Just a bit more up front?
Discussion in 'Suspension' started by 3coma, Sep 21, 2016.
  1. Sep 21, 2016 at 4:18 PM
    3coma
    3coma [OP] my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    So I've had 885's for a while and left out the lean spacer when I did the install. I'm thinking if ordering a half inch spacer for the driver side and putting the other one on the passenger side to give me a level front end, and add a half inch total. Tell me if this makes sense or if you've done it and how it worked out. I just order LR uca's through the group buy and think this would put me where I want to go for 285's when my 265's wear out. Thanks
  2. Sep 22, 2016 at 8:22 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, that would work to level the front and add 1/2" of overall front lift.
  3. Sep 25, 2016 at 4:05 AM
    Rus TRD
    Rus TRD Well-Known Member
    Don
    Pa.
    2015 DC TRD Sport
    Bilstein 5100 with 884 Springs. Full audio system. Stealth 6 Wheels. Cali led light.
    Could I do that to my 884 coils to give me more lift. Instead of preloading my coils by setting them at .85?
  4. Sep 25, 2016 at 10:18 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes. However if your 5100s have the spring spacer already in the strut on the driver side to counter the lean you would want to do equal top plates on each side. Adding top plates will lower the point of the suspension bottoms out by the amount of the spacer. Bump stops should be adjusted accordingly.
  5. Sep 25, 2016 at 12:45 PM
    Rus TRD
    Don
    Pa.
    2015 DC TRD Sport
    Thanks for the info!!
