just bought a truck with a lift on it.
Discussion in 'Suspension' started by chaos316, Sep 28, 2011.
  1. Sep 28, 2011 at 8:41 PM
    chaos316
    chaos316 [OP] Well-Known Member
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    285/75/16 BFG KO2 Ditch Lights
    just bought a 2011 dclb sport 4x4 with a 3" revtek lift on it
    here is the link:http://store.revtek.com/products/productdetail/part_number=426A/1909.0
    now what i am wondering is if i wanted to take that lift out, and put a different 3" in, would i be missing anything? the truck did not come with any stock parts. or do the revtek lifts just bolt into place?
  2. Sep 28, 2011 at 11:22 PM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    You should be fine. So your going with a 3" lift now over the 6"?
  3. Sep 29, 2011 at 1:50 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    just until i get enough money for a 6 lol. or should i just stick with the spacers until i get enough?
  4. Sep 29, 2011 at 1:54 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Don't get a 6 inch. But if you must, just wait until you can afford it. Don't waste your time and money on another 3" lift.
  5. Sep 29, 2011 at 2:14 AM
    yotamikez
    Valrico
    x2 couldn't have said it better myself.
    Research the 6" before you buy it please, don't regret like some guys do.
  6. Sep 29, 2011 at 2:46 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    well whats soo bad about a 6"? is there any other alternatives or even getting as close as you can to 6"s without problems?
  7. Sep 29, 2011 at 2:56 AM
    yotamikez
    Valrico
    Well 6" is a drop bracket, so you have to cut the stock cross member and actually dropping it (hence drop bracket) IIRC all those kits are usually aal's and blocks in the rear (guys upgrade to bigger leaf packs). They are pretty expensive and if you want to run 35"s you might still have to do some trimming and maybe the cab mount chop.
    Its really a love hate relationship on this site. Some guys love it most guys hate them.
    Just do your research before buying anything.... i.e. search, read the FAQ in the suspension sections.
    There is also a rcd 4.5" lift and guys love that because its a lower profile drop bracket (IIRC) and you can add icon coil overs to get more lift. But I'm sure some drop bracket guys will chime in.
    I wanted a db in the begining but I talked to a bunch of guys that have them and they said stick with the 3" and regreting the db came up in the convo and if you ever want to go back you have to re weld your stock cross member in place...
  8. Sep 29, 2011 at 3:51 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    if you have a professional do it right the first time you will be fine.love mine,would have regretted a 3 inch.
  9. Sep 29, 2011 at 5:32 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    why would you swap it out for a different 3" lift?
    unless you're gonig to 6", I'd leave it as is.
  10. Sep 29, 2011 at 6:53 AM
    BlkTaco47
    BlkTaco47 Unhinged
    oh. i have the same lift, didn't change the ride one bit for me.
  11. Sep 29, 2011 at 12:53 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    because the wheels on them right now rub with the spacer lift. and I'm only running 18's with i think 285s
  12. Sep 30, 2011 at 9:57 AM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    What do you plan on doing with this truck? Daily Driver? Lots of wheeling? Mall Crawling/show truck?
    People don't like the spacer lift because it pushes the whole strut assembly down, thus giving the lift. The problem is that the LCA now has more up travel, but the strut does not. Normally, on a stock truck, when you compress the strut all the way the bump stop should hit before the strut bottoms out. With the top plate spacer lift, the whole strut was pushed down lower than it was before, which means the shock will bottom out before the bumpstops hit. With a top plate spacer like the Revtek lift has (I think), the ride shouldn't be much different than it was stock, unless you bottom out the struts, then it might be pretty harsh. If all you are going to do is drive on paved roads/a few gravel roads then this lift may work for you.
    A drop bracket lift gives more frame clearance, but it doesn't give any more clearance to the front of the truck. It uses brackets to drop the whole 'axle' assembly down lower, but it doesn't actually get it higher off the ground. It's similar to lifting the back end. If you put a 6 inch block on the rear, the axle stays the same distance from the ground, but the frame/body etc are lifted 6 inches higher. The only way to get more 'axle' clearance for a DB lift, or for the rear axle, is to run bigger tires. IMO, having to cut parts out, and putting a big bracket in would weaken the front end. Also, the extra height messes up the center of gravity, making it more likely of rolling over. If all you are going to do is drive on paved roads/a few gravel roads/mall crawl then this lift may be right for you.
    A 3 inch lift done right with, say, an Old Man Emu lift would lift the truck with new coil springs, and use struts with more travel. This should let everything compress to the bumpstops when the tires are stuffed. The 3 inch front lift pushes everything up, thus giving more clearance. The LCA's are still near the ground, but it is not as bad as what a DB lift would do, plus you haven't cut anything out.
    If you want to wheel, then upgrading your 3 inch lift may be a good idea. Some of your options (priced lowest to highest) are:
    • Bilstein 5100 leveling struts ~$300
    • Old Man Emu complete lift ~$800+
    • Fox/King/Icon Coilovers ~$1000++++
    The Old Man Emu lift just for the front is around $400. I have it in the front of my truck, and I like it. If you get the AAL/rear shocks then it is closer to $800. This would be a really good setup IMO.
    The Old Man Emu/Bilsteins would also be good for a daily driver.
    If you want to spend a couple grand, then get some King Coilovers, some new UCA's, and new rear leaf packs. That would be a sick setup.
    Somewhere in that list some ProComp 3 inch lifts could be thrown in there as well.
    The Bilstein 5100's only lift up to 2.5 inches, so to get slightly more lift people buy Eibach lift springs for the front, and run them along with the 5100's. This is a similar setup to the Old Man Emu one.
    Figure out what you want to do, and how much you are willing to spend.
    ~Sam
  13. Sep 30, 2011 at 11:38 AM
    sooner
    TX
    2011-4X4-LONGBED
    its your truck,i have the 6inch,running 285/65/18,which is equal to 33/13.50/15.i have more than enough clearance and don't need a gear swap.i average 20 mpg.i do a lot of muddin so thats why i chose 6-inch.also it wasn't much more for the 6-inch,than what the other guys are running.my truck is built for a purpose,and i use it as such.good luck.
