Just fixed driveline vibration!!!For free!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hvacbmac, Apr 21, 2011.
  1. Apr 21, 2011 at 9:59 PM
    hvacbmac
    hvacbmac [OP] Member
    northwest
    '07 SR5 4x4
    Toytech 2.5" lift adjustable front, TSB rear springs, Underdog racing shifter
    After lifting my truck about 2" in the rear (over stock non-TSB) and adding 2.5" in the front, I had a bad driveline vibration. A shudder off the line and a varying mild to bad vibration 53-61 mph and again around 70 mph. I installed the 3 degree shims with lift in the rear, but had the above vibrations. I then tried dropping the carrier bearing 1/2", it didn't change much of anything. Then I removed the rear 3 degree shims. Vibration stayed but I got a low humm from the extreme u-joint angles at almost all speeds. After some thinking I picked up a degree finder to check actual angles of shafts and joints. I found the trans @ 1.7 deg. down, front shaft @ 8.7 deg down, rear shaft @ 8.7 deg down and pinion @ 4.8 deg. up with carrier shimmed down and no rear shims. After checking things over I realized Toyota engineers failed driveline 101. The ideal ujiont angle is less than 3 deg. so take the mating driveline angles and subtract to figure ujoint angle. The trans was much more even without dropping carrier and is'nt affected by lift.So long story short visit spicer site http://www2.dana.com/pdf/J3311-1-DSSP.pdf. After some figuring I got mine closer to ideal without buying a thing, I found that the ring around the carrier bearing isn't concentric and if rotated 180 deg. it raises the carrier about 1/2". So I flipped the carrier bearing ditched the carrier spacer shims that I got with lift and have the rear 3 deg. shims on rear. Now pinion angle is close to first shaft angle per Dana/Spicer and all ujoint angles are very close or less than 3 deg. I still need to fab a trans. mount to lower the trans. a hair but all vibrations are gone. For any of you having a vibration problem give this a try who knows the select few that haven't had a problem may have had the bearing installed this way accidentally from the factory!
    Johnjaz, jmdwifi, Kolunatic and 3 others like this.
  2. Apr 22, 2011 at 1:37 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Interesting, like to see what others have to say here. May just have to try it.
    Thanks for the info.
  3. Apr 22, 2011 at 2:18 AM
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
  4. Apr 22, 2011 at 4:22 AM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
  5. Apr 22, 2011 at 4:24 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Subbed.....even tho i have none of dem vibrations
  6. Apr 22, 2011 at 4:28 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    subbed for future reference
  7. Apr 22, 2011 at 4:58 AM
    blkbelt42
    blkbelt42 Well-Known Member
    2016 AT Black DCSB 4x4 TRD Sport Loaded!
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub in Full length Ported Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Start TRD Pro Grille ECT always-on mod by MESO OV-Tuned ROAV Dash Cam
    is this happening only on certain years or??
  8. Apr 22, 2011 at 6:19 AM
    antatich
    antatich Well-Known Member
    Tony
    Bremen, Indiana
    2011 DC Silver Tacoma
    Ready lift SST w/ 2 inch blocks, 33x12.50R17 Dick Cepek Mud Country Tires, 1.25" Billet Spacers, Tinted Windows, DDM tuning HID Headlights and Foglights, N-Fab Side Bars, N-Fab Light Bar, 4 Hella 500FF, JL Amp, 12" shallow Mount Sub
    Finally somebody smarter than me has figured this out. I have all the same problems as you do with the same style lift and tried everything. Where did you get the shims?
  9. Apr 22, 2011 at 11:59 AM
    crf69
    Ohio
    ummm yeah
    too broad to answer
  10. Apr 22, 2011 at 10:29 PM
    hvacbmac
    northwest
    '07 SR5 4x4
    I got the 3 deg. shims from toytech.
  11. Apr 22, 2011 at 10:32 PM
    hvacbmac
    northwest
    '07 SR5 4x4
    It seems to happen on a select bunch of the 2nd Gen. double cabs mostly, not aware of any reasons why some are affected more than others.
  12. Apr 22, 2011 at 10:44 PM
    hvacbmac
    northwest
    '07 SR5 4x4
    Just wanted to get a little bit deeper into the double shaft dana/spicer specs. On my double cab taco ideally the trans mount still should be lower than what I have done so far and after doing so the carrier bearing should be lowered slightly to make the angles all within dana/spicer specs. but for now I'm happy without major mods. And by the way I have had and loved many Toyotas, and have taken their share of abuse. But I thought it funny as i was staring the spicer sticker on the driveshaft in the eye that toyota can have a company manufacture a shaft for them but not get the angles to specs.!!! Many hours of their time and ours have been spent trying to cure vibration problems on these trucks and this seems to be only one of the causes depending on the truck.
  13. Apr 23, 2011 at 5:45 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Interesting. And this was with a 2" lift in the rear and 2.5" lift in front?
    You raised the carrier bearing (by rotating it 180) and used the 3 degree shims in the rear... ...interesting.
  14. Apr 23, 2011 at 7:52 PM
    nighthawk87
    nighthawk87 Well-Known Member
    Good job man. If I take the angles of mine, would be able to tell me what to do.
  15. Apr 23, 2011 at 9:14 PM
    GeoTaco1
    GeoTaco1 Well-Known Member
    Geo
    11 Tacoma TRD Off Road
    NEW Toyo TIRES Bed Cage to hold 120 LBS of sand and fishing rod holder, window air deflectors, Bug Deflector, & finally Avid Light Bar and step rails....
  16. Apr 23, 2011 at 9:32 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
  17. Apr 23, 2011 at 9:37 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    <subbed for reference> Thanks for all the 'foot work' you put into this!
  18. Apr 23, 2011 at 10:38 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    huh.... im ganna have to try this sometime.... I have a annoying vibe/shudder around 45-50mph... Its not that bad, but it can be annoying.
  19. Apr 23, 2011 at 11:50 PM
    hvacbmac
    northwest
    '07 SR5 4x4
    Yep I have the rear spring TSB wich raises the rear a little over stock plus the rear add-a-leaf for the lift. Just got back home from a trip down I-5 and hit anywhere form 0-78 mph no driveline shake except for the slight shudder @ 0-7 mph that I need to work on w/ trans mount. Long road trips will be much better, hope this solves a few of your guys' problems!
  20. Apr 27, 2011 at 8:49 PM
    ShaneHD
    ShaneHD Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
    Question for you. Did this noise occur above 45mph and would go away almost instantly after letting off the gas?
