JUST CLOSED ESCROW !
Discussion in 'Garage / Workshop' started by AsianAnts, Jul 7, 2017.
  1. Jul 8, 2017 at 8:25 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Congrats on the new digs! Definitely need to see some more pictures of the inside and the garage/shop space. I love houses that have "interesting" driveways (eg. not a straight line rectangle).
    SilverBullet19 likes this.
  2. Jul 8, 2017 at 8:36 AM
    xybris
    xybris Well-Known Member
    The Lone Star State
    2014 DCSB
    Congrats OP, I know it's a great feeling! I'm about a week and a half from loading up my TRD Sport and getting the hell out of my apartment. Such a fun event, enjoy!
  3. Jul 8, 2017 at 12:49 PM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    If you're on a computer, you should be able to right-click the image and select "Save Picture As" and save it. If you're on a phone or tablet, press and hold the image, and you should have the option to "Download Image."
  4. Jul 9, 2017 at 10:26 PM
    AsianAnts
    AsianAnts [OP] just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    garage and backyard:
    Nickel and Benzdriver81 like this.
  5. Jul 9, 2017 at 10:27 PM
    AsianAnts
    AnT
    laundry room
    Benzdriver81 likes this.
  6. Jul 9, 2017 at 10:29 PM
    AsianAnts
    AnT
    kitchen/dining room taken from all four corners.... sliding door leads to the backyard... 2 open walls inside lead to the big living room... more pics to come later....
    apartment is almost packed!!!... but still have a garage full of stuff we need to pack =\
  7. Jul 10, 2017 at 7:50 AM
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    Sand, that's a sweet setup!!!
  8. Jul 10, 2017 at 8:15 AM
    Randy9448
    Randy9448 Well-Known Member
    Randy
    Congrats
  9. Jul 13, 2017 at 8:45 AM
    AsianAnts
    AnT
    Ok guys.. first problem:
    Master bathroom shower pressure is weak, especially the hot water. It uses a single lever to controls the water from off to on to hot....
    ALSO
    master bathroom sink 1 has a hot water pressure issue. the sink uses 2 levers to control the water: one for hot, one for cold. not much water comes out of the hot water side....
    The rest of the house is fine. no issues with the pressure. I was told it might be the compression something? or something compression??? Newb to plumbing stuff... any help would be greatly appreciated. If I can fix it myself for something cheaper than calling out a plumber or calling our the home warranty insurance stuff than i'll do it! and learn at the same time.
  10. Jul 13, 2017 at 8:51 AM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    If you have a home warranty be careful doing the work yourself or highering someone without going through the warranty company. With my home warranty, I have to call them, and they dispatch an approved company to come check out my issue. I pay the co-pay and that's it. I renew my warranty every year as it's saved me from buying a new AC, a new water heater, as well as repairing drywall/wood that was damaged due to a water heater leak.
    AsianAnts[OP] likes this.
  11. Jul 13, 2017 at 8:54 AM
    AsianAnts
    AnT
    Understood and thank you. I will keep that in mind :)
  12. Jul 17, 2017 at 9:05 AM
    AsianAnts
    AnT
    ok so I swapped the cartridge because someone said it might be a bad cartridge. and no luck..
    i'll call the warranty/insurance people to see if this is covered.
  13. Jul 18, 2017 at 12:57 AM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    Did you check the valves under the sink to make sure it was fully opened?
  14. Jul 18, 2017 at 4:46 AM
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
    He's having the same issue with the shower as well.
  15. Jul 18, 2017 at 7:39 AM
    #35
    AsianAnts
    AnT
    ^^^ what he said.
    but yes.. I did fully open the valve under the sink.. the results were still the same; very little water coming out. Been so busy I haven't been able to call yet.. It is an issue that will need to be taken care of but its not #1 on the priority list. It's up there, just not #1 right now.
  16. Jul 20, 2017 at 11:55 AM
    #36
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    How old is the house? Do you have hard water? Copper or galvanized pipe? My house is old and had some galvanized pipe. When I remodeled the guest bathroom and cut the pipe it was about 75% blocked with corrosion. Yuck.
  17. Jul 20, 2017 at 1:19 PM
    #37
    AsianAnts
    AnT
    the house is 2001. I'm pretty sure I have hard water. there was no mentioning of a water softening system and/or I did not see any. As far as the piping, I'm guessing copper because our fire sprinkler system is all copper piping. unless sprinkler system is piping and everything else is galvanized...
  18. Aug 7, 2017 at 10:36 PM
    #38
    AsianAnts
    AnT
    Ok. Update!!!!!!
    plumbing issue is good to go now. I installed some insulation on the garage door. I bought a chainsaw so i can destroy that tree that my wife backed in to.... LOL
    916carl likes this.
  19. Aug 8, 2017 at 3:34 PM
    #39
    916carl
    Carl
    So what was the water issue?
  20. Aug 8, 2017 at 3:54 PM
    #40
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Congrats on the new place!
