Just Between You, Me, and the Bingo Card: Life Lessons from the Assisted Living Facility
Discussion in 'Colorado' started by Squeaky Penguin, Dec 17, 2015.
What should we call old Brett's train set?
  1. Scale Model
    7.1%
  2. Toy
    7.9%
  3. Nearly scale but far too many cirlces
    11.4%
  4. Trains go in circles
    11.4%
  5. Bitches love my train set
    55.7%
  6. Old guys are wierd
    29.3%
Multiple votes are allowed.
  1. Dec 18, 2016 at 6:06 AM
    #321
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Thank you! :D
  2. Dec 18, 2016 at 6:43 AM
    #322
    Madjik_Man
    Colorado Front Range
    When it's all said and done you should invite us all over for a BBQ/beer/train extravaganza.
  3. Dec 18, 2016 at 6:50 AM
    #323
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I'll just bring pics to the Stranahan/New Belgium meet. :D
  4. Dec 18, 2016 at 6:51 AM
    #324
    Madjik_Man
    dafuq is this you speak of?
  5. Dec 18, 2016 at 6:52 AM
    #325
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    You're not in the loop?
    my bad.
  6. Dec 18, 2016 at 6:55 AM
    #326
    Madjik_Man
    Loop? I see what you did there. ;)
  7. Dec 18, 2016 at 8:50 AM
    #327
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    This one seems alright....
    Maybe we should trade up the one we have now?
  8. Dec 18, 2016 at 4:29 PM
    #328
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    :ohsnap: @sean266 getting traded in for a better MOD-el. :D
    CO MTN Steve and 3378jakesr5 like this.
  9. Dec 18, 2016 at 4:34 PM
    #329
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    3378jakesr5 and Deathbysnusnu like this.
  10. Dec 18, 2016 at 9:05 PM
    #330
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    :smack: Really!!
    Deathbysnusnu[QUOTED] likes this.
  11. Dec 21, 2016 at 7:15 AM
    #331
    WillT
    WillT Well-Known Member
    Colorado
    '21 Colorado ZR2 Bison
  12. Dec 21, 2016 at 7:39 AM
    #332
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Yes, Brett you need a beach for the choo, choo!
  13. Dec 21, 2016 at 9:29 AM
    #333
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I'm not sure a 2nd gen would be appropriate on my layout...
    Beaches love my train set. :cool:
    Package coming from Trainworld today. :dancingbacon: been waiting since last week for this.
    CO MTN Steve likes this.
  14. Dec 21, 2016 at 10:12 AM
    #334
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    A ballast tutorial.
    Start with a bead of undiluted white glue down each side of the track bed.
    Next, sprinkle ballast down each side of the track bed. Get it between the ties as you go, there will be a lot of "fill" on the very edge as you make it look uniform.
    The sprinkle ballast down the center of the rails. There should be no glue in the center just yet.
    Being as it's a smaller scale, I use a small fan shape brush to gently spread it down the track. This will level the ballast between the ties and spread the excess to the edges.
    It's important that everything be dry during this step, except for the original bead down the edge, which is thoroughly covered at this point.
    Larger scales I use a chip brush, whatever works is fine.
    The toothpick is just a marker from where I left off the last time.
    Then use the brush to shore the edges back up.
    The left is fresh, unglued ballast. The right was finished last week.
    Gramps, CO MTN Steve and lobsterbait like this.
  15. Dec 21, 2016 at 10:33 AM
    #335
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Next use the highly controversial wet water, a drop or two of dish soap and 16oz water mix, give or take. If you get soap bubbles when you spray it, use less soap.
    Spray the ballast well. It needs to be wet through to the bottom. Otherwise the glue will float on top and cause serious erosion to your freshly poured ballast that you spent time grooming. Smaller scales use something that produces a fine spray or the ballast will blow away.
    Soaked.
    Then the 50/50 diluted white glue and water. Start right down the center. then come back and do the edges.
    After you have glued the center and edges, there will most likely be a few areas where the ballast ran, notice the black track bed showing through.
    No biggie, sprinkle some more ballast on these areas, it's wet so it sticks easily.
    Then SPRAY IT AGAIN WITH THE WET WATER. otherwise it will float away when you apply more diluted white glue.
    Should look like this at this point. Do not worry about the ballast laying on the rail or the ties. That is the next step and one of the easiest.
    Don't cheap out here, use a Reach Toothbrush with firm bristle. Size and color of handle is up to you.
    After the ballast is dry, it will feel hard and have no flex. Use the toothbrush to gently yet firmly remove the ballast from the top of the ties and the edges of the rail. Usually takes just seconds, a few passes is all that is needed.
    Should look like this when done. Run a vacuum across the rail and it will clean the loose grains right up.
    Done. Run train and look for any issues.
    CharlieCafe, Gramps, jubei and 2 others like this.
  16. Dec 21, 2016 at 3:45 PM
    #336
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  17. Dec 21, 2016 at 3:56 PM
    #337
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  18. Dec 21, 2016 at 4:08 PM
    #338
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Awesome. When you said you had to test your train out. I pictured you laughing just like he did.
  19. Dec 23, 2016 at 5:19 PM
    #339
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  20. Dec 23, 2016 at 5:28 PM
    #340
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Are those happy little trees?
