Just an observation.....by my wife
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoDan723, Sep 19, 2015.
  1. Sep 20, 2015 at 4:23 PM
    Gply
    Gply Well-Known Member
    Bay Area, CA (east bay)
    2015 Tacoma DC TRD off-road
    More shit then I ever planned on doing
    100% correct! Pre loading any coil over will make it ride stiff! I had my kings preloaded to 3" of lift and it road stiff. Dropped it back down to 2.25" and my ride improved drastically. Still slightly stiff but in a good way, if that makes sence.
  2. Sep 20, 2015 at 4:25 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    When I bought my Tacoma, the previous owner threw in a Toytech Boss kit that he never got around to installing. I heard it described as "plush" by one person in a thread I read several months ago. It is NOT "plush", but then again, it isn't harsh either. Just "firm" at lower speeds. Personally, I'm NOT satisfied with it. I actually preferred the ride when it was stock. Now that I've put different tires on it, I'm even LESS satisfied with the ride. To get decent gas mileage, I'm running my Duratracs with a bit more pressure than I'd like. That contributes to the "bounce" when I hit a bump. Looking at several options as far as suspension changes going forward.
    That said, I'm "old school" with my 4wds. I expect 'em to ride like a truck, but it doesn't have to rattle my teeth when I hit a bump.
  3. Sep 20, 2015 at 4:28 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    My truck handles like a shopping cart. You know - the one with the wheel that keeps going in circles as you go down the aisle...
    Pigpen, Josh828 and Bluegrass Taco like this.
  4. Sep 20, 2015 at 4:29 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    My biggest complaint with my suspension is the sensation that the front end is ricocheting off bumps. The rear actually rides pretty good. But, as I said in a previous post, I think a lot of the problem is over-inflation of tires (relative to inflation that would provide a good ride)
  5. Sep 20, 2015 at 4:33 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I always get the Jeff Gordon #24 kiddie cart! My wife doesn't like it when I make engine noises while we wait in the check out line!
  6. Sep 20, 2015 at 4:41 PM
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    Lots of variables. You just can't take what worked for one truck and expect the same unless most everything on the truck is similar. Spring rate and length of spring, shock valving, weight of truck and payload weight, alignment and others. Not to belittle toytec boss lift ( as I'm sure there is an application these great for), but Kings, Fox, Icon, Sway a way and other racing shocks are just in a different league. The way may coilovers are set up, if you put them on a stock single cab they would probably make you pee blood, but on my heavy double cab they ride very nice. They are others but Down South Motor Sports can help anyone with proper application.
  7. Sep 20, 2015 at 4:43 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Wheelers progressive 3 leaf pack, ditch the overload, Bilstein 5100's all around. Ride like a Cadillac!
    HomerTaco likes this.
  8. Sep 20, 2015 at 4:43 PM
    bluewaters182
    Greg
    Ohio
    Are your coilovers adjustable?
  9. Sep 20, 2015 at 4:44 PM
    bluewaters182
    Greg
    Ohio
    Not if you are loaded with armor, winch and other goodies.
  10. Sep 20, 2015 at 4:48 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Yes....preload.....THey're considered 0" to 3" and I'm at 2-3/4" on the front. That high preload is probably a contributing factor to my DISlike of the ride quality. Gonna try to back 'em down a little first chance I get.
  11. Sep 20, 2015 at 4:49 PM
    bluewaters182
    Greg
    Ohio
    Should make the ride a lot better.
  12. Sep 20, 2015 at 4:54 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I'm also going to start backing down the pressure in my front tires until I see gas mileage start to tail off. Running 35 psi now. I tried 'em at 30psi early on, but the gas gauge imploded on a 400 mile road trip. Plan is to see next what happens at 32 psi. I may come home from work tomorrow and back off the preload on the shocks until I get down to what amounts to a 2" lift. 95% of my driving is 70mph+ concrete interstate driving. I need to tailor the suspension to that.
  13. Sep 20, 2015 at 4:56 PM
    bluewaters182
    Greg
    Ohio
    Thats actually good for offroad too. When they are preloaded a bunch there is almost no down travel which make for a very poor ride on and off road.
  14. Sep 20, 2015 at 5:10 PM
    taco duck
    taco duck Well-Known Member
    SR5
    Do the obvious... get rid of the 20 inch wheels, and swap them w some 16's. More sidewall= smoother ride. Your welcome.
  15. Sep 20, 2015 at 5:17 PM
    #35
    bluewaters182
    Greg
    Ohio
  16. Sep 20, 2015 at 5:23 PM
    #36
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Agreed
  17. Oct 8, 2015 at 10:06 PM
    #37
    TacoDan723
    TacoDan723 [OP] Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    I'm BACK. Sorry, been traveling for work. Back in the saddle again. I have taken it all in and will drive it for a while to break it in. Still only have 2200 miles on it.
  18. Oct 9, 2015 at 2:51 AM
    #38
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    My truck drives fantastic with the complete overhaul of my suspension. It will take some coin to get there as you want to do it right the first time. When I took all the factory stuff off I was amazed at how cheap the stuff was. I guess weight is a issue as well as MPG's and cost when they design these. Before the suspension overhaul I could feel all the bumps in the road. Now it drives great. It will set you back at least $5000.
  19. Oct 9, 2015 at 3:01 AM
    #39
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    save your money.....accept a bump or two once in a while
  20. Oct 9, 2015 at 11:33 AM
    #40
    Rus TRD
    Rus TRD Well-Known Member
    Don
    Pa.
    2015 DC TRD Sport
    Bilstein 5100 with 884 Springs. Full audio system. Stealth 6 Wheels. Cali led light.
    2015 TRD Sport short bed. Bilsteins 5100 all around and and the front shocks set at 0 and 884 coils it made my new truck act like a total different truck. My wife said it was better than my stock set up.
