Just changed ring & pinions to 4.56
Discussion in 'FJ Cruisers' started by 10851, Dec 7, 2013.
  1. 10851
    10851 [OP] Well-Known Member
    2013 FJ Trail Team
    Warn 9.5 cti, Warn winch bumper, Master Pull Synthetic Rope, Factor 55 Flat link, Factor 55 1.5" Hawse Fairlead, Factor 55 Hitch-link, Odyssey PC1700, Total Chaos 2" Long Travel UCAs and Race series LCAs, 3.25" lift, TC 4340 Axles, ICON CDCV coil overs with bypass shock, ICON +2 rear coils, ICON CDCV rear shocks, ICON upper and lower rear trailing arms and Panhard bar. Nitro 4.56 R&Ps, ARB Locker-front - Factory E Locker rear, ARB HO onboard air, BMC, Spidertrax 1.25 rear.
    Hey guys, I changed my ring and pinions to 4.56. This has made a huge difference in the way my FJ performs on the road and off. I actually picked up approximately 1-1.5 mpgs as long as I keep it 65 mph or below. 70-75mph I lose almost 2 mpgs. I live in a very mountainous area and this gear change has allowed the transmission to stay in a higher gear with better throttle response. The 3.73s were just too tall. I had East Coast Gear Supply build the 3rd members and ship them to me. They installed an ARB locker in the front. I got fantastic service from them and they were a real pleasure to deal with. Sooo... If any of you are riding the fence on a gear ratio change... do it.. You won't be sorry.. Be sure to do the proper break-in on the new gears.. ECGS has instructions on their website.
  2. Sje1124
    Sje1124 Well-Known Member
    Sean
    Oklahoma / Louisiana
    2010 DBL Cab TRD OR 4x4 W/ JBL
    Just a few
    What size tires are you running?
  3. 10851
    2013 FJ Trail Team
    265/75/16 Toyo Open Country MT. I am going to 285/75/16 as soon as I modify the body mount in the front wheel well. The 285s are 32.86 inches in diameter. This change will decrease my rpms by 80 @ 65mph and 88 @ 70 mph. The taller tire will only increase my crawl distance by 1 foot per minute @ 1,000 rpms in low range. I have the new tires sitting in the garage and it is killing me not having them installed...
  4. Sje1124
    Sean
    Just a few
    Ohh ok, I'm running 285/70/17s right now about about to switch to some 35s and trying to figure out what gears to go with.
  5. tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, cal tech, weather tech, viper, Al's tinting , leds , hide a hitch or chrome stinger , Walker Evans Resi's w/all pro 3" lifted ,flm, amp research , good year , diff breather mod, 4x4 switch light mod, plastic derped. Trailer socket relocate mod via Miles , 4:56 gears. Blue intake spacer, S.S. brake lines F&R, sway bar deleted, roll-x, pop-n-lock electric. Red metal TRD badges. Paid Off Mod- Chee Hu, superbumbs(f),timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra heat shield.CMC .mishimoto (custom bracket by Nate), powerstop, Rampage 50".Depo taillights.
    I also have 4:56 on 285/75-16 and love them. The truck runs so much better that its gonna be an automatic upgrade when going to larger tires from now on.
    I would go with 4:88 if I had 35's. I also rarely drive over 70mph.
  6. 10851
    2013 FJ Trail Team
    I agree with TX Ron about going to 4.88's for 35 inch tires. I used several gear ratio calculators and in my opinion, this one was the best. http://www.grimmjeeper.com/gears.html The other calculators didn't give as much information. Use the drop down boxes to enter your transfer case and transmission ratios. When entering the tire size, be sure to click the appropriate bubble. (Either inch or metric) If your tires are metric sized enter the proper aspect ratio. (I.e.) 285/75/16. You will get a more accurate tire diameter. When you change the ring & pinions... don't try to save money and go cheap on anything.... It will wind up costing you more in the long run..
    Good Luck! Feel free to shoot me a PM if you have more questions. I am no expert... but I will be happy to share the information that I got while doing my home work.
  7. zilla68
    zilla68 www.okledlightbars.com
    Moore,Oklahoma
    thanks for the info, I have a customer who is looking to upgrade his fj gears to compensate for the 285's he is running now.
    ECGS has a great rep in the jeep community also, so glad to hear you have had a good dealing with them. I will let him know.
  8. 10851
    2013 FJ Trail Team
    Zilla,
    If your customer has a 6 speed manual transmission, 4.10 ring & pinions will put his/her freeway rpms the same as my 4.56 with 5 speed automatic trans. The 6 speeds overdrive is 0.80 (6th) vs. my 0.72 overdrive (5th with the torque converter locked). The speed odometer gets it’s information from wheel sensors, so there is no need to add a calibration box after R&P change. I don't know about the 6 speed manual trans. I hope this helps..
