Just Blew A Lot Of Fuses-Need Some Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by O-Dubs, Apr 30, 2010.
  1. Apr 30, 2010 at 11:09 AM
    O-Dubs
    O-Dubs [OP] Well-Known Member
    I've got a '96 and long story short the positive battery terminal touched the metal bracket for holding the battery down and the truck started to smoke and emediatley went dead and had VERY little brakes and no steering, i was only going a few miles an hour on my property so it was ok, so i jumped out and pulled the battery away and thus the smoke stopped. Now the truck will sometimes start up and run a few feet then die and its like the battery isnt even connected, even though it is and its not hitting the metal that caued the initial problem. I called my local mechanic and he thinks i blew several "big" fuses that would likely be bolted down inside/next the fuse box. Does this make sence to anybody, can anybody offer some help it'd be much appreciated.
  2. Apr 30, 2010 at 11:31 AM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Could be fuses or the computer took a hard hit from the short.
  3. Apr 30, 2010 at 11:35 AM
    O-Dubs
    just spoke to local toyota parts guy, told me i needed a replacement 80 amp main fuse thats what my mechanic said as well so i order one for $18 and gonna get it tomorrow so i'll go from there...
  4. Apr 30, 2010 at 11:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    Where are you at in PA dubs?
    In the engine compartment on the driver's side is where the "big" fuses are. I would suggest getting your battery and alternator test along with changing/checking the fuses.
  5. Apr 30, 2010 at 11:37 AM
    desertdude59
    good luck. Hope the truck runs
  6. Apr 30, 2010 at 11:40 AM
    O-Dubs
    thanks for the help everybody, ya i'm also gonna get it checked out even if this solves the problem just to be on the save side
  7. Apr 30, 2010 at 11:58 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The first thing I'd do is ANCHOR THAT BATTERY DOWN !!! How'd it get loose enough to make contact with anything ?.......:eek::eek::eek:
    :facepalm: :smack::smack:
  8. May 1, 2010 at 3:42 PM
    O-Dubs
    i anchored down the battery so thats set, but i also tested all the fuses and even the main 80 amp fuse if completely fine, truck will still start but putters a lot and if you try and drive it'll stall does anybody have any ideas?
  9. May 1, 2010 at 3:47 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    could have smoked some relays and possibly melted some wires. start looking over wiring. hope you find it fast and cheap... sounds like you got some good damage.
  10. May 1, 2010 at 3:56 PM
    O-Dubs
    oh ya, the relay referred to as "starter" on the fuse box lid has 4 prongs, and only one of them is lighting up the meter, if i just change the relay will that solve the problem or is it deeper than that
    on a search i found that there are supposed to be "fusable links' under the fuse box, could they be the source of my problems?
