Just dropped the hammer on complete lift kit
Discussion in 'Suspension' started by Nicky Lam, Dec 19, 2012.
  1. Dec 19, 2012 at 6:24 PM
    Nicky Lam
    Nicky Lam [OP] Dog Face Soldier
    Nick
    Somers Point/Mount Laurel, NJ
    2013 Blk DC Off Road
    NOV12: Front windows tinted to matched to rear windows 12NOV12: Fog light anytime mod DEC12: OME 885 w/ 25912 top plate spacers for full 3" lift OME Trim packer Dakar Rear 5 Leaf Packs Total Chaos Uniball Upper Control Arms 2.5° Degree Rear Axle Shims 18JAN13: 17x9 Fuel Kranks 17x9 4.5 BS -12mm Offset 285-70-17 Goodyear Duratracs 23JAN13: OME Carrier Bearing Drop Kit 05FEB13 TRD Aluminum Skid Plate 05FEB13 TRD Stainless Steel Cat Back Exhaust (2012 modified to fit 2013) Auto Mate 5304A (Viper 5704 Equivalent) 2-Way Alarm/Remote Start with Smart Start for iPhone De-Badged All Emblems 30JUL13 Go Rhino Stainless Steel Dominator II Side Steps *not yet installed: Stainless Steel Extended Rear Brake Lines
    just ordered OME full 3" lift with 885 coils and dakars out back. 2.5 degree axle shims and stainless steel extended rear brake lines. ($1450+)
    Total Chaos upper control arms from MetalTech (free shipping, so nice) $620
    1 paycheck, gone. just like that
    just a little excited, so i had to throw a post up. :p
    wheels and tires next pay check?
  2. Dec 19, 2012 at 6:28 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Did you get the 5mm OME trim packer and the OME CB drop ?
  3. Dec 19, 2012 at 6:31 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  4. Dec 19, 2012 at 6:31 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    woo! I'm jealous
  5. Dec 19, 2012 at 6:39 PM
    Nicky Lam
    Nick
    negative, i figure i can make my own CB drop if i need to.
    5mm OME trim packer? i dont know.... i ordered the front shocks/coils to be fully assembled, i wanted to take the stock ones out, put the new ones in. is it needed? can i add to it later if i have the dreaded lean? does it go on top of the hat? or between the coil and hat? i hate compressing springs
  6. Dec 19, 2012 at 6:43 PM
    MarkM
    MarkM Well-Known Member
    Mark
    Indiana
    2017 TRD Pro / BRO
    I just went through this exact same thing. Wheels and tires installed tomorrow! Tacomadicted
  7. Dec 19, 2012 at 7:14 PM
    OZ-T
    Peter North
    British Columbia
    The trim packer goes on the drivers side shock below the coil
    It needs to go on at time of assembly
    It only works with OME shocks
  8. Dec 20, 2012 at 3:16 PM
    Nicky Lam
    Nick
    cool thanks. it's only like a 12 dollar part. I plan to install the lift, wait about a month so the suspension settles, then decide if ill need it. I'll get it aligned then with new wheels and tires
  9. Dec 20, 2012 at 3:19 PM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    its a cheap part, but the trim packer will require you to remove the spring, so if you dont want to mess with a spring compressor in a month, have it installed now.
  10. Dec 20, 2012 at 3:40 PM
    OZ-T
    Peter North
    British Columbia
    Bad idea
  11. Dec 20, 2012 at 3:46 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Call them and have them put the spacer in for you. You WILL have the lean. No getting around it. Also why not get the $12 cb spacer at he same time
  12. Dec 20, 2012 at 4:08 PM
    Nicky Lam
    Nick
    Too late, already assembled and shipped.
    CB drop kit, I can make myself. If I even need it.
    I'm competent with suspension and a wrench to install the trim paced, if there is a lean at all.
    Won't know till I install will we? Only hope for the best
  13. Dec 20, 2012 at 4:12 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    X2 i just installed 885s with the trim packer and have almost 1/2" of taco lean. If he ordered the shocks and springs pre assembled they should know to put in the trim packer right?
  14. Dec 20, 2012 at 4:22 PM
    Nicky Lam
    Nick
    Doh!:frusty:
    Lets hope they were feeling festive, and threw the trim packer on there
  15. Dec 20, 2012 at 4:24 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    What about ordering a 1/4 top plate spacer?
  16. Dec 20, 2012 at 4:32 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    You will probably need an alignment right away, the lift will most likely mess your alignment up pretty bad. are your dakars coming with rear bushings?
  17. Dec 20, 2012 at 5:10 PM
    Nicky Lam
    Nick
    No idea if the dakars come with new bushings or not, I would assume so since they were $470++ option over aal or block from toytec. my truck only has 2000 miles on it, if it didn't come with new bushings. Is it possible to use the stock ones?
    I ordered the 885 with the top plate spacer option to make it a full 3" inch lift I don't think I want to stack another spacer on top of that. IF I need the trim packer ill order it.
    Also this truck, is not my daily driver, I have another vehicle (car) which I drive to and from work. I would merely, drive it to where I'm installing it, install, drive it back, let it sit to settle for a few weeks. At most I'd drive it around the block a couple times a week to help settle it further. Then when it's all said and done, see if I need the trim packer. Some members on here say they have no lean with this same setup.
  18. Dec 20, 2012 at 5:16 PM
    Nicky Lam
    Nick
    Correct me if I'm wrong but don't the new dakars have a driver and passenger side that you're supposed to install to that compensates for the lean as well?
  19. Dec 20, 2012 at 5:16 PM
    Mitch
    Mitch
    Spokane, WA
    You do plan on getting it aligned after you install it though right? If you have a firestone in your area they have a lifetime alignment for 160 bucks. Totally worth it. After installing my lift I had my truck aligned twice in a week because I was leveling out my front end.
  20. Dec 20, 2012 at 5:22 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Oh ok, i didn't realize you already had the top plate spacers. You could do 1/4 on the passengers side and 1/2 on the drivers side. The thing about installing the trim packer is you have to completely disassemble the coil-over. You will need a spring compressor, if you are taking it apart it kind of defeats the purpose of having them pre assembled. For the dakars i think it depends where you ordered from, im guessing toytec? I ordered from downsouth, they do not come with rear bushing from OME so unless you ordered from a vendor who adds them then you might need to press new bushings in. I bought mine from toyota because i have heard removing the old ones is a pain in the ass. I am sure you will figure everything out, we are just trying to help you be prepared.
    Edit: toytec does include new rear bushings for the dakars
