Jungle Fender Flares
Discussion in '1st Gen. Tacomas (1995-2004)' started by Moneray, Apr 15, 2008.
  1. Apr 15, 2008 at 9:44 AM
    Moneray
    Moneray [OP] Member
    Has anyone bought Jungle fender flares for your truck? I have a 99 tacoma and the price seems really good for these fender flares but I am worried about quality and looks. If you have or know anyone that has these can you let me know what you think about these.
    Thanks,
  2. Apr 15, 2008 at 10:10 AM
    RoadKill
    RoadKill Northern Alliance: padawan
    North of the border
    First gen 4x4
    285x70x17 offset rims+ 1.5 spacers, rear Timbrens + 3 inch lift add a leaf, Sway-a-way coilovers + camburg control arms, Fender flares (2.5 inch), clear lights, headers, sliders, roll bar
    I did buy a set, unfortunately I haven't had time to install them yet but i'm satisfied so far. It's sturdy and good quality. These guys ship very fast also
    can't wait to put them on...
  3. Apr 20, 2008 at 7:16 AM
    RoadKill
    North of the border
    First gen 4x4
    Got the flares on yesterday, i like em, easy install also
  4. Apr 20, 2008 at 9:25 AM
    99redtaco27
    99redtaco27 Member
    Lake Winni NH
    1999 sr5 ext 4wd
    workin on it -
    WOW flares look great, I have a 99 also - gonna send it as I can put my whole hand into a hole in the frame, DAMN right I will buy another toyota - too bad tho I just put the bilstein shocks on and was easily able to fit 33" skins only rubs a tiny bit when full turning, just went wheelin today will post videos on myspace, have a link in a few
  5. Apr 20, 2008 at 5:35 PM
    Moneray
    Moneray [OP] Member
    With all these trucks going in everyone should strip out your performance equipment, tires, etc. and sell them before Toyota dealers get their hands on them. If you have the original equipment and put it back on before Toyota takes it back they would not know or expect anything different. I checked my truck and it did not appear to have the holes. It did come from Boston so I thought for sure it would have had the problem. If any of you guys want to sell some used parts before the truck goes back let me know. Thanks guys I think I will try those Jungle flares, they look nice.
    Take care.
  6. Apr 21, 2008 at 7:52 AM
    RoadKill
    North of the border
    First gen 4x4
    Exactly what I have done, kept all my mods and transfered them to an other tacoma, this one has the V6 :D and no rust at all! Toyota will still waranty frame until 2013. Check out Blake's web site for jungle flares http://www.JungleFenderFlares.com nice gentlemen, very helpfull input also
  7. May 26, 2008 at 9:27 PM
    bladez
    bladez Well-Known Member
    That is an awesome looking Taco. You should get newer pics since you did so much more work. It looks way better now with your new wheels and tires! The Tacoma fender flares are the coolest model Jungle Fender Flares makes. Thanks for the link, I am glad you are enjoying the flares!
  8. Jul 21, 2009 at 5:59 AM
    bladez
    Would you mind if I post the newer pics of your Tacoma that you gave me on here?
  9. Jul 21, 2009 at 6:10 AM
    RoadKill
    North of the border
    First gen 4x4
    Not at all, feel free to use them
  10. Jul 21, 2009 at 6:36 AM
    bladez
    Great, thanks!
    Well than Jungle Fender Flares is proud to present RoadKill's killer completed Tacoma!
    Check out his truck since he got all the other accessories, awesome Mammoth wheels and 33" Maxxis Bighorn Tires installed! You'll hardly recognize the old little Tacoma at the heart of this beast!
    You can see more info about his build in the gallery here; http://www.junglefenderflares.com/gallery.htm
  11. Dec 20, 2009 at 5:02 AM
    bladez
    Any updates on the Tacoma?
  12. Dec 20, 2009 at 5:41 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Too shiny...you gotta bedline them!
  13. Jan 11, 2010 at 10:53 PM
    bladez
    Actually the new version of these Tacoma fender flares are not shiney. They are the same size and style but they are now heavy duty made from fiberglass. See more information about these new Tacoma Fender Flares here.
  14. Jan 15, 2010 at 7:30 AM
    kato
    kato Well-Known Member
    Kelowna
    tacoma SR5
    Mine came in the other day. They are flat black and made out of fibreglass. I am a little sceptical about the mounting. It is held to the truck by the mounting plates in the wheel well. This leaves the top edge capable of pulling away from the bedside.
    I think i will buy some double sided foam tape to place around the top edge, and likely glue the rubber top seal down.
    Its a little gross outside these days, and i do not have a place to install inside. So i am stuck waiting for the weather to cooperate.
  15. Jan 16, 2010 at 4:50 AM
    bladez
    Due to the convex design of these/most fender flares, the top can not possibly pull away once the inside lip is mounted, especially with this new heavy duty fiberglass version. Just try holding them in place and then attempt to pull that top edge away from the fender with your finger. There is no way it will budge even slightly if they are pressed firmly against the fender when you mount them. It is a good idea to use a little glue between the gasket and flare though. They don't come glued on as they may need to be removed if/when painted. Good luck with the install and please do experiment to see how that top edge will not pull away before going to the trouble of trying to double-sided tape it.
  16. Jan 16, 2010 at 6:52 AM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    Those looks pretty amazing actually
  17. Apr 27, 2010 at 7:24 PM
    jacky_bubbles
    jacky_bubbles Senior Lurker
    Victoria
    Supercharged 1997 Tacoma
    Can someone tell if these are Xenon or Jungle fender flares in the photo below?
    From all the pictures I've seen, both brands look very similar. Anyone know about that resemblance or how they differ?
    thanks,
    Bubs
    Uploaded with ImageShack.us
  18. Apr 27, 2010 at 11:40 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Just buy some Flared fenders and bedsides if your going to do all that. They look better. IMO
  19. May 28, 2010 at 7:41 PM
    juandiaz9087
    juandiaz9087 New Member
    Puerto Rico
    Prerunner 4x4
  20. May 28, 2010 at 7:44 PM
    juandiaz9087
    Puerto Rico
    Prerunner 4x4
    where can i find a rollbar like the one in your photos
