just bought a used 2001 tacoma, drove it home. now it won't start.
Discussion in '1st Gen. Tacomas (1995-2004)' started by jools, Oct 30, 2009.
  1. Oct 30, 2009 at 1:39 PM
    jools
    jools [OP] New Member
    Martha's Vineyard
    2001 tacoma SR5 4wd
  2. Oct 30, 2009 at 1:39 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    welcome and that sux. more details would help us help you.
  3. Oct 30, 2009 at 1:43 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Well your tires need to moving to the lft 1.2 inches.
    That will fix it...
    Or tell us what is not happening.
    Like you turn the key and ??
    Do the headlight turn on ? yes or no.
    if no check the battery...
    Does it have an alarm? facotry or aftermarket?
    Did you put enough gas in it?
    Does the starter engage?
    Do you like donuts with milk or coffie?
    Will the dodger ever get back inot a world series game?
  4. Oct 30, 2009 at 1:44 PM
    BravesFan
    BravesFan The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    You forgot- Can you rub your stomach and pat your head at the same time?
  5. Oct 30, 2009 at 2:23 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yea that smiley as the descrpition wont make anyone want to help you. you need to fix that. and if you did a search you would see there are about 10 different threads on non-starting tacos
  6. Oct 30, 2009 at 2:29 PM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    No.
  7. Oct 30, 2009 at 2:33 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Welcome to the forum. Most common problem would be the battery, but it could be the starter.
  8. Oct 30, 2009 at 2:34 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    definantly check if it has an alarm. mine wont let me start it if i dont use the remote start. freaked me out a few times
  9. Oct 30, 2009 at 2:36 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    lol
    This has got to be funniest thread I have ever seen..!! Thx for the laugh
  10. Oct 31, 2009 at 5:10 AM
    jools
    Martha's Vineyard
    2001 tacoma SR5 4wd
    okay, thanks. here's more info. It's a manual. 4wd. regular cab. power steering. Bought it used from a dealer. Drove it first and all seemed good except there was a bearing problem related to the clutch that the dealer was going to fix. which he did. truck was delivered to me yesterday at the ferry (I live on an Island). Drove it onto the ferry and turned it off. when we got to the Island it wouldn't start at first, turned the key and chimes sounded but no engagement of motor. After a couple of tries, it started.
    drove it home (it seems kinda noisy too?)
    when went to start it again later, same thing. Turn the key and nothing, except normal dings that ring when you turn on the car (so battery is working). Then tried again later and it started.
    It goes to my guy in the shop on Monday for complete look and inspection.
    meanwhile, I keep thinking I am doing something wrong when starting it. Usually when I drive a manual I slip it into neutral before starting. Is that wrong? Is there some other trick? I've never owned a Toyota before and I was SO looking forward to my little Tacoma for driving around the Island. I'm bummed. Want it to run right.
  11. Oct 31, 2009 at 5:22 AM
    Menametony
    Menametony Well-Known Member
    Tony
    Oahu
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar, OEM bed mat, softtopper. WeatherTech Mudflaps On order dissent bed rack and retrofits.
    call the dealer.. and see if they will fix the problem?
  12. Oct 31, 2009 at 5:26 AM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    did you have the clutch pushed in when you tried starting it?
    Not sure about the Tacoma, but several other manual tranny vehicles I have had required you to have the clutch engaged during starting, regardless of which gear(or neutral) it is in
  13. Oct 31, 2009 at 6:01 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Yeah that is pretty standard to manual transmissions, more of a safety thing.
    Putting it into neutral is perfectly fine. Put your truck into neutral and push the clutch start cancel button and see if your truck will start. Left of your steering wheel. Try that and get back to us.
  14. Oct 31, 2009 at 9:48 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    x2...
  15. Oct 31, 2009 at 10:04 AM
    Air_Ops
    Air_Ops Active Member
    Peter
    N.W. VT
    01 Ltd Dbl Cab
    TRD Headers, Cat Back Exhaust, Airaid Intake Tube, LC Engineering Throttle Body Gasket, Bilstein 5100 Series Shocks, Wheeler's Add-A-Leaf, LC Engineering Tundra Brake Kit, Re-Framed
    Make sure the clutch pedal is pushed all the way down into the carpet. I beleive there is a starter interlock which will not allow the truck to start unless the clutch pedal is fully depressed. I had a manual 4Runner before my Tacoma and it had the interlock and would not engage the starter unless the clutch pedal was pushed hard against the floor. There should also be an override switch on the dash which will bypass the switch on the pedal.
