the painted surfaces like new, everything else looks like crap.
  8. Jun 9, 2014 at 12:35 PM
    #468
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    It's still there, scratch X didn't help but that's the worst of it. Almost all the little pin stripes came out.
  9. Jun 9, 2014 at 12:38 PM
    #469
    Tacomanimal
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    You were a green monster out there! Imma call your truck The Hulk![​IMG]
  10. Jun 9, 2014 at 1:03 PM
    #470
    TacoHell
    TacoHell Well-Known Member
    Colson
    Central FL (Orlando)
    98 Tacoma 2.7L
    Headers, K&N intake, Lifted, 4.56 gears via ECGS. Locked in front, LSD in the rear
    Ha ha when it's not my DD I'll push the limits a little bit more. Until then I'll be taking it easy for the most part and enjoying the ride.
  11. Jun 9, 2014 at 1:05 PM
    #471
    Taco No Baka
    Lee
    Tampa, FL
    Haha. :D
    To be honest, you guys who haven't wheeled with me before really didn't get to see the Odd Green Taco at her best. I broke that CV practically right out of the gate and she was definitely having a lot tougher time negotiating obstacles than is normal...which just made me hammer on her all the more to make her perform. :eek: A lot of that stuff, particularly in that Trail 14 washout area where we had lunch and I broke the second CV, she usually makes that look easy where as she was struggling with it due to a lame front-end. The sand hills...well, she usually struggles with those regardless. The Swampers don't care for sand much. As soon as they start spinning, they go right to China and the Odd Green Taco doesn't have enough motor to spin them hard enough to stay on top of the sand.
  12. Jun 9, 2014 at 1:21 PM
    #472
    Tacomanimal
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    Oh, I thought it was 4 hours just for the engine compartment.
    Same boat here with payments.
  13. Jun 9, 2014 at 1:46 PM
    #473
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Haha, no total time. If I took that long on the engine then I think I'd need professional help. Haha
    The engine compartment was 10 mins at the most. The pressure washer made quick work of that.
  14. Jun 9, 2014 at 2:54 PM
    #474
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    Are u guys covering anything up? Alternator? Battery?
  15. Jun 9, 2014 at 3:17 PM
    #475
    Tacomanimal
    Fredo
    Tampa, Florida
    '22 SR 4x4 DCSB
    Since my battery is now crusted, i'll be removing that and covering the alternator.
  16. Jun 9, 2014 at 3:23 PM
    #476
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    well, im now getting put onto a different crew since im getting close to the point in finally being done with my training, gonna be working Mon-Fri from 8-4...booya, I'll actually be able to attend some of the meets possibly now haha
  17. Jun 9, 2014 at 3:40 PM
    #477
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I didnt cover anything, never have. I just didnt spray directly on the alternator or battery. I would think most things are water resistant, water gets up there when driving in the rain.
  18. Jun 9, 2014 at 3:41 PM
    #478
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Nice! Normal hours, congrats.
  19. Jun 9, 2014 at 3:45 PM
    #479
    Taco No Baka
    Lee
    Tampa, FL
    Haha, I spray all that crap. Like you said, it gets plenty wet anyway when driving in the rain or fording deep water.
  20. Jun 9, 2014 at 3:48 PM
    #480
    Alfuh
    2006 Prerunner
    I have a few mods
    thanks! unfortunetly when I get rated, I go back to then 4 on 2 off schedule lol...but I'll be able to take leave without having to deal with anymore training
