Just bought a 11 regular cab, how do I get XM?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by imacericg, Aug 22, 2011.
  1. Aug 22, 2011 at 8:02 AM
    imacericg
    imacericg [OP] New Member
    I bought a Tacoma '11 regular cab over the weekend and I want to get XM installed on it. I see the radio has a "SAT" button. Is there a way to buy equipment and hook it up through the unit? I would rather not buy an add-on that I have to mount somewhere.
  2. Aug 22, 2011 at 8:45 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Go back to the dealer.
  3. Aug 22, 2011 at 1:55 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    They all have a external receiver and wiring but it does run through the radio. I think there is one radio unit that is NOT compatible but not positive. If you have the sat/am button then I believe your ok to go. Just give them the radio number to be sure. They change things so fast it's hard to keep up.
  4. Aug 22, 2011 at 2:04 PM
    KCin HBCA
    KCin HBCA Well-Known Member
    Keith
    Huntington Beach
    09 Dbl Cab PreRunner
    Push the SAT button and see if an ID number shows up on the display and/or you get channel 1 on XM. If you do, the equipment is already installed, just write down the ID number and call or log onto xmradio.com and activate the radio.
    If you don't get anything when you push the SAT button you will need to add the tuner or go aftermarket radio.
    Hope this helps, I have 4 xm radios... oh, and if you call and get someone with an Indian accent, hang up and keep calling the 800 number till you get an "in country" CSR. It'll save you a lot of hassle!
    KC
  5. Aug 23, 2011 at 10:24 AM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    I used these parts
    SIRIUS SCC1 Connect Universal Tuner
    Directed Electronics TOYSC1 Toyota/Lexus/Scion SiriusConnect Tuner Interface
    Lexus GS Shark Fin Antenna Adapter( not required) I used it to use factory antenna
    Every thing looks factory. It all mounts behind the radio.
  6. Aug 23, 2011 at 10:30 AM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    Do you have to have the JBL system, or does any stock system work?
  7. Aug 23, 2011 at 2:54 PM
    jbrenn
    allen texas
    10 sr5
    As long as the radio has the sat button it should work. Mine is not the JBL system.
  8. Aug 23, 2011 at 3:47 PM
    colder
    MN
    This is mine. However, when I push "SAT" nothing happens.
    What would I need?
  9. Aug 23, 2011 at 3:55 PM
    ICEMAN
    ICEMAN Well-Known Member
    Eric
    Middleburg, FL
    2010 TRD Sport DC Silver 4x4
    Weather tech floormats K&N CAI fabtech 6" lift procomp 17x9 6079 Nitto Terra grapplers N Fab Nerf bars Nfab Light Bar Hella 500 FF
    you have to go back to the dealer and get some $400 part, thats what they told me. the truck is wired for it but none of them come with the tuner or whatever plugs into the back. they told me it was $400 for mine installed its a 2010 i bought at the end of 09 still havent done it i would wait till you buy an aftermarket head unit
  10. Aug 23, 2011 at 4:36 PM
    jbrenn
    allen texas
    10 sr5
    That is the same radio i have.
    http://www.amazon.com/Sirius-SCC1-S...8COI/ref=sr_1_2?ie=UTF8&qid=1314142250&sr=8-2
    Sirius Interface for Toyota/Lexus Vehicles
    Toyota Lexus and Scion SIRIUS Connect Interface SIR-TOY1http://www.amazon.com/Sirius-Interf...FXQS/ref=sr_1_2?ie=UTF8&qid=1314142398&sr=8-2
    These two part will get you sat radio i also purchased the shark fin adapter So i could use the factory antenna.
    http://www.tss-radio.com/products/lexus-gs-shark-fin-antenna-adapter
    I installed it about a year ago. 2010 access cab sr5 5 lug
  11. Aug 23, 2011 at 4:37 PM
    colder
    MN
    Thanks!
    Regarding this shark fin antenna, I don't think I have one. Are you saying that this means the radio will work with my stock antenna, without mounting one of the sat ones?
  12. Aug 23, 2011 at 4:44 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Have to have the shark fin to get sat. Dealer told me 6 mon. free. XM told me 1 yr free. booya
  13. Aug 23, 2011 at 5:46 PM
    jbrenn
    allen texas
    10 sr5
    sat uses its own antenna The shark fin is the bump on the back near the third break light. If you don't have that the kit comes with one that mounts to the dash.
