Just added 5100s and AALs
Discussion in 'Suspension' started by Dane-Taco, Oct 31, 2009.
  1. Oct 31, 2009 at 9:38 PM
    Dane-Taco
    Dane-Taco [OP] Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    I just added 5100s (raised to 2.5"), 2" AALs and shocks. I got a total of 3" lift in the front and 2.2" in the rear. (Will add before and after pictures tomorrow) With that said, how important is a diff drop? Should I do this or is that for a larger lift? ...Also, is there a certain way to make the boots on the shocks look good? I have the zip ties on there and it seems to bind the boot where it is sinched down and doesn't make it look symetrical? Any tips?
    Thank you
  2. Nov 1, 2009 at 11:13 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Did you use the stock front springs?
    I will be doing the 2" AAL 5100 bilsteins and eibach front springs next week and kind of wondering how much to raise the front with the 1.6" spring lift to match the rear.
    I will do the rear first to try and estimate how much to level it.
  3. Nov 1, 2009 at 11:21 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    i would get a diff drop for 2.5" or higher. as for the shock, not so sure how to make it look better
  4. Nov 1, 2009 at 11:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Wait on the diff drop. Only use one if you have front end vibes. In many cases, they cause vibes, and its hard to chase them down.
  5. Nov 1, 2009 at 11:46 AM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    doesn't the diff drop also help your cv boot/joint angles too?
  6. Nov 1, 2009 at 11:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not much. A 1" diff drop only lowers the front of the diff, eaquling 1/2" drop at the axel. 1/2" spread over the length of the front driveshaft is only about 1 or 2*. Not worth the 1" front drop. In many cases, it causes vibes.
  7. Nov 1, 2009 at 11:55 AM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    you are correct at it sometimes causing vibes. but ive seen them and heard of them being used to help the cv boot and joint angle. but since you used numbers and technical terms, you win :D
    :p
  8. Nov 1, 2009 at 12:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL...Not trying to "win"...just trying to give accurate info. :)
  9. Nov 1, 2009 at 2:01 PM
    Dane-Taco
    Justus
    Wasilla, AK
    Yes, used the stock coil with the bilstein.
    ...Will keep an eye on the front end, thanks for the info
  10. Nov 1, 2009 at 5:17 PM
    outnback
    outnback Member
    Wheres a good place to get the 5100's?
  11. Nov 1, 2009 at 5:29 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    That would be www.downsouthmotorsports.com do a search on here tons of info!! good Luck!!:)
  12. Nov 1, 2009 at 7:35 PM
    Dane-Taco
    Justus
    Wasilla, AK
  13. Nov 1, 2009 at 7:40 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Go with them over everyone else there price cant be beat and you will have them in 2 days. Thats where I bought mine and they are going on tomorrow.
  14. Nov 1, 2009 at 7:42 PM
    Dane-Taco
    Justus
    Wasilla, AK
    Here are the before and after pictures. Slightly different aspects, sorry. Extremely pleased with the way it looks, just hoping the ride is still nice!!
  15. Nov 1, 2009 at 8:04 PM
    outnback
    outnback Member
    After you drive it, an update on ride quality would be appreciated. I am leaning toward this type of lift also. Thanks.
  16. Nov 1, 2009 at 8:15 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    x2 It's where I will be getting mine
    BTW the truck looks good dane
  17. Nov 1, 2009 at 8:20 PM
    Dane-Taco
    Justus
    Wasilla, AK
    Will do
  18. Nov 2, 2009 at 6:29 AM
    RI06TACO
    RI06TACO Well-Known Member
    Jeff
    Rhode Island
    06 Tacoma Sport
    Looks good, doing the same this week, except I got the dealership to do the TSB on the back. What are the 5100's set at? and any updates or change in ride quality?
    *BM1 at Sta Castle Hill..you?
  19. Nov 2, 2009 at 6:25 PM
    Dane-Taco
    Justus
    Wasilla, AK
    IT1, Tracen Petaluma, Was previously stationed with Milne and Martin.
    Wish i could have put on the TSB. That was for 2008 and below, I believe. The 5100s are set to 2.5, today was first day driving distance and it is a noticeable stiffer ride (obviously), but overall very pleased with ride quality. This is subject to opinion, but rides nothing like a buddy's Jeep with 3". Couldn't ride in it with a drink without a lid!!!
  20. Nov 2, 2009 at 6:37 PM
    RI06TACO
    Jeff
    Rhode Island
    06 Tacoma Sport
    Oh nice, I see Milne all the time..I am on the fence about setting my billys at 1.75 or 2.5..would def like the higher lift but don't want any problems (vibes,alignment, etc.)..also not sure how high the rear will be with the TSB..
