Just bought 2018 SR5, having issues, what to do?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CSFastlane, Jan 21, 2021.
  1. Jan 21, 2021 at 4:27 PM
    CSFastlane
    CSFastlane [OP] Well-Known Member
    What's up guys just bought bought a 2018 Tacoma SR5 with 20k miles on it from a Toyota dealer. Its not a used certified. Well while driving home I noticed vibration in the steering wheel, that is really noticeable at highway speeds and while braking the whole truck shudders. Well after looking at the service records, it looks like the first owner had been to the dealership 6 times with drivability and "brake" concerns. The last time being about 3 months ago, where it looks like he traded it in. So I am thinking they just didn't fix the issues and sold it to meupload_2021-1-21_19-27-14.gif I've read through the forums and the various fixes for vibration issues, but it looks like they tried to fix it but never could. I am sorry that my first post is negative but I am not sure what to do, since it isn't certified used and the dealer didn't offer a warranty. What should I do in this situation? Is all fault on me for not noticing it before i bought it, or should they help me out since they might of sold it knowing something was wrong? Any advice would be appreciated. First time buying a car from a dealership so I am not sure what to do.
    EDIT: Also in the service notes its had the vacuum pump replaced twice and the lifters and rocker arms replaced? these motors don't have lifters? do they
    cryptolyme and Skydvrr like this.
  2. Jan 21, 2021 at 4:31 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    What are the laws in your state? My state has a 3 day buyers regret on all contracts except used cars.
    Silentshredr and itzyoboipaul like this.
  3. Jan 21, 2021 at 4:31 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Dealers usually sell their used trucks with a month-3 month warranty where they'll fix anything. Check to see if you have that first, if so get it fixed. If it's really annoying theres I think a 3 day period on new and used cars where you can take the truck back and get in everything you invested into it. Well least in NJ there is
  4. Jan 21, 2021 at 4:32 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    You didn't notice this issue on the test drive? Take it back to them, demand for it to be fixed or cancel the deal.
  5. Jan 21, 2021 at 4:33 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Are you sure it's not under the original factory warranty. Mileage is low enough just have to check the date is was first put in service.
    BSFord, cryptolyme, griffee and 5 others like this.
  6. Jan 21, 2021 at 4:35 PM
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    1. Are the tires/rims hot after driving a few miles?
    2. Have you gotten the truck onto an alignment machine (if so post the alignment numbers)?
    3. Does the problem get worse at speed; if so what speed?
    4. Does the problem get worse when you brake?
    5. Does the vibration go away if you put the truck into neutral?
    Not much could go wrong with the steering... sounds like an alignment issue IMO (especially if it's speed-related), but it may be a stuck brake (unlikely), rims, or tires. I would rule out the simple things first.
    Edit: Didn't read the part where OP stated the issue was with braking. Jack the truck up and see if a rotor is warped/inspect the brakes. Could be rotors or worst case calipers. The previous owner probably heated the rotors up and warped them badly. There's all that much that could go wrong with the brakes; cost or problem-wise.
    SR-71A and RedWings44 like this.
  7. Jan 21, 2021 at 4:37 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    20,000 miles and it was sold "AS IS"? A good lawyer would get you 2 trucks for that. LOL
    Zim
  8. Jan 21, 2021 at 4:46 PM
    CSFastlane
    yes has 11 months left on the 36,000mi warranty and has the 60,000 mi powertrain. But it appears that the dealer where i bought it from is where the original owner took it for service, and reading the service notes they couldn't fix the issues.
  9. Jan 21, 2021 at 4:49 PM
    CSFastlane
    They said there was no dealer warranty, only the manufacture warranty and I bought it in Tennessee.
  10. Jan 21, 2021 at 4:49 PM
    OrangeRa1n
    Houston Area
    TRD-Offroad 2021
    Go to a different dealer :thumbsup:
  11. Jan 21, 2021 at 4:51 PM
    Taco_Coma
    South NJ
    2018 DCSB SR5
    take it back to get fixed then. if they can't is there another dealer close?
    Chew likes this.
  12. Jan 21, 2021 at 4:53 PM
    CSFastlane
    It vibrates at all speeds , just seems to be worse at highway speeds ,and shudders while braking at all speeds again worse at highway speeds.
  13. Jan 21, 2021 at 4:54 PM
    crbr
    crbr Well-Known Member
    east TN
    18 Sport / 93 Mastercraft Prostar 190
    ^ ^ this
    You have warranty from the manufacturer. Just a sorry dealer. Find a near-by manufacturer service center and get it looked at.
    ABA180 likes this.
  14. Jan 21, 2021 at 4:56 PM
    CSFastlane
    correction i bought it in ga, i live in tn. but they are only about 40 min from me, I just bought it two days ago. I will call them tomorrow and see what they say.
    lynyrd3 likes this.
  15. Jan 21, 2021 at 4:56 PM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    If they have a Toyota sign out front, they have to fix the car. I don't think there's a pick and choose on warranty repair. Climb the ladder man, this is good money and folks are phucking with ya.
    Zim
    Rottencotton, lynyrd3 and Skydvrr like this.
  16. Jan 21, 2021 at 4:58 PM
    anthonynoriega
    anthonynoriega I just wanna disappear and find nothing.
    Anthony
    Idaho
    2019 Tacoma SR5 QS DCLB
    OV Tune 2.0, UpTop Rack, RTT, Total Chaos Bed Stiffeners, LED Grille Lights, Custom decals and pretty stickers.
    Get a blow torch, some pliers, and a baseball bat... go ham on those sons a bitches.
    JaiOME, lynyrd3 and Tacman19 like this.
  17. Jan 21, 2021 at 4:58 PM
    crbr
    east TN
    Chattanooga or Cleveland should have large and reputable service centers. Toyota of Knoxville is good for me.
    tacotoe and GoldenBrew like this.
  18. Jan 21, 2021 at 4:59 PM
    OrangeRa1n
    Houston Area
    TRD-Offroad 2021
    Could be alignment. Or maybe the PO hit the brakes hard enough to warp them. Maybe both. Either way, a mechanic should be able to find the issue.
    To recap: A Toyota dealer sold you a truck that still had a warranty and in the service notes wrote, "We can't fix this". If it's under warranty, bring it to a different dealership and KEEP all of your documentation. If the problem persists past the warranty's expiration, having documentation proving that you attempted to have Toyota fix it is imperative. Not much can go wrong to cause a vibration, especially if its brake related. Don't worry so much! Have it looked at somewhere else and enjoy the truck.
    tacotoe likes this.
  19. Jan 21, 2021 at 5:01 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    It's got to be under the warranty from Toyota still I bet. As was said, check state law if not..
  20. Jan 21, 2021 at 5:04 PM
    CSFastlane
    and no didnt notice it on test drive, traffic was heavy and the roads wasnt the best so didnt notice it till i got
    the service notes say could not duplicate.
    JaiOME likes this.
