Just found out that my driver side is 1" lower front suspention 2010 TRD ! Why?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moulin6801, Aug 26, 2010.
  1. Aug 26, 2010 at 10:37 PM
    moulin6801
    moulin6801 [OP] Well-Known Member
    Hey guys, I was taking some measurements of the stock suspension of my 2010 TRD Sport double cab, 3 leaf springs in the back, when I realize that my driver side is sagging already. It is actually 1" shorter than the passenger side. Measuring from floor to side fender area....
    This is truck has only 3000 miles and I am 220lbs. I think it is too soon for that, or are all of them like that???
    If you can, measure yours and see if you also have this 1" difference.!!
    Thanks
    David
    PS: From ground to truck, front tires,34" and 35" on driver side.
  2. Aug 26, 2010 at 10:38 PM
    moulin6801
    By the way, don't say the obvious.... my fat ass... :) I want another reason !! :)
  3. Aug 26, 2010 at 10:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    battery, fuel tank, and driver all on the same side. Its normal
  4. Aug 26, 2010 at 10:39 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    "taco lean" did you by chance have a full tank of gas when you measured?
  5. Aug 26, 2010 at 10:45 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    a full 21gallon tank will tend to do that :)
  6. Aug 26, 2010 at 10:48 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Taco lean. Some aftermarket lifts/level kits come with 1 extra 1/4"+ spacer just to add to the drivers side to level it out.
    Totally normal.
  7. Aug 26, 2010 at 10:49 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Is that why my truck seems to corner better turning left? You guys almost have me convinced to mod my suspension!
  8. Aug 27, 2010 at 12:41 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    Nope I think it's his Fat Ass! my truck doesn't lean!
    J/K! I actually have my C/O's adjusted so my truck sits level.
    Toytec sells spacers that can correct the lean. The Toytec spacer is 1/2" and should do the trick. But you actually need a 5/8" coil spacer to lift it 1", but the 1/2" spacer will be close!
  9. Aug 27, 2010 at 7:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Are you on a level surface when you are measuring?
  10. Aug 27, 2010 at 2:11 PM
    moulin6801
    You guys know your staff ! Yes I had a full tank of gas!
    That alone weigh around 120lbs!!!
    Thanks guys!!! I fell better, now I just need to loose 20 lbs
  11. Aug 27, 2010 at 2:15 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    21x8=168 plus your 220 = taco lean!
  12. Aug 27, 2010 at 2:16 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Or buy a right-hand drive Hilux. Those things have all the goodies and are balanced properly.
  13. Aug 27, 2010 at 2:16 PM
    PLC721
    Patrick
    Chandler, Az
    and post pics of it because i love them
  14. Aug 27, 2010 at 2:30 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Dammit..............that was my 1st thought!.................
  15. Aug 27, 2010 at 2:33 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    good luck trying to get that thing to pass emissions test...that's why they don't offer it here in the US...
    also the same reason why its hard to get an R34 Skyline, Silvia, and other bad @ss cars registered and insured in the US...the government doesn't want us to drive faster cars and better built cars that will take on and blow cop cars/helicopters away...lol bastards...you gotta know the loop holes in the system and the right people to pay off to get them here...boo the man...
