Just got my LCE header
Discussion in '4 Cylinder' started by numbah57, Apr 10, 2014.
  1. Oct 5, 2014 at 10:35 PM
    #61
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    My 2.7 has really high 3:31 road gears and has plenty of pep. :)
    https://www.youtube.com/watch?v=hvIBURPwtXw
  2. Oct 6, 2014 at 1:57 AM
    #62
    numbah57
    numbah57 [OP] GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
  3. Oct 6, 2014 at 10:47 AM
    #63
    tooter
    Greg
    Los Angeles
    Yeah, I only push 27's. ;)
  4. Oct 6, 2014 at 10:55 AM
    #64
    numbah57
    kahai
    Maui, Hawaii
    Must be fun to drive.
  5. Oct 6, 2014 at 10:55 AM
    #65
    numbah57
    kahai
    Maui, Hawaii
    Thinking of getting a 5 lug for a dd
  6. Oct 6, 2014 at 11:06 PM
    #66
    numbah57
    kahai
    Maui, Hawaii
    Planning on eventually going solid axle with 37's on my truck.
    So either way I'd be getting a dd
  7. Oct 7, 2014 at 6:36 AM
    #67
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    If this wasn't real life, I'd have a 5 lug reg cab manual with all of tooter's mods + a supercharger & some coilovers. Maybe a 4.10 ratio. That little truck would be a blast.. I bet with all the intake and exhaust mods it would be pushing close to 300 hp
  8. Oct 7, 2014 at 10:53 PM
    #68
    tooter
    Greg
    Los Angeles
    It is. :)
    It's very responsive for a little 4 banger pickup truck, and it makes going to work fun. The wider wheels and tires while retaining the stock wheel diameter keeps the axles relatively close to the ground for great handling in the corners.
    Greg
  9. Oct 13, 2014 at 10:11 AM
    #69
    tooter
    Greg
    Los Angeles
    That's an excellent description of torque. :)
    Torque is not horsepower. It's not quicker acceleration... but rather the ability to hold the same rpm level under increased load.
    Greg
  10. Oct 13, 2014 at 12:30 PM
    #70
    numbah57
    kahai
    Maui, Hawaii
    Been noticing that too lately.
    The more I drive, the more I notice that I can carry a higher gear than before.
  11. Oct 22, 2014 at 2:19 PM
    #71
    BamaToy1997
    Bill
    Navarre, FL
    Hey OP, where did you get your LCE header from, and if I may ask, what did you pay for it?
  12. Oct 22, 2014 at 3:10 PM
    #72
    numbah57
    kahai
    Maui, Hawaii
  13. Oct 22, 2014 at 6:33 PM
    #73
    tooter
    Greg
    Los Angeles
    You didn't get penalized for living in Hawaii. Mine was $475 shipped to California.
    Greg
  14. Oct 22, 2014 at 7:09 PM
    #74
    Bob57
    Bob57 Well-Known Member
    Spencer Indiana
    2010 base
    Had the cash saved up for the header but went for the wheels first.
    My scale shows the factory 15 inch steel wheels at 26 lbs each, the Enkei wheels are 15.6 lbs. I'm thinking by dropping 40 pounds off the rotational weight it will surly help the mpg, I'm keeping tabs on it.
    I'm hoping the combo of light wheels and the LCE will make a even bigger improvement.
    Still saving $ for a LCE, may be a while unless I find a used one. :eek:
    I'm mostly interested in lowering the toque curve and gaining mileage.
  15. Oct 22, 2014 at 8:01 PM
    #75
    RdRunr
    RdRunr Well-Known Member
    Dan
    still in the Matrix
    2014 Base, white, reg cab, 2.7L, 5-spd
    DT header, Flowmaster 50 Series Delta Flow muffler
    My LCE header has been sitting in the garage for a while. I wanted to replace the muffler first so I could better hear the difference in sound with the header. Also want to run through a few tanks of gas to see if there is a MPG increase with just the muffler change (there was). Muffler has been on for a while, almost time to install the header!
    The torque/HP chart from LCE is below. Am I reading it right? It says we gain 60 ft-lbs at 1,000 RPM? That's crazy! :D
  16. Oct 29, 2014 at 4:54 PM
    #76
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    I hope so! I just ordered my LCE header. It's supposed to be here 11/4. I'm stoked to get it on!
  17. Oct 30, 2014 at 4:38 AM
    #77
    Dangerdave
    David
    Wilmington, NC
    20 F150
    Lol yea I bet.
  18. Oct 30, 2014 at 6:22 AM
    #78
    GEORGE STRAIT
    Da Magic City, AL
    LOL who the fuck published this wizardry?
  19. Oct 30, 2014 at 3:07 PM
    #79
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Wizardry is right. On the same scales, using ft-lb and hp, the torque and horsepower curves must cross at 5252 rpm
    No dyno starts at 0 rpm
    Since when do our engines turn 6000 rpm?
    You'd go straight to Slytherin if you turned this in for homework
  20. Nov 5, 2014 at 6:56 AM
    #80
    chickdr
    chickdr Well-Known Member
    Atlanta, GA
    Tacoma 2.7l
    Do they ever put this product on sale?
