Just another Differential harmony thread. Might as well move along.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nDub, Mar 17, 2017.
  1. Mar 17, 2017 at 9:27 PM
    #81
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Ok , I hear ya man, also check the torque on your U bolts from your leafs while you are under there...I have heard quite a few of these were loose from the factory, 1 out of 8 of mine were not torqued properly, also might want to see if your zerks on your drive shafts u joints are greased also, mine were bone dry and required about 12 to 15 pumps of NLGI2 grease from Mobil to get them purged . My trans fluid was fine, and let me tell you, what a fucking pain in the ass that was, I would gladly pay a local indy trans to do that again. Anyhow, good luck to you, hope you get this resolved soon. I can imagine its pretty annoying I am sure.
    nDub[QUOTED][OP] likes this.
  2. Mar 17, 2017 at 9:35 PM
    #82
    nDub
    nDub [OP] Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Ubolts. Done.
    Ujoint grease now on the list. Thanks.
    Storman and shakerhood like this.
  3. Mar 17, 2017 at 9:39 PM
    #83
    Storman
    South Western PA
    No problem. Mine were bone dry, so much for dealer prep...ugghhh. dickheads!
    shakerhood and nDub[QUOTED][OP] like this.
  4. Mar 17, 2017 at 9:41 PM
    #84
    nDub
    Lead Free Gasoline
    Yeah I tried to get them to check the tranny before I took delivery. My expectations are low that it actually occurred. No shifting issues though so far :fingerscrossed:.
    shakerhood and Storman[QUOTED] like this.
  5. Mar 17, 2017 at 9:44 PM
    #85
    Storman
    South Western PA
    Oh believe me...I hear ya on that.....I do not trust dealers, sorry if anyone is offended
    but...
    I am, and always will be, my favorite mechanic.
  6. Mar 19, 2017 at 2:48 PM
    #86
    nDub
    Lead Free Gasoline
    Diff levels were fine.
    Couldn't find my grease gun and I could have sworn I just used it a couple of weeks ago. So the driveline will have to wait.
    No zerks on the rear and just two on the front as far as I could tell.
    shakerhood likes this.
  7. Mar 19, 2017 at 3:07 PM
    #87
    Storman
    South Western PA
    Same here, just 2 on front, mine took about 12 pumps to purge, I used Mobil 1 blue 222 NLGI-2 grease because it was free from work. Good luck bro.
  8. Mar 19, 2017 at 3:48 PM
    #88
    tnt
    tnt Member
    2017 DCLB TRD
    Here's the details on my Tacoma. 2 weeks ago I took my 2017 Tacoma TRD, (Double Cab/ Long Bed) to Toyota for 5000 mile service. As a test I asked them to drive the truck and see if they hear the noise that so many of use have. when I picked up the truck the following day, they said YES we hear it (positive 1st step) The service department asked me to leave the truck one day so they can try and figure out what's going on. The first day they had the Tacoma, Toyota Corp Engineering told the lead service tech to replace the Differential, so they did. No Change in the noise (either the Differential is not the cause or its a design issue ????????) ! So now Engineering is saying to replace wheel bearings. I should have an update in a few days. I'm hopeful that they will find the problem. I told the service manager, that I'm fine if they have to change out all components on the truck until they figure it out. So I'm hopeful that its just a matter of time, before they find the cause, we will see how long this takes. Fingers Crossed !
    shakerhood and nDub[OP] like this.
  9. Mar 19, 2017 at 4:02 PM
    #89
    nDub
    Lead Free Gasoline
    Perfect. Thanks!
  10. Mar 19, 2017 at 7:03 PM
    #90
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Well that sucks, hopefully the wheel bearings make a difference but I have a feeling they will not.
  11. Mar 19, 2017 at 7:20 PM
    #91
    nDub
    Lead Free Gasoline
    Anyone know why Storman's name is crossed out? Ban?
  12. Mar 20, 2017 at 5:29 PM
    #92
    ScottyMo
    ScottyMo Well-Known Member
    Scott
    Monterey, CA
    2017 Black TRD OR 4x4
    Sub for wheel bearings update...
  13. Mar 20, 2017 at 6:42 PM
    #93
    nDub
    Lead Free Gasoline
    So I was playing again with the noise today. It sounds like when you blow across the top of a soda bottle. Not the LCA howl, my 17 came with plugs. It's weird that it's at such a specific speed. I feel like if it was the diff I could do it all the time, like my other truck...
    Could feathering the gas either create vacuum or pressure in the exhaust to make that sound?
    I suppose people with aftermarket exhaust wouldn't get it if that was the case. Time for more searching.
  14. Mar 20, 2017 at 6:52 PM
    #94
    shakerhood
    Southern Ohio
    The Diff Howl I heard in the 17 was around 55-60 MPH.
  15. Mar 20, 2017 at 6:57 PM
    #95
    nDub
    Lead Free Gasoline
    Same here.
  16. Mar 20, 2017 at 7:16 PM
    #96
    tnt
    tnt Member
    2017 DCLB TRD
    The rest of the Story, Today I talked with the service manager. Corp Toyota said the noise is definitely coming from the Differential. Engineering said there is nothing wrong with the differential, its just the way its setup. They said there might be a TSB coming that will address this. So I guess at this point we Just Drive. I told the Service Manager that if mine locks up going down the road, they get to buy me a new Truck!
    nDub[OP] likes this.
  17. Mar 20, 2017 at 7:20 PM
    #97
    tnt
    tnt Member
    2017 DCLB TRD
    They were going to change the wheel bearings today, however Corp. Toyota told them they would be wasting there time.
  18. Mar 20, 2017 at 7:34 PM
    #98
    shakerhood
    Southern Ohio
    If you have the chance to speak to Engineering ask why some are doing it and others are not, something has to be going on.
  19. Mar 20, 2017 at 9:32 PM
    #99
    nDub
    Lead Free Gasoline
    I'm guessing that a lot of them are but people don't/aren't noticing.
    I can hear it anywhere from 40-60mph. But I'm looking for it.
    55mph is the honey spot.
    shakerhood[QUOTED] likes this.
  20. Mar 20, 2017 at 9:33 PM
    #100
    nDub
    Lead Free Gasoline
    Thanks.
    I think I'll still complain to the dealer at my next service if for nothing less than to document it.
