Just did front brakes and already squeaking..
Discussion in '1st Gen. Tacomas (1995-2004)' started by AZTacoSupreme, Apr 29, 2014.
  1. Apr 29, 2014 at 3:29 PM
    AZTacoSupreme
    AZTacoSupreme [OP] Well-Known Member
    Anthony
    Chandler, AZ
    2006 LS430/ 2004 Sequoia 4X4
    Brakes were squeaking when I bought the truck. Replaced the pads about 3 weeks ago, driver side was fine, but one pad on the passenger side was worn and thats where the wear indicator squeak came from. Long story short, decided to change both sides, and I used brake grease, what could be making them squeal all of a sudden again?
  2. Apr 29, 2014 at 3:32 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    did you turn the rotors (or replace them)?
  3. Apr 29, 2014 at 3:37 PM
    AZTacoSupreme
    Anthony
    Chandler, AZ
    Neither. The rotors looked fine
  4. Apr 29, 2014 at 3:41 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Sure it's not a dust guard dragging? Didn't muck up the pads when you out them in did you?
  5. Apr 29, 2014 at 3:45 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    "Looking" only tells you if there are cracks. You cant see a hundredth of an inch. Mic the rotors in a few spots and it's easy to tell if you have flat spots. Chances are you need to turn the rotors.
  6. Apr 29, 2014 at 3:48 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Always get them turned. Why not for 20bucks.
  7. Apr 29, 2014 at 3:52 PM
    AZTacoSupreme
    Anthony
    Chandler, AZ
    Turning the rotors could very well be the answer to my problem.. The truck has almost 140k on it and I highly doubt the rotors have ever been changed. thanks guys!
  8. Apr 29, 2014 at 3:55 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Both pads in a caliper should wear evenly. If only one of two pads is worn, that indicates a problem with the caliper. I would rebuild or replace it.
  9. Apr 29, 2014 at 3:55 PM
    mkatts
    mkatts Well-Known Member
    Joe
    Columbus, OH
    95 Reg cab 4x4 2.7L
    IMHO, rotors should be turned or replaced when replacing the brake pads.
    Helps to get the pads seated to the rotors and also breaks the glazing that is always there.
    Did you burnish in the new pads?
    Run it up to about 45min and lay on the brakes enough to slow down to 5mph as fast as possible without locking em up. Do not come to a stop.
    Should do that 2-3 times. Seats the pads and burns off and residue on the pad face.
    Did you orient the new pads in the same manner as the old pads in relation to where the sqeel indicator is located?
    It should be on the leading edge of the caliper.
    Did you buy metallic pads?
    If so, turning the rotors could fix a brake sqeel too.
  10. Apr 29, 2014 at 7:25 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Caliper might be sticking. That's the problem I have now. I bought brakes from NAPA and about 3 weeks later, they started squeaking. Just replaced them a month ago and they're already squeaking again and grinding.
  11. Apr 29, 2014 at 8:11 PM
    AZTacoSupreme
    Anthony
    Chandler, AZ
    Just sprayed some brake cleaner on the rotors and the squeak is gone. I also noticed the brake fluid was a bit dark, so I bled they system and put fresh fluid in. so hopefully that'll help my pads wear evenly and I won't run into that problem again.
