Just finished led gauge swap and..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Burgess65, Jan 9, 2013.
  1. Jan 9, 2013 at 7:55 PM
    Burgess65
    Burgess65 [OP] Active Member
    I can't remember where all the plugs go for the fog lights and dimmer wheel. My truck is an 08 prerunner if that helps any. Anyway, At this point I see four different plugs. The blue one goes to the dimmer wheel, the all black plug goes to the fog light switch. But what about the green plug and piano board like colored plug? I can't seem to find places for those two. Any information pertaining to this would be greatly appreciated!
  2. Jan 9, 2013 at 7:58 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    The fog can only be plugged into the left most 4 pin plug
    If you have a stock locker, it's the 5 pin plug...
    These trucks come prewired for other stuff that you probably don't have
    To test the fogs just plug it in and turn them on.
  3. Jan 9, 2013 at 8:04 PM
    Burgess65
    Ok cool. They work. Along with my dimmer switch. I was hoping there was some magical fix that I was missing as my v2w led bar from flyzeyedesigns isn't lighting up anymore. Nothing that I have done should have caused that though as I only swapped the led's in my gauge cluster. Ill probably have to get in touch with them and see if they know what's going on..
  4. Jan 9, 2013 at 8:05 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Where did you connect those lights too? The flyzeyesdesigns?
  5. Jan 9, 2013 at 8:06 PM
    Burgess65
    I should probably quit posting on this board. I assume things are wrong when it's strictly user related. Appreciate the help Jerez.
  6. Jan 9, 2013 at 8:07 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    No prob, alot of people are here to help man. So ask away :thumbsup:
  7. Jan 9, 2013 at 8:07 PM
    Burgess65
    The bar got set back to completely dim. As a result, nothing lit up.
