Just dont get it - Tire pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cnasianfire, Feb 22, 2018.
  1. Feb 22, 2018 at 5:02 PM
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    I'm running e rated 245's (for now)not near as wide but only run about 30 in front and 25 in the rear empty if you drop the pressure they should ride and wear better :cheers:
  2. Feb 22, 2018 at 5:12 PM
    Cougars
    Cougars Well-Known Member
    The alternative is to air down your tires further for a better contact patch. However, when you load up the truck you should bump up the pressures to what BFG recommends or what those inflation tables say. This is important for highway use but not really important for offroad.
    su.b.rat likes this.
  3. Feb 22, 2018 at 5:16 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    I run 35 front and rear BFG KO2 E rated and all is good.
    How’s your alignment?Are your wheels balanced correctly to the tires front/rear?
  4. Feb 22, 2018 at 5:24 PM
    Cnasianfire
    Cnasianfire [OP] Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    I got an alignment about two weeks ago. But I did have someone today stop me and say that my passenger front looked like it was toed in. But the chalk test doesnt show that and I can't feel any thing wrong. Yes, the tires are balanced pretty well I think. Sorta hard to tell because my old muds were so bouncy (they never were balanced well). It is a bit bumpy,but I think that is just the truck being a truck.
  5. Feb 22, 2018 at 5:29 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Hankooks Dynapro ATMs 265/75/16 set at 35psi. cold all the way around and wearing straight across. The key to getting the pressure right means that tire should be cold for at least 2 hours. I like to check pressure in the morning for that's when they will be coolest. keep doing chalk test when you find the sweet spot write it down and keep them there.
    Good luck finding your sweet spot.
  6. Feb 22, 2018 at 5:32 PM
    Cnasianfire
    Charles
    Wilmington, NC
    Yeah, I am going to do 35 front, 33 rear (cold) tomorrow and see what it is like
  7. Feb 22, 2018 at 5:33 PM
    Tiedie
    David
    WFOY
    Firestone Lifetime Alignment. FTW:rockband:
    Crom likes this.
  8. Feb 23, 2018 at 1:06 AM
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    same I'm at 36
  9. Feb 23, 2018 at 3:21 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    It isn’t down to holding the weight. The pressure they told him would support over 9000 lbs of GVW.
    What they did was tell him the pressure that would get the new tires at the same same point on the load curve as the P stock tires at recommended inflation. That’s considered the best starting point to have the same ride quality and handling as stock when you switch tire sizes. But it is only a starting point really and for big changes in tire size or type you might adjust quite a bit from there.
    Always wise to check the load curves for your final pressure of course.
    Oh and thanks for the link, that is the most complete table I’ve seen so far, the others I have are missing a fair number of sizes.
    ChadsPride likes this.
  10. Feb 23, 2018 at 3:26 AM
    Cnasianfire
    Charles
    Wilmington, NC
    How do you figure the 40-45 psi in a 285/75/16 Erated tire can hold 9k lbs? Not disagreeing with you, just don't see that psi anywhere for that weight. I didn't know if you had a formula or something to arrive at that figure
  11. Feb 23, 2018 at 4:20 AM
    DVexile
    Ken
    GVW is distributed over the four wheels, though of course not necessarily evenly between the front and rear axles. From the table that was linked a LT285/75R16 handles a load of 2340 at 40 PSI and 2540 at 45 PSI. So just using the lower PSI they gave you 4*2340=9320 lbs.
    Similar story for stock TRD OR tires which at the door sticker inflation have a load of 2015 and 2115. Still well over the GVWR of 5500.
    So it really isn’t about the tires potentially being too under inflated for the weight. All the various recommended pressures in this thread provide load handling way beyond the GVW. The vehicle manufacturer determines what point on the load curve the tires should be inflated to based on a number of factors beyond just GVW. When you change sizes the recommendation is to inflate the new tire to the pressure that gives it the same load handling as the original size tires at their recommended inflation.
    It seems like BFG is telling you to inflate these well past the equivalent load point of the stock tire size. Seems like 35PSI at a load point of 2130 is the closest match to stock. So it seems like you finding them over inflated at 40/45 is to be expected. Likely 35 PSI is the correct starting point.
    Hawco636 and Pugga like this.
  12. Feb 23, 2018 at 4:29 AM
    DVexile
    Ken
    Oh hey - and I think I see why BFG screwed up. They didn’t account for the fact that the stock Tacoma tires are P on a light truck and thus the load curves are derated by 1.1. They used the standard P table and not the derated table when finding the stock load. If you make their same mistake you get 40/45 as they told you. If you do it correctly you get 35/35.
    Crom and Taco Addiction like this.
  13. Feb 23, 2018 at 4:30 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Damn, I wasn't thinking right. I was thinking that each tire was to hold the entire weight of the axle. Stupid me! That totally makes sense. Yeah, I am going to run them at 34front/32rear and see how they are.
  14. Feb 23, 2018 at 4:32 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Yeah, I don't think that they were accounting for the 1.1 either and I just learned about the 1.1 factor this week. Thanks again!
  15. Feb 23, 2018 at 4:46 AM
    #35
    evansdmax
    evansdmax Well-Known Member
    Evan
    Western NC
    2017 TRD OR BBP 6 SPEED MT
    I’m at 35 all around on my st maxx e rated.... any less and it starts to hurt your mileage in my testing
  16. Feb 23, 2018 at 4:46 AM
    #36
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    u smart! :cheers:
    Crom likes this.
  17. Feb 23, 2018 at 5:04 AM
    #37
    badger
    badger Well-Known Member
    07 SR5
    Where did you get this information? The larger the tire, the lower the pressure required to support a given weight. That is why a bicycle road tire is over 100psi, and a mountain bike tire might be 30. E rated tires do not require more pressure. E rated tires CAN hold more pressure, and therefore more weight. That is the only difference. What you are seeing is the proof.
    Trust your chalk test. Do it after a reasonable drive to get the tires to a typical temperature. Once you get it right, check the pressure cold in the morning and use that as your reference. Add a few pounds for extended highway or loaded driving.
    My truck weighs about 5,600 pounds and my 255/85-16 E tires are set at 32 front and 30 rear. One more thing. Tire gauges are all cheap. I've got three different dial type gauges that all read different numbers. The spread is 5 pounds!. I only use quality liquid filled industrial pressure gauges like Wika for my tires, and even they only claim 2% accuracy. Don't get hung up on a number. Get a good gauge, trust the chalk, and use the same gauge at the same temperature every time you check if possible.
    a400ryan and LarryDangerfield like this.
  18. Feb 23, 2018 at 5:20 AM
    #38
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    E rated 265/65/17 KO2's for me. Running 32psi all around. If I did it again I'd probably go C-Rated, but at least E-rated tires should last a longggggg time on these trucks.
  19. Feb 23, 2018 at 6:11 AM
    #39
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    My tire guy put in 45 on my BFG's to properly set the bead. I'm running 35 in each now.
    Did the chalk test and all is good. It's a good idea to drive in a mild serpentine pattern
    when doing the chalk test..btw...not just straight.
    jv_74 likes this.
  20. Feb 23, 2018 at 7:13 AM
    #40
    badger
    07 SR5
    I haven't noticed a huge difference in that. The rubber is still the same hardness.
