Just another Bilstein Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IB1BADMOFO, Feb 20, 2013.
  1. Feb 20, 2013 at 1:22 PM
    IB1BADMOFO
    IB1BADMOFO [OP] Member
    Orange County, CA
    12 PreRunner Sport Uprgade
    I am about to pull the trigger on some Bilsteins and the OME 885 coils. I have a 2012 toyota tacoma with the tsb. At the moment it is about 2.5 inches higher in the rear. If I add the Bilstein with the OME 885 will it be semi close to level?
  2. Feb 20, 2013 at 1:27 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Bilstein 5100's set at 0 or .85 should put you real close w/ the 885's. If im not mistaking I think the 885's will give you about 1.6" so setting them at .85 should put you at 2.45 for the front which will just about have you level.
    Pull the trigger!! That's a good setup. I have my 5100's set at 1.75 and love the ride. I am going to do the 885's when I have the money and drop the 5100's to .85. There are lots of guys running it the way you are and love it!! Wish I could have a tsb done on mine :( Could get rid of that damn 2" block in the rear.
  3. Feb 20, 2013 at 7:15 PM
    IB1BADMOFO
    Orange County, CA
    Thank you for all your help I appreciate it.
  4. Feb 20, 2013 at 7:46 PM
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    there are a couple of threads stating that you should leave your billies at zero when using ome 885's. I've got a set i just took off. they're set at zero and it was a stiff ride. i couldnt even imagine them compressed.
  5. Feb 20, 2013 at 7:47 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    885s 2.5-3" of lift. I have them. Leave the billys at 0 do not preload them. You might be higher in the front. 884s yield a little less lift
  6. Feb 20, 2013 at 7:48 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I think eibach springs provide the same lift and a smoother ride. At least that's what I read and I chose to run eibach springs. They are a great ride, much better than stock. Set at .85 I have about 2.7 inches of lift.
  7. Feb 20, 2013 at 7:49 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Your thinking of eibach coils
  8. Feb 20, 2013 at 7:51 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Eibachs are stiffer than 885s.
    Eibachs = 620 lb spring rate
    885s = 590 lb spring rate
