Just got a laugh from the dealership.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ClemsonMGM, Nov 6, 2015.
  1. Nov 6, 2015 at 6:24 AM
    ClemsonMGM
    ClemsonMGM [OP] Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    So as I wait for my driveshaft to be replaced as a result of a tsb, I noticed I cheap pro comp spacer lift around the parts counter... Halfway joking I asked what it fits and how much it was. It fit a 2nd gen Tacoma and it was $325 for spacers and blocks... Then halfway joking again I asked was that installed? No. It was $325 and this is the good part... 6 hours labor!!! Plus alignment. Holy crap I could buy a full ome setup for what they want for this crap...
    Ok rant over.
  2. Nov 6, 2015 at 6:32 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Along the lines of silly - check out the opening post in this thread:
  3. Nov 6, 2015 at 7:05 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    The reason why they sell 'em.....is because people will BUY 'em.
    I do some minor repairs and installs on trucks from around my home area. (To supplement income for my 4wd addiction) Like the dealer, I have to charge for my time, or else it isn't worth doing....With parts the dealer sells, or if I was to supply parts, as a "vendor" you assume some liability and risk. You need to be paid for that. I do NOT sell parts. I'll install a kit that you carry in the door to me.
    Without knowing where your dealer gets his "lift kit", there's no way of knowing how much they pay for them. I have seen a few "name brand" spacer lift kits sell in the $250+ range. The simple "ebay kits" sell for $75 to $100 AND WILL DO ANYTHING THE MORE EXPENSIVE SPACER LIFTS WILL.....
    So...conceivably, they're making $75 above cost on the kit. Not unreasonable. 6 hours labor to install with the availability of a lift, adequate tools, help when you need a second set of hands, etc....is a lot of time. But, I've had installs that don't go well, and I WISHED I could have done them in 6 hours. I've installed essentially the same kit in less than 4 hours with a floor jack, a handful of tools, and laying on the driveway. I've spend 2 days crawling around on one install.
    So. It's not out of the realm of believability that a simple spacer lift installed would go north of a grand,....Just imagine how much it would cost to have that same dealer install high end lift kits...?
    All of this falls back to one theory I have. "If you can't do the work yourself, either don't plan on modifying a 4wd, OR, get a good job where you can afford to pay someone qualified about 2 or 3 times what it SHOULD cost to do the work."
  4. Nov 6, 2015 at 7:07 AM
    Jazz1one
    Jazz1one It is what it is
    Calgary AB
    2015 MGM DCLB sport premium
    SCS ray 10s. 315/75/16 Yokohama G003. Elka 2.5 dc w/remote resi. SPC uppers. Dobinson heavy leafs. Timbren bumps. Spindle gussets. Cab mount relocate. TRD catback. Toyota trifold tonneau. Full spare in bed. Hood deflector, side visors. Danger Customs Front/rear high clearance bumpers and full skids. 2 way remote start. Safari snorkel. Front 30% tint. Bed step. Anzo LED head lights. Weather tech mats. AllPro HD sliders linexed. 10k smitty x20 synthetic. Factor55 flatlink. Linexed bushwhackers. Rigid industries bumper pods. Ridged industries DSS ditch lights. Diode Dynamics amber pods. Prinsu roof rack. 42” Caliraised Amber single row. Switch Pros in sunglass holder. Custom Bed rail mounts for recovery gear.Northstar AGM battery. 4.88 nitro gears. Front and rear ARB lockers. ARB air compressor in bed cubby using expedition essentials mount.
    I had the dealer put in that pro comp lift when I ordered the truck new. Cost $1000..less than what the ome setup woulda cost.. But more importantly I maintained the full warranty because it's all done through the dealer. Went wheelin twice right after I got the truck. That lift is good enough for what I do :)
  5. Nov 6, 2015 at 7:12 AM
    ClemsonMGM
    Workin the pole!
    12 Ram 2500
    I just know MOST of the time it isn't gonna be a 6 hour job. Besides I don't want spacers anyway. For the same money I can do 5100s.
  6. Nov 6, 2015 at 8:01 AM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    It's the same up here in Canada. Both the dealerships and auto supply chain offer up spacer lifts and sell as a quality lift. Some don't get into coilover lifts and others do but charge an arm and a leg to do it. Best bet is to get what you want, buy a buddy some pizza and beer and do the install yourself.
    Jazz1one likes this.
  7. Nov 6, 2015 at 8:08 AM
    Jazz1one
    Calgary AB
    ^Agree. I also shopped around after the fact.. $1000 is the standard rate for this spacer lift. Cheapest I found was $940
