Just did a Mobil 1 0w20 flush - what are your DIY "lessons learned"?
Discussion in 'General Tacoma Talk' started by GrievousAngel, Oct 27, 2024.
  1. Oct 27, 2024 at 5:21 PM
    GrievousAngel
    GrievousAngel [OP] Well-Known Member
    2019 Tacoma SR 4x4 V6 DCSB Super White
    Ok, reality is I don't think I installed the tiny oil ring on the bottom of the canister and it caused oil to slowly weep, collect in the shield plate, and then blow all over the undercarriage when I got underway. I noticed some oil on the ground after my first drive.
    I wasn't sure if I could just drop the filter and change it, so I just drained it all (there was plenty in the drain pan...no worries there)
    I swear I put it (the small o-ring) on there...but I'm guessing I put it on and it fell out before I got the bottom plug installed.
    I reused the oil filter thinking I could just buy the o-rings (I had a two pack) but that doesn't look feasible or cost effective either (given you can get 2 filters for 14 bucks on Amazon with the rings)
    So it's probably a $50 (oil) pluse $7 (filter) mistake.
    Sure is awesome "saving money" doing it yourself!! :)
    Y'all commiserate...what are your most memorable "lessons learned" while working on your Tacoma?
    TnShooter likes this.
  2. Oct 27, 2024 at 5:34 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Put almost everything on backwards the first try. Most times I don't get past the first bolt/screw LOL
    Look at it this way. You sorta got a free undercarriage rust prevention for the winter. :D
  3. Oct 27, 2024 at 5:44 PM
    Bishop84
    Bishop84 Well-Known Member
    I'm a licensed mechanic and I didnt check a lawnmower I bought for its oil level.
    Bought 2 in one day :D
  4. Oct 27, 2024 at 5:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My oil drain pan is they type that has a plug.
    You remove the plug and the oil drains into the plan.
    I forgot to remove the plug, and all the oil drained out into the driveway.
    It was a mess. A BIG mess. I just glad it was a blacktop drive way.
    If it were concrete, it would have been worse.
    rocknbil and GrievousAngel[OP] like this.
