Just enuf lift for 285's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Goosedog, Jan 8, 2017.
  1. Jan 8, 2017 at 12:14 PM
    Goosedog
    Goosedog [OP] Well-Known Member
    I'm sure you guys get tired of redundant suspension questions but my search remains not entirely answered. Most have probably figured out what works thru trial and error so I hope to gain from their knowledge before spending money in the wrong direction.
    My plan, and research has indicated this possible, is to lift my truck enough for 285/70/16's with 1.5in off-set rims, Bilstiens 5100's on highest setting, diff drop, plus 2 leaf AAL's in back leaving the overloads in as well.
    The main controversy I have heard is both for and against UCA's being necessary with an under 3 inch lift. Is this an install, then see if it aligns kind of situation? Thanks for your responses.
  2. Jan 8, 2017 at 12:16 PM
    Large
    Large Red
    For a 285/70/16 that will be perfect, I had almost the same lift and zero rub anywhere
    if you mean 285/75/16, that's another story ..
    edit: with just a 2.5" front lift you can still get your alignment in spec, or close enough to not worry about it
  3. Jan 8, 2017 at 12:21 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Enough
    Through
  4. Jan 8, 2017 at 12:24 PM
    Goosedog
    Yeah that was a typo on the 70 vs 75. What tire did you run that was 285/70?
  5. Jan 8, 2017 at 12:25 PM
    Goosedog
    Sorry, short hand ya know. (er, you know)
  6. Jan 8, 2017 at 12:28 PM
    Large
    Large Red
    It was nitto trail grapplers, the 285/75 isn't bad to clear. You could just do the lift, install the tires and it will rub on the cab mount and maybe the pinch weld in reverse. If you plan to wheel the truck then you bust out the hammer, and do a cab mount chop.
    don't mind the trolls, they are everywhere and hardly contribute anything helpful
    Naveronski likes this.
  7. Jan 8, 2017 at 12:39 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Until*
    Rigid*
  8. Jan 8, 2017 at 12:43 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Skip the diff drop. Not needed on a 2nd gen.
  9. Jan 8, 2017 at 12:47 PM
    Naveronski
    Fort Worth
    T4RFTMFW[QUOTED] likes this.
  10. Jan 8, 2017 at 12:48 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    So many sensitive people, what to do? Did it hurt your feelings correcting the spelling. Wah.
  11. Jan 8, 2017 at 12:53 PM
    Clearwater Bill
    Billy
    Largo Florida
    Recommend selecting proper springs to gain the lift you want, and setting the shocks to 0.
    Preload to achieve lift reduces travel, risks coil bind, works the shock harder.
    Call Marie @HeadStrong Off-Road and tell her what your goals. She'll point you to the right spring.
