Just got a used 2007 Tacoma 4cyl, 5speed, 4x4 - How did I do? Here's what I have planned for it!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bbinSF, Mar 26, 2024.
  1. Mar 26, 2024 at 11:28 AM
    bbinSF
    bbinSF [OP] Well-Known Member
    Hi,
    On Saturday I purchased this Tacoma. It met most of my requirements except its rather high mileage (217k), but figured I'd take a chance with it.
    It has a lift, aftermarket intake, and some decent tires. I'm planning on using it for "farm" work and occasional off road camping trips.
    Looks like I got a 2" block lift in the back, which I understand to be not so good.
    Can anyone tell me more about this UCAs?
    I'm planning on doing the fender washer fix for this door catch failure.
    I paid $11.9k
    I'm really curious about the lift and the quality of the components there. If anyone can report back, I'd appreciate it. (I know its subjective!)
    Here's what I have planned next:
    1. Replace all gear fluid with 75W-90 Synthetic, Rear Diff, Front Diff, Transfer Case, manual transmission.
    2. Put on a Valvomax quick drain plug and do an oil change and oil filter change.
    3. See if I can eliminate or minimize the side to size clutch pedal movement
    4. Coolant flush, PS fluid flush, Brake and Clutch fluid flush.
    5. clean and oil the volant cold air intake filter.
    Baxter White and 69 Jim like this.
  2. Mar 26, 2024 at 11:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think you did beautifully. Congrats and welcome to TW!
  3. Mar 26, 2024 at 11:34 AM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Looks pretty good, how’s the frame? Start spraying the front diff plugs now and get a good 10mm hex sock to break them loose. Hopefully the drain plug doesn’t strip.
  4. Mar 26, 2024 at 11:35 AM
    AvalonTaco
    AvalonTaco Falken Sales Rep.
    Joe
    Cabin in the woods
    2019 Super White DCSB OR
    Working on a lien delete for my title…..
    I'll give you $12,100 as she sits!! Seriously, that seems like a great deal, especially in today's world.
    bbinSF[OP] likes this.
  5. Mar 26, 2024 at 11:41 AM
    Richard009
    Richard009 Active Member
    09 Access Cab manual V6
    Can't wait to start!
    Looks a lot better than the 2009 I bought 3 years ago, so great find and welcome to TW!
    Block lifts on the front struts are bad, I think blocks on the rear are OK just watch for axle wrap.
    bbinSF[OP] and Steves104x4 like this.
  6. Mar 26, 2024 at 11:44 AM
    bbinSF
    Oh man, really appreciate the positive comments. The mileage really had me bummed out, but I've been shopping for awhile. Frame is all good. Been a California and Nevada car its whole life.
    I'm going to run it off road as is! See what breaks!
    I hear the rear block lift is not so good, any recommended better products to achieve a 2" lift in the back?
    Steves104x4 likes this.
  7. Mar 26, 2024 at 11:48 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    With the truck idling, is the tach needle steady or bounce a little bit? If so and if it hasn’t already been done, replace the valve cover but more importantly the spark plug tube gaskets… like tonight.
  8. Mar 26, 2024 at 11:53 AM
    bbinSF
    The tach is steady at idle.
    Can you tell me more about this valve cover and spark plug tube gaskets please? is there a sticky? What's the issue?
    Also sitting overnight in my driveway, not a drip. I noticed some evidence of oil at the transmission. I'll investigate and report back after I am under there poking around.
    Good idea on the PB blaster, I'll get on that before the day of the flush.
    Thanks for the welcome all!
  9. Mar 26, 2024 at 1:18 PM
    Agoldxj
    James
    Central Pa
    2009 SWB AC
    Start now, do it daily and tap it a few times before you break it loose.
  10. Mar 26, 2024 at 9:39 PM
    bbinSF
    Just got 'em PB blasted and ordered my first torque wrench after wrenching on cars for like 20 years, lol.
    Just pulled the relevant repairs from the carfax:
    Front Brakes, rotors, fluid flush, 119,775
    Differential Fluid Flush 123,469
    Valve Cover gasket 214,874
    Rear Leaf Springs replaced 186,417
    Unknown Transmission Service at 200,808 miles
    Exhaust Manifold replaced 186,674
    PCV Hose repaired 186,698
    Clutch replaced, and flywheel resurfaced 196,031
    Looks like the spark plug tube gaskets are part of that valve cover gasket job, so I'm set.
    Bravesfan1995 and Steves104x4 like this.
  11. Mar 27, 2024 at 3:30 AM
    Agoldxj
    James
    Central Pa
    2009 SWB AC
    Good deal, if they were serviced once hopefully they won’t give you an issue. It’s mainly the front diff drain plug. I had to use a hammer and cold chisel on mine after stripping it. It came right out though.
  12. Mar 27, 2024 at 5:05 AM
    Ridgewalker1
    Ridgewalker1 Well-Known Member
    Philip
    Longmont, CO
    2003 Tacoma TRD OR, 2015 Tacoma TRD OR
    2003 1 5/8” lift, 235-85r16 BFG KO2, ARB Bull Bar, Warn M8000, sliders, Snugtop; 2015 Hefty Fab al bumper and sliders, Warn Zeon 10k, Rago bed stiffeners,
  13. Mar 27, 2024 at 5:33 AM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Didn't see anybody say anything about the upper control arms. They are icon ucas. They are good ucas. I'd just check the bushings and delta joints. They might be greasable also. I've never ran icons but I haven't heard anything bad about them. Good looking truck.
    racerX969 likes this.
  14. Mar 27, 2024 at 6:20 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    You did really well !
  15. Mar 27, 2024 at 7:59 AM
    bbinSF
    Thank you guys,
    Getting a grease gun as well to start maintaining these U-joints and other suspension components.
    Appreciate all your feedback and positive encouragement.
    Thank you!
    Tatts521 likes this.
  16. Mar 27, 2024 at 9:59 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  17. Mar 27, 2024 at 10:44 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Your truck looks great, you did good. Underneath looks really good, definitely never in a salt state. My only hesitancy would be the lift. If not quality, not done correctly or not done by someone who knows what they are doing you can have some major problems. But overall looks good.
  18. Mar 27, 2024 at 11:01 AM
    bbinSF
    Thank you very much.
    The lift is where I have the most questions. I now understand how the front lift was done. The rear uses the blocks which i see why they are not ideal. I'm wondering if any driveline modifications are needed to accommodate the lift. I saw a video where someone had a shim between the frame and the clamp that secures the driveshaft... done to maintain driveline alignment. I just need to read more on what is needed.
    I'm trying not to go crazy with this truck, but would like to take an affordable step up with the rear lift like different leafs, or add-a-leaf to achieve that 2"? I'll just need to immerse myself in the topic.
  19. Mar 27, 2024 at 11:31 AM
    OffroadToy
    Are you experiencing vibs/shudder? I had faint take off shudder and the carrier shim took care of it. As far as the rear check out the Icon RXT leaf pack... 3 load/height options.
  20. Mar 27, 2024 at 11:38 AM
    bbinSF
    no vibes or shudder.
    I'll check out those RXT leaf packs! Thank you! Looks like what I need.
