Just got a Tacoma, think engine is seized
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikeZ, Aug 17, 2014.
  1. Sep 25, 2014 at 7:49 PM
    #61
    MikeZ
    MikeZ [OP] Well-Known Member
    Just put a deposit on a motor with 102k on it for $700. It comes with a 90 day warranty as well. I am definitely glad I waited and got a motor with 167k less miles for $200 more. They are going to have it pulled by tomorrow or Saturday, told them I had to have it by this weekend.
    Found 3 good sites in my search
    - Row52.com which has a listed vehicles at salvage yards
    - hollanderparts.com is good for finding for sale parts
    - MyPartShop.com is seems to be a subsidary of Hollander but is where I found my engine, wasn't on the other site for some reason.
  2. Sep 26, 2014 at 8:01 AM
    #62
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    If you know a broker, copart.com is a good site to find salvage trucks for cheap.
  3. Sep 29, 2014 at 4:54 PM
    #63
    MikeZ
    Got the swap finished today aaaaaand the starter actuator doesn't engage. It's newer and still under warranty and the guy I got it from said I can use his number to get it replaced.
    Will do that tomorrow and hopefully I will be driving a Tacoma tomorrow.
    Side note: the tranny fluid was pretty brown. Usually tranny fluid is red. Do you guys think it needs changed then?
  4. Sep 30, 2014 at 3:16 PM
    #64
    MikeZ
    She runs! Started up pretty easily and had some ugly knocking at first but it went away in 5 seconds or so. Everything seems to be doing OK but I have a few problems.
    - Brake light in dash is on for some reason.
    - Tire has a broken belt so I get hell of a vibration, easy fix as it needed new tires anyways.
    - Tranny is leaking fluid. There is a line that is leaking by the exhaust that is hard to get a wrench on. Will have to try tightening it when the pipe is cooled off.
  5. Sep 30, 2014 at 5:06 PM
    #65
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Sounds like success
  6. Oct 3, 2014 at 1:04 PM
    #66
    MikeZ
    Having trouble fixing this leak. It is in a spot I can not get a wrench on very well. How do you guys think I should go about fixing it. I think it is one of the tranny cooler lines.
