Just bought a truck, forgot to put it in 4wd...
Discussion in '1st Gen. Tacomas (1995-2004)' started by skedrc, Oct 13, 2018.
  1. Nov 2, 2018 at 12:17 PM
    #161
    skedrc
    skedrc [OP] Well-Known Member
    Preston
    Elko
    2005 MT 4wd
    According to Rock Auto the only length difference is about a quarter inch, that isn't enough for normal hubs to fit on there still....
  2. Nov 2, 2018 at 12:19 PM
    #162
    Wulf
    Wulf no brain just damage
    rock raisin
    Weird.
    Your new red hub is wrong, the Tacoma aisin hubs always have grey dials while the earlier IFS trucks use red ones. You may be able to use the snap ring on the Tacoma hub though
  3. Nov 2, 2018 at 12:20 PM
    #163
    skedrc
    Preston
    Elko
    2005 MT 4wd
    Thats what I was planning on doing, but I can't find another one of those gray hubs anywhere... The one you linked doesn't sit close enough to the CV to actually catch the teeth.
  4. Nov 2, 2018 at 12:25 PM
    #164
    Wulf
    rock raisin
    Then maybe something else is wrong. Are you sure your truck has manual hub knuckles/spindles and not ADD ones?
    Also, I wouldn't necessarily rely on the stock photo. That said it looks vaguely what mine did last time I had the hubs off AND they fit as expect. YMMV
  5. Nov 2, 2018 at 12:27 PM
    #165
    skedrc
    Preston
    Elko
    2005 MT 4wd
    I wasn't aware the spindles for the ADD were different.. I thought it would be as simple as swapping the tube from the old axle to the new one....
  6. Nov 2, 2018 at 12:28 PM
    #166
    Wulf
    rock raisin
    Something is definitely up, the CV should stick at least 1/8" or so past the hub gear when it is engaged. Here is some more info:
  7. Nov 2, 2018 at 12:29 PM
    #167
    Wulf
    rock raisin
    Err I misremembered, the spindle/knuckle are the same but the wheel bearing is different between ADD and manual hubs. Lots of good info here:
  8. Nov 2, 2018 at 12:32 PM
    #168
    skedrc
    Preston
    Elko
    2005 MT 4wd
    This is just so weird and confusing... As soon as I get home i'll do some more inspecting and take some more pictures of the whole assembly.
  9. Nov 2, 2018 at 12:37 PM
    #169
    Wulf
    rock raisin
    There are a lot of scams out there but for $20 I can show @skedrc how to avoid them all ;)
  10. Nov 2, 2018 at 2:21 PM
    #170
    skedrc
    Preston
    Elko
    2005 MT 4wd
    So do you think the solution is finding another hub similar to the one I have that is sunken in and can actually go onto the CV?
  11. Nov 2, 2018 at 2:23 PM
    #171
    Wulf
    rock raisin
    That would be a step in the right direction, the red dial hubs definitely do not fit as they are for 86-95 IFS pickups and 4 runners.
  12. Nov 2, 2018 at 2:23 PM
    #172
    Wulf
    rock raisin
    It would also be worth investigating whether the truck has ADD or manual hub wheel bearings before you throw more money and parts at it.
    black coffee likes this.
  13. Nov 2, 2018 at 2:25 PM
    #173
    skedrc
    Preston
    Elko
    2005 MT 4wd
    Alright, thanks for all your help man. I will post pics of everything when I get home.
  14. Nov 2, 2018 at 2:37 PM
    #174
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Send Wullf a plane ticket.
    Alternately is there a 4x4 shop anywhere around you? Some place you can talk to a guy who has experience with Toyota 4x4s?
    Internet diagnosis only goes so far. I bet a guy with knowledge can look at your issue and figure out how to correct it. Or tell you what you need to do.
    If I call my mechanic and tell him XYZ is wrong, he’d never say google it. He’d say bring it in and I’ll have a look.
  15. Nov 2, 2018 at 2:41 PM
    #175
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Haters gonna hate.
  16. Nov 2, 2018 at 2:43 PM
    #176
    Wulf
    rock raisin
    if possible take a look at the back of the actual wheel hub assembly:
    manual hub:
    ADD hub:
    tcjacado likes this.
  17. Nov 2, 2018 at 2:55 PM
    #177
    Wulf
    rock raisin
    You may not be able to see the threaded portion but you should be able to see the brass bushing
  18. Nov 2, 2018 at 4:30 PM
    #178
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    If you look at the front of the hub/wheel bearing assembly, the ones for manual hubs have 6 bolts around the axle hole and the ones for ADD do not.
  19. Nov 2, 2018 at 5:21 PM
    #179
    skedrc
    Preston
    Elko
    2005 MT 4wd
    Yeah mine are defiantly manual then... I just can’t find these shallow mount aisin hubs anywhere.... I only need one.
  20. Nov 2, 2018 at 6:19 PM
    #180
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
