jus got my stealth DC tool box. perfect fit!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by haynstyle808, May 6, 2011.
  1. Nov 1, 2020 at 8:30 AM
    #61
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    ok i see Ur dilema
    the box i have does not have the wings or wood block
    sits directly on floor................holds MORE than the box U have pictured
    will almost come back to the wheel wells..............does NOT have to fit flush with front bulkhead
    i guess it could be located between wheel wells if necessary.............if something else was taking up
    the first 2feet or so of bed
    clears the wheel wells tho
    designed to fit under tonneau
  2. Nov 1, 2020 at 8:37 AM
    #62
    stif_meister13
    stif_meister13 Member
    Andrew
    2020 Tacoma TRD Off Road (Cement)
    Yeah I’m thinking I might have to get a regular box without the “wings.” I would prefer the look of them resting on the wheel well, sort of gives the impression that the box was “fitted” to the truck. Oh well.
  3. Nov 1, 2020 at 8:45 AM
    #63
    ROAD DOG
    FEW
    the box im referring to Was Measured out for the Tacoma
    NOT a generic box
    a few had purchased them..................... i was chasing it n my mind when i discovered
    ( Post #35)
    a perfect fit !!!
    did not hesitate to order.............arrived........bolted in
  4. Nov 1, 2020 at 8:51 AM
    #64
    stif_meister13
    Andrew
    I see. Looks like the gentlemen in post #35 installed it in a 2nd gen, but you say you were able to fit the same model (UWS TBC42W) into a 3rd gen? Would I run into issues with a short bed possibly? I just worry that with the wheel wells being pushed up closer to the cab that it would create problems.
  5. Nov 1, 2020 at 8:54 AM
    #65
    ROAD DOG
    FEW
    got nothing for u on the short bed...................
    i would think only the length would make a diff ( distance from front to wheel wells )
    the box does clear the width by fractions...............soooo
    even if from front bulkhead to wheel well was a concern
    the box should fit
  6. Nov 1, 2020 at 8:56 AM
    #66
    ROAD DOG
    FEW
    ordered thru Home Depot..................came in on time
    unbox take out to truck
    fits or it dont..................right there !!!
    no hassle
    i did mount my box 2 inchs in front of bulkhead
    i Enlarged the drain holes so they would NOT get blocked
    leaves will find there way back there
    other than that
    be careful drilling ...............canister+fuel tank + wiring loom
