Just got Billies, want AAL need advice.
Discussion in 'Suspension' started by gospurs21, Mar 19, 2014.
  1. Apr 9, 2014 at 5:06 AM
    xTRDxLatino
    xTRDxLatino Member
    Mississippi
    2010 Tacoma TRDoffroad
    Thanks alot guys! I already bought the bilstein 5100 all around. Do you think buying OME dakar leafs springs and eibach coils would be a good combination with these billy's? will i need an alignment?
  2. Apr 9, 2014 at 8:31 PM
    xTRDxLatino
    xTRDxLatino Member
    Mississippi
  3. Apr 10, 2014 at 4:53 AM
    gospurs21
    gospurs21 [OP] Well-Known Member
    Brownsville, Texas
    05 x2 Cab Texas Edition V6 prerunner, TRD
    wish it wasnt so difficult to add a picture on here lol so si could show you how nice it came out w just Bilsteins set at 1.75, looks sick.. you should do it
  4. Apr 11, 2014 at 7:13 PM
    124x4tacoma
    124x4tacoma Member
    Margate, New Jersey
    12 4x4 access cab
    Tint Adjustable Shocks 1.75 Rear Leaf 1.5
    1.75 billies up front, 1.5 AAL leaf in the back on 265/75/16 . It has a small rake. Having the itch to go higher to fit bigger tires
  5. Apr 11, 2014 at 9:07 PM
    TCprerunner
    TCprerunner Well-Known Member
    You can run the eibachs withe the setup you got without a leaf pack. Put front 5100s on the bottom notch and use the 1.5 aal with the coils it would only put you .1 higher up front..
    And thanks still some things in the work for the truck but I like the bro lean lol don't care what anyone says
  6. Apr 11, 2014 at 10:05 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    He's 2nd gen Cody, for 1" no issues, he'd be fine on stock shocks...
    No, this is incorrect... You CAN run your stock shocks for a 1" lift on 2nd gen Tacomas.. 1st gens not so much
  7. Apr 11, 2014 at 10:34 PM
    TCprerunner
    LSO just saw you ask about alignment you need alignment with all suspension work pretty much
  8. Apr 11, 2014 at 10:36 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Only if the geometry changes (lifting or lowering)
  9. Apr 12, 2014 at 6:24 PM
    xTRDxLatino
    xTRDxLatino Member
    Mississippi
    i bought 5100 all around and some eibach coils, now all im needing is AAL's. to add a leaf, do i have to have a TSB spring?
  10. Apr 12, 2014 at 8:27 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You dont have to & the TSB is a joke anyway...
  11. Apr 12, 2014 at 11:49 PM
    xTRDxLatino
    xTRDxLatino Member
    Mississippi
    really i heard its a bit better than the old stock ones. but im guessing rear ToyTec 1 1/2" Lift Add-a-leaf will do it since i just read that it will fit in non-TSB springs also.
  12. Apr 22, 2014 at 1:38 PM
    LoneWanderer
    LoneWanderer Well-Known Member
    Randy
    Ohio
    03 4x4 Access Cab 2.7l 5spd
    Bilstein 5100s, Rancho Quick Lift struts, Wheelers 3 leaf aal, Procomp 8069s, General Grabber AT2 31x10.5, AFE Pro Dry S air filter, Dynomax Super Turbo muffler
    Would I get the same look on a 1st gen with those? I'm looking at doing billies all around set at 1.75 in front and a 1.5" aal in the rear too but what I'm looking for is exactly how yours sits. Also 1.75 on the front with stock springs is safe on the parts and tires right? I plan I driving this thing A LOT more miles.
  13. Apr 24, 2014 at 7:29 AM
    Trev407
    Trev407 Trev
    Trev
    Central Florida
    07 Tacoma DCLB TRD PreRunner
    Volant Ram Air intake, Stoptech drilled and slotted rotors, custom LED bed lights, Fogs anytime mod, Kenwood double din, 21" Light bar and BAMF behind the grill mount, Black Billet grill
    I too have just purchased 5100's for the front and rear of my 07 double cab. i do not have the tsb leaf. Im putting some 20'' WT4s on my truck and want to level it or get it as close to level without having the infamous "bro lean".
    so my question is, with stock springs and no tsb where would i set my front shocks? 1.75? or could i go .85 and still be more level than stock? some pics would be great!
  14. Apr 24, 2014 at 10:55 AM
    Casey31
    Casey31 Well-Known Member
    Casey
    Saltillo, Mississippi
    2013 Silver Streak Mica Double Cab 4WD
    2.5" in lift upfront from the dealership, 1.5" AAL in the rear, Aries Bull Bar painted Black, Badges painted Matte Gray, 17" Pacer Type 164b wheels
    I read somewhere that you should not mix lift components but I didn't know for sure if that was just a disclaimer or what? The reason I ask is that I just bought a 2013 Double Cab that came with a 2.5" lift on the front (spacers). The dealership kept calling it a lift but it is just a leveling kit. I want to get rid of the lean even though it is not that noticeable to most people, but it is driving me nuts. Couldn't I just add the 1.5" Toytec AALs since I have the TSB to even it out or give it a rake without messing anything up?
    I eventually would like to replace everything but just can't afford to purchase the complete OME or coils, 4 Bilsteins, and AALs at this time.
  15. Apr 23, 2017 at 8:11 PM
    #35
    PirateMedic3
    PirateMedic3 Well-Known Member
    Would you happen to have measurements of what your sitting at?
  16. Apr 24, 2017 at 9:03 PM
    #36
    gospurs21
    Brownsville, Texas
    *a few years later* lol billies at 2.5" and 1.5" rear block!
