Just got my tacoma and I have a few noob questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by everleet, Mar 20, 2010.
  1. Mar 20, 2010 at 11:17 AM
    everleet
    everleet [OP] Well-Known Member
    NY
    07 SR5 TRD Off Road
    I just picked up my taco thursday and so far I love it but because it's a new car to me, there are a few things I haven't been able to figure out yet. Oh, it's 07 v6 trd off road crew cab.
    1. When you shift into drive, do you get a lurch when it goes into gear?
    2. Do you have an annoying low ticking sound when the fan is on?
    3. How do I get the tie down points off the side runners in the bed to the front runner? I can't figure out how they will ever fit.
    Thanks a lot in advance and I'll post some pictures later on.
  2. Mar 20, 2010 at 11:28 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    The ticking is normal, there is a fix idk off the top of my head where on the forum it is but a search might find it. I heard the lurchings just the nature of the beast.
    Welcome to the forum and hope you continue to enjoy the truck!
  3. Mar 20, 2010 at 11:35 AM
    Cleavitt
    Cleavitt New Member
    Florida
    2010 DC TRD Sport
    The tie down points don't have to be installed/removed from the rails from the ends. They can be popped on or off at almost any point on the rail (every few inches at least). All you have to do is loosen the knob all the way and turn the tie down 90 degrees. You might have to slide it to one side or the other a few inches to get to the right part of the rail, but you don't have to slide them all the way off the end of the rail.
  4. Mar 20, 2010 at 11:39 AM
    JKD
    JKD Well-Known Member
    Tie down point? The plastic "D" shaped rings that attach to the bed rails?
    Loosen the center lock knob a LOT. You should eventually be able to pull the plastic "D" ring far enough away from the track that you can rotate it around. When you rotate it 90 degrees, the bolt that holds it in place will be able to slip out of the track. (The bolt head is flat on two sides).
    Installation is the reverse. Make sure the lock knob is loose, insert the bolt into the track, turn 90 degrees, slide it back and forth to make sure it is in a "notch" in the track, then tighten the knob down finger tight. Done.
  5. Mar 20, 2010 at 11:40 AM
    TimS
    TimS Well-Known Member
    Tim
    Maine
    2010 DC tacoma/2005 access cab
    Rebuilt with flatbed 5100's, new spring packs
    The lurch is normal. I think it is a bit less if the truck is warmed up first.
    Ticking is normal
    Tie downs: Cleavitt explained it very well.
    Good luck with the truck.
  6. Mar 20, 2010 at 11:52 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Welcome and enjoy the new toy:D
  7. Mar 20, 2010 at 3:18 PM
    lazaro
    lazaro Well-Known Member
    Garry
    Chesterfield, Virginia
    2010 DC BSP 4X4 TRD Off-road
    Stainless Nfab Steps painted black, Acces Tonneau cover, LED dome and map lights, Weathertech floor mats, EGR slimline visors, Wicked Flow 13 mufflers, ultragauge and 4X4 illuminated switch mod, receiver shackle from Timichi and Redline QL plus hood struts.
    :worthless:
    Now be a good pal and show us some pics.:D
