Junkyard ECM?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Loudspeakerboy, Nov 19, 2021.
  1. Nov 19, 2021 at 7:45 AM
    Loudspeakerboy
    Loudspeakerboy [OP] Member
    Michael
    Hi,
    Does anyone know if my 07, 2.7 tacoma would run properly with a junkyard ECM, this assuming that the JY ECM is good? I’d prefer to spend <$100 to see if it solves my misfire issue before dropping $350 on a refurbished unit..
    Thought?
    Thanks, Michael
  2. Nov 19, 2021 at 7:49 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Michael.....not sure you're thinking clear......
    Spend <$100 on a JY ECM to gamble if its good
    or
    Spend $350 on a refurb ECM that has been tested and likely has a warranty.
    Seems to me the refurb is likely the more successful path.
    What diagnostics have you done to find the misfire source???
  3. Nov 19, 2021 at 7:55 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I grabbed a same part number ECU for my truck off ebay awhile back after I briked my original when HPTuners was in its infancy. Still using it to this day without issue.
  4. Nov 19, 2021 at 8:29 AM
    guyfromky
    guyfromky Well-Known Member
    What other diagnostics have you performed to lead you to the conclusion you need an ECM for a misfire?
  5. Nov 19, 2021 at 9:43 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    ya that’s kind of odd that he went for the ECM right away
  6. Nov 19, 2021 at 10:26 AM
    Loudspeakerboy
    Michael
    I’ve done a compression test, 165# per cold, checked for hydrocarbons in the coolant, there is no water in the oil and vice versa, replaced, plugs, coils, injectors, and the F/A sensor. All parts are denso. I currently have an intermittent miss on 1 and 3 at exactly the same time and the same number of misfires. I’ve swapped coil 1 for coil 2 with no change. I’m using the mode 6 function on my BlueDriver for the data.
  7. Nov 19, 2021 at 10:45 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you get the correct ECM for your truck it should be plug and play providing your truck doesn't have an immobilzer.
    That being said it would be unusual for an intermittent misfire to be caused by the PCM, I would be looking very close at wiring and checking connectors for loose pins before firing more parts.
    Are you getting any circuit codes or only misfire codes?
  8. Nov 19, 2021 at 10:56 AM
    Loudspeakerboy
    Michael
    Misfire codes only.
