Just got horrible news from the dealer NEED HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grow4hobby, Jul 31, 2012.
  1. Jul 31, 2012 at 3:34 PM
    #81
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Oh, Man. I'm starting to smell General Motors. images_92fbf929ed366460be738dfc48704fc3417d0a6d.jpg
  2. Jul 31, 2012 at 3:47 PM
    #82
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Truth!
    The dealership I used to work for sold a lot of Fidelity. I've never fought with an extended warranty company so much over trivial BS. You seriously have to read every inch of the fine print on your contract or you will become extremely angry the 1st time you try and make a claim. They have so many exclusions and clauses.
    FI- intake manifolds being covered but the gaskets aren't unless you selected seals and gasket coverage.
    Fidelity "rewards" the dealer and finance people extremely well so they don't give a damn they're selling you a POS contract or haven't fully explained all of your options within that contract.
    Go with the Toyota one if you can or go without if you can't.
  3. Jul 31, 2012 at 4:12 PM
    #83
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . . . I know SET and their system . . . never worked for them ... but I did know the players.
    Thats is why I would only get an "OEM Toyota Factory Platinum Warranty".
  4. Jul 31, 2012 at 5:03 PM
    #84
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    I'm pretty sure he means the dealer is financing the cost of repairs not the cost of the warranty, read back a few post's he clearly stated the dealer agreed to fix the issue seeing as a second party( another toyota dealership) was able to determine the issue was pre existing to his purchase.
  5. Jul 31, 2012 at 5:26 PM
    #85
    SOSHeloPilot
    2024 4Runner SR5
    Missed that ... thanks ... I was wound up a bit on the problems with Fidelity warranties. ... :D
  6. Jul 31, 2012 at 5:27 PM
    #86
    stocksport
    stocksport Well-Known Member
    Orlando, FL
    White 2011 TRD Sport DC 4x4
    Blacked out emblems, Weathertech liners, LED interior, tag, and 3rd brake light, reverse light mod, rear TSB, rear diff. breather, added black factory running boards, OR tow hook, and rhino lined UWS low profile box.
    I'd cancel the Fidelity policy if that's still possible and go through one of the several guys mentioned on here for extended warranties. I went through Toyota of Greenfield, ME after canceling the one I bought from the dealership down here. It's the original factory extended warranty. All Southeast Toyota dealers use Fidelity/JMA. I'm not sure how it works once you are past the 3/36K, but I literally saved 50% and got a better warranty.
  7. Jul 31, 2012 at 5:30 PM
    #87
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Yeah well hate to burst your bubble but the toyota warranty sucks a fat one as well. I have one and it is pain to get anything covered even if it is obvious. I gave up on it. I do not have time to deal with the dicks at toyota. Tried two dealers and get the same run around and need to have a rep see it or find some other excuse.
  8. Jul 31, 2012 at 6:02 PM
    #88
    03is300ztk
    Zach
    07 Tacoma 4X4
    Hahaha I can only imagine, well frankly I dont want too. So thank you for doing it for me.
  9. Jul 31, 2012 at 6:11 PM
    #89
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Has anyone suggested the dealership is just trying to pull a fast one? Was anything wrong with your truck beforehand? If not, tell them to pound sand. I'll bet anything they're just trying to screw you out of 1500 bucks. Fucking thieves is all they are.
  10. Jul 31, 2012 at 6:37 PM
    #90
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You are talking about the rust coming from between the "ring" and the weld, no? If so,that is not a crack. The ring is only a slinger, and is only press fit onto the stub shaft. Water can indeed get in that space, and cause the rust streaking out, but with no ill effects. The stub is welded to the driveshaft tube, and is one solid piece that extends through the carrier bearing and the flange on the other side of it. It is splined for the flange, and the tip is threaded for the flange nut. So, basically, your photo doesn't show any fault or failure at all. Which leads me the believe there is something else amiss if you have a vibration.
  11. Jul 31, 2012 at 6:56 PM
    #91
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Interesting
    Toyota thought it was enough of a fault to replace it under warranty
  12. Jul 31, 2012 at 7:17 PM
    #92
    landphil
    BC, Canada
    Tundra 5.7 mod
    Seems like they weren't really sure what they were looking at, so decided to replace it. If its alread been approved by the rep or corporate based on photos, then your dealer will get paid. If not, most likely the claim will be denied and the dealer will be on the hook for the bill. Either way, you get a new driveshaft at no charge.
  13. Jul 31, 2012 at 7:18 PM
    #93
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    just checked mine. no significant rust or cracks, but definitely a lot of play in it.
  14. Jul 31, 2012 at 7:21 PM
    #94
    OZ-T
    Peter North
    British Columbia
    The tech did mention to me some of what you stated earlier , and he's been a Toyota tech for 25 years
    Not doubting you at all , just saying he seemed to know what he was looking at and thought that whatever he was looking at was incorrect
    My picture might not tell the whole story
  15. Jul 31, 2012 at 7:28 PM
    #95
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Bullshit.
    You are legally protected and they can not flat out void your warranty simply because of mods.
    They must prove that the mods caused the failure.
  16. Jul 31, 2012 at 7:30 PM
    #96
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Magnusson moss act
  17. Jul 31, 2012 at 8:41 PM
    #97
    SOSHeloPilot
    2024 4Runner SR5
    That is kinda rare from what I have seen in the past.
    Just curious ... what was the warranty issue and what reason did Toyota Corp. use to turn you down ??
    Off roading damage and lack of proof of service and certain mods are the things that they normally try to use against a claim.
    FWIW ... OEM Toyota Corporate Warranties ... are much more liberal granting claims than most other extended warranties.
  18. Jul 31, 2012 at 8:52 PM
    #98
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Same here. I have Never had a problem getting the little warranty service that I have needed over a 34 year period.
    Ford on the other hand ...
  19. Jul 31, 2012 at 8:52 PM
    #99
    SOSHeloPilot
    2024 4Runner SR5
    The dealer should be glad that they didn't have you to deal with ... you would have had them for lunch ... I like your "tenacity and grit" ... :D
  20. Jul 31, 2012 at 9:13 PM
    #100
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Interesting that another dealer is saying to just replace driveshaft and asking insane price for it. When a u-joints started squeeling a few monthds ago on my 05 taco, I asked a dealer in GA how much they'd charge for u-joints. They said nothing was servicable on the shaft and had to replace the whole thing.
    I think I paid around $320 total to find the parts myself and have a local shop install. 3 u-joints from O'Reily, carrier from a different toyota dealer, the local mechanic to do the work for me once I realized that one of the u-joints was so seized up that even my bench vice couldn't press it out.
    My 05 taco is far better than the POS 04 chevy colorado I had but I still think maybe I won't get another toyota. Every time I've checked the work done by a dealer service dept, I found something wrong. Stuff like not removing an old gasket before putting on the new one, wrong torques, missing nuts/bolts, forgetting to put parts back on, and of course the "no issue found" and "unable to replicate issue" multiple times.
