Just bought a 2006 Tacoma I am stuck on what mods to do first
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sender20, Mar 21, 2025.
  1. Mar 21, 2025 at 8:10 PM
    Sender20
    Sender20 [OP] New Member
    Jacob
    2006 Tacoma 4wd
    None yet, I just bought it so I am thinking of a lift tires and new bumpers
    I just bought my first Tacoma I’m 17. I don’t know what to do first, I could easily build tube bumpers at home, I am thinking I will get the rough country 9,500lbs winch. For a lift I was thinking the rough country 3.5” lift with 33,s on bronze trd rims. Any tire suggestions I will obviously use it as my daily so I want them to not be super loud on the highway, but I live around mountains so I like adventuring on deactivated forestry roads and that type of stuff. I was also thinking of getting some led light bars. Any suggestions for tires, light bars and any thoughts on the rough country products, thank you.
    GTGallop and Hay Lobos like this.
  2. Mar 21, 2025 at 9:11 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    HWI and Hay Lobos like this.
  3. Mar 22, 2025 at 7:20 AM
    Hay Lobos
    Hay Lobos Let's be friends.
    Ben
    The Great State of Maine
    2013 Tacoma SR5 Access cab
    I would wait on the lift and winch. Get good tires and do all the maintenance. Check your fluids, grease the drivetrain, make sure your oil is clean, clean the air intake and check the filter. You don't want to drop money on fun extras if you're behind on the items that keep the truck running.
    You can do a *lot* without any mods. Go take a drive in the woods and see how it performs!
  4. Mar 22, 2025 at 7:39 AM
    LOLLY
    Alfredo
    Norwalk, CA
    At the very least, you can get a kinetic rope, shackles, and a come along. It would be recommended to wheel with another vehicle until you get comfortable with yours in case you need a tug.
    Sender20[OP] likes this.
  5. Mar 22, 2025 at 7:45 AM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    THIS^^ These trucks are very capable. I wouldn't go wasting money on a Rough Country lift...
    Maintenance first, don't go running up your credit cards on stuff you want, do the things the truck needs!
  6. Mar 22, 2025 at 7:56 AM
    Odlcjro01
    Odlcjro01 Well-Known Member
    Lee
    Rhode Island
    2021 Tacoma MGM DBC SR5
    LT265/75R16 tire, side steps
    I agree, do all the maintenance first. Drive it like it is and then decide what mods you may want. As for a lift, based on the research I did before I did mine. I would recommend 2" to 2 1/2" max. Anything more than that puts a lot of angle in the shafts.
    4WDTrout likes this.
  7. Mar 22, 2025 at 7:59 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Agreed! Came here to say Congrats and to take it slow and easy on the mods. I know it's fun to turn it into the ultimate truck, but I see a lot of guys with an ultimate truck in progress but they are broken down on the side of the road because they didn't prioritize basic maintenance. Then they end up getting chased by the maintenance dragon and it keeps them from getting the other stuff done.
    Change all of the fluids.
    Change out Belts and Hoses.
    New brake pads and shoes
    Good set of tires - I prefer BFG ATKO
    If your shocks are worn out do replace those and if you want to do a little lift here - again modest - that's a good time. I'm talking 1" maybe 1.5" Max 2".
    I'd stay away from Rough Country. Had their shocks in the past - meh. But I hear from reviews their other accessories are more for show and not for go. In other words they will lift the truck, but then you lose the performance gains of the lift. Less articulation, etc. Get a quality set up instead of buying future you some problems.
    But yes - After you get the Taco back to bullet proof status with all of the maintenance (it will last 100,000's of miles - dependably) then take it out and wheel it. See where it does well, see where it fails or struggles. Then the trick is to enhance the points that struggled w/o losing the parts that did well. And winches... I'm 51. Have never needed a winch or been on site where a winch was needed for off roading. All of my "winching experience" comes from farm work where we needed a winch to do do farm stuff and land management and most of that was using a winch on a crane on the back of a truck or a come-a-long hand winch. A front bumper winch was almost useless there too. I think a lot of guys add them because they think it adds girth to their dick but it doesn't. And the only people it impresses is other guys. No woman has ever said, "Oh you have a winch? Let me get my good eggs ready!"
  8. Mar 22, 2025 at 7:59 AM
    TacoTuesday1
    FL
    “Rough country” how about no
    maintenance on an 06 would be better than butchering it. Maybe figure that out first.
    not sure why you would lift beyond recommended to put a stock 4runner tire size. I have like 2” lift on 35’s.
    Rob MacRuger likes this.
  9. Mar 22, 2025 at 8:23 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I'd go thru the entire truck first to see if it actually needs anything and inspect the frame very VERY well. Then, drive it for awhile to make sure the engine and drive train is mechanically sound. THEN I'd start researching.
  10. Mar 29, 2025 at 6:27 AM
    Sender20
    Jacob
    2006 Tacoma 4wd
    GTGallop likes this.
  11. Mar 29, 2025 at 6:44 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    Cat got your tongue?
  12. Mar 29, 2025 at 6:47 AM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    This ^^^
    Make sure you have a truck worth fixing up. No point in doing mods if the engine and drivetrain needs some TLC to keep going. How many miles are on it? You can Google the model to check for typical problems and recalls. A good set of shocks is probably in order if those are originals on it now, and then a good set of tires that don't rub with every bump you hit (properly sized). You can turn it into a mall-crawler or offroad beast later.
  13. Mar 29, 2025 at 7:51 AM
    wdunnlee
    wdunnlee Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    06? Get an oil analysis to check on the head gasket… thats a good “mod”
