Just did full tune up and still rough idle???
Discussion in '1st Gen. Tacomas (1995-2004)' started by mj1168, Apr 21, 2011.
  1. Apr 21, 2011 at 6:42 PM
    mj1168
    mj1168 [OP] Member
    Ontario, Canada
    97 Tacoma 4x4 Reg Cab
    I just changed my plugs, wires and fuel filter using all Toyota parts. My truck is still idling rough only when it's in gear either at a light or stop sign. If i put in neutreal it runs fine??? It's a 97 Tacoma with a 2.7 litre, automatic. Just wondering if anyone knows what eles i can check for?? It runs fine when i'm driving at any speed, just runs rough when sitting at light and in gear??
    Any suggestions would help.
  2. Apr 22, 2011 at 8:48 AM
    medic2230
    Murph
    Bama! Roll Tide
    MAF sensor maybe? Had a 99 4 runner do that and that was the problem. It would stall at a light but run good other wise. It also ate some fuel when it was doing that.
    Murph
  3. Apr 23, 2011 at 6:20 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    x2 on the MAF, try removing it and cleaning it with electrical contact cleaner just be careful with it they are fragile. your engine might benefit from a good seafoaming as well. also is your check engine light on?
  4. Apr 23, 2011 at 8:12 PM
    B3AS7808
    B3AS7808 Well-Known Member
    San Diego, CA
    13 DCSB 4.0 4x4
    TRD S/C,URD 2.8 Stealth pulley, DTLT Headers,URD ypipe, URD rear O2 Sims, TRD catback, Powerstop rotors and pads, weathertech floor liners. RCD 4.5 lift. Nitto Trails 295/70R/17, KMC XD125's.
    Timing belt
  5. Apr 23, 2011 at 8:13 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    also clean your throttle body
  6. Apr 23, 2011 at 9:29 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    The 2.7 has a chain not a belt.
    I would definitely try cleaning the MAF sensor and throttle body and see if that helps.
  7. Apr 23, 2011 at 9:37 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    mine is the newer style 2.7, 2tr-fe. but mine idles a little rough too. always has. and it idles really rough after you disconnect the battery because that resets the computer and the truck has to learn your driving habbits again.
    what im getting at is have you disconnected your battery recently, and have u always noticed it rough idling or just recently noticed it?
  8. Apr 27, 2011 at 4:24 PM
    mj1168
    mj1168 [OP] Member
    Ontario, Canada
    My engine light just came on, so now i'll get it scanned to see what it is but i will also check the MAF while i'm at it. After putting fuel, the engine light came off and then came back on about an hour later...
    Thanks Guys
  9. Apr 27, 2011 at 4:41 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Well the CEL could be gas cap.
    But when I had my 02, the cure for my rough idle was cleaning the throttle body and also doing a SeaFoam cleaning....
    But it could also be a o2 sensor, bc I remember my o2/AFR sensor went bad and gave me a rough idle.....
    Good luck man!
  10. Sep 6, 2012 at 8:04 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
  11. Sep 6, 2012 at 9:08 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Seafoam it ,change oil and egr rubber part.
