Just finished spark plug change...they were...
Discussion in 'Technical Chat' started by Masada, Sep 27, 2009.
  1. Sep 27, 2009 at 3:54 PM
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Gapped wrong from the factory. I checked the GAP on all of them 3 Denso's and 3 NGK's all from 46 to 55 GAP. What the heck?
    Anyone else have a similar issue?
    Just wanted to say a specail thanks to Chris4x4 for the write up, made it easy to do. Thanks man, in this short amount of time on this sight I can see you are a very helpful person :)
  2. Sep 27, 2009 at 3:59 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    subscribed
  3. Sep 27, 2009 at 4:01 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I am interested as well i'll have to change mine one day.
  4. Sep 27, 2009 at 4:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I dont think they are gapped wrong from the factory. I have pulled the plugs on a new Tacoma :spy: and the plugs were all in the .040 range. At 30K miles, it seems the NGK's are closer to .055 while the Densos are around .044 to .048. When changing the plugs, this is why I recomend useing all Denso plugs, as they seem to hold their gap for a longer period.
    And thank you for the kind words. :)
  5. Sep 27, 2009 at 4:37 PM
    Masada
    Taylor
    Laveen, AZ
    I don't know man, I pulled them out and then checked the gap just for fun and they were all over gapped. Maybe it was because they weren't changed at 30K? The truck has just under 40K now, maybe next year I will change them out to the Denso, but the dealership parts store wasn't open today :(.
    All I know is it freaked my out...
  6. Sep 27, 2009 at 4:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you had NGk's on one side, and Denso plugs on the other, I would say they havent been changed. You need to change them at 30K.
  7. Sep 27, 2009 at 4:46 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Do you really think they were over-gapped from the factory or maybe just WORN? :rolleyes: With the mileage you mentioned I'm thinking they just "opened" with normal wear and tear. I'm assuming plugs do not stay at the recommended gap for life, hence the reason for "changing" them out....
    If I'm thinking incorrectly....I am willing to be set straight.
  8. Sep 28, 2009 at 10:28 AM
    Masada
    Taylor
    Laveen, AZ
    It is as you stated, they had not been changed yet. I just got the truck on Tuesday night from the dealer as a used certified Toyota, so I didn't know if they changed the plugs or not. My next thing is to look at the throttle body and see if it needs a good scrub down, the truck is idling a little ruff after it warms up.
  9. Sep 28, 2009 at 10:49 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    At least your certified had sensbile plugs in it. My "certified" had effin POS autolites in it.
  10. Sep 28, 2009 at 11:20 AM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '16 4Runner Trail Barcelona Red
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    Do they come from the factory with two different brands? Has anyone tried those E3 or whatever their called?
  11. Sep 28, 2009 at 11:28 AM
    Masada
    Taylor
    Laveen, AZ
    Sensible or not they should have been changed 10k miles ago...oh well, my truck has found a good new home...
  12. Sep 28, 2009 at 12:29 PM
    bubba
    bubba Member
    Dave
    Cleveland Ohio
    TRD Sport Package
    I know this is a stupid question but why would they use twp different spark plugs??
    and Why are they not using an Iridium Plug instead of standard on the V-6
  13. Sep 28, 2009 at 1:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The E-3's are just hype. Use OEM.
    Cost. The engine ignition is designed for useing a nickle/copper plug. You cant just throw any plug in, and expect results. Plugs have different temp ranges, resistance, etc. Best to use what the manual says, as I have found the other plugs actually give reduced performance.
  14. Sep 28, 2009 at 1:15 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Read, heed & embrace the reality of what he speaketh :bowdown:
  15. Sep 28, 2009 at 1:58 PM
    TicTacOma
    Columbia,SC
    When that man speaks, bushes catch fire....and I ain't talkin' red heads.
  16. Sep 28, 2009 at 3:46 PM
    Masada
    Taylor
    Laveen, AZ
    Ok the man love is getting a little thick in here...lol :)
  17. Sep 28, 2009 at 3:55 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I don't think any one has discovered why Toyota does this.
    X2 on the man love.
  18. Sep 28, 2009 at 4:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My Friends and I have an idea. Not sure if its valid, and I cant get ahold of anyone to varify, or dipute. Anyway....The resistance from the driver side to the passenger side is slightly different. Not much, but a little. We have figured that Toyota is useing a plug requireing less resistance to reliably fire, and/or a less expensive plug.....Even at a $0.05 difference ofver a few hundred thousand vehicles, is a good savings. Just my friends and my idea.
  19. Sep 28, 2009 at 4:16 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Is this only found on the 4.0? I think it was found on the 3.4 also but I can't remember.:eek:
  20. Sep 28, 2009 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes....and the 3.0, and a friend said he found the same thing on a Camry V6, but he never sent pics, so I cant be sure.
