Just another stupid lift question
Discussion in 'Suspension' started by Maple85, May 7, 2009.
  1. May 7, 2009 at 3:28 PM
    Maple85
    Maple85 [OP] Well-Known Member
    Portland Oregon
    Lots to come at some point. Hopefully soon.
    So I got a 2006 Prerruner that is the base model. I just had the TSB completed so I have the new leafs in back and new shocks for both the back and front. I think the TSB lifted the rear about a inch and now I want to level the truck. I think to level it I will have to get about 2-2.5 inches up front. What is my most economical option? I want something cheap but at the same time I don't want to hurt my truck.....I do about 99.5% road driving and i'm not to against a slightly stiffer ride. What to you recommend and what will it cost for parts + labor?
  2. May 7, 2009 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bilstien 5100's should fit your needs. You can install them your self, and save some cash. :)
  3. May 7, 2009 at 4:18 PM
    Maple85
    Portland Oregon
    I'm not great with trucks and don’t want to **** something up so I will probably just take it to a shop. How much do you think labor would cost? Do they just slap them on or do they do an alignment and everything?
  4. May 7, 2009 at 5:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For an alignment and install, $250.00 should be reasonable.
  5. May 8, 2009 at 7:08 AM
    ELKAHOLIC
    ELKAHOLIC Well-Known Member
    Edgewood Texas
    2016 DCLB OFFROAD 4X4 Quicksand
    Icon suspension, Falken Wild Peak AT3W,s, Marshall Fab sliders, Built Right uca's, BAMF grill, Cali Raised led light, Bakflip fibermax, Husky mats, Clazzio leather
    I got all 4 5100s installed for $100 alignment $80 I set mine at 1.75 and I sometimes have to take a double take sometimes it looks a little nose up but it mesures 3/4" higher in the rear. I dont think I would be happy if I would have gone 2.5". When I park on level slab and put a 4' level on my bed rail it reads almost perfect. Very slightly higher in rear. At 2.5" it would read higher in front. If I put any thing in the back of the truck it looks nose up and I dont like that look. So I would not more than 1.75" unless you want to do an aal. That's my 2 cents. [​IMG]
