just got recon with garden flares, where to go for safety check with the flares off
Discussion in 'Hawaii' started by larry2375, Dec 14, 2010.
  1. Dec 14, 2010 at 9:46 PM
    larry2375
    larry2375 [OP] Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    just got my recon sticker with the help of my home made flares to cover the tires sticking out. took them out now and was wondering where i could go to get a safety check. my truck has 265/70 17's on a 17x9 4.5 back space. tires only stick out 1/2 " but im not sure it would pass safet check. my recon papers says it has fender flares but i took them out. any help appreciated. mahalo:)
  2. Dec 14, 2010 at 11:31 PM
    happyb
    happyb Well-Known Member
    Brandon
    on a beach in hawaii
    to my taste
    making a list
    put the flares back on. technically they can take away your recon sticker away if you go without fender flares. whatever the recon papers say you must have on your truck when you go for safety check.
  3. Dec 21, 2010 at 6:47 AM
    larry2375
    honolulu
    Thanks,I'll leave the garden flares off and put them on when I need a safety check. Just gotta drive carefully so I don't get pulled over.p.s. Getting recon wasn't as bad as I thought.I saw a fellow Lifted Tacoma in line at recon, so we talked about our trucks while waiting for the inspector.
  4. May 13, 2014 at 10:44 PM
    ponoG
    ponoG New Member
    Honolulu
    TBD
    Aloha!
    It's a miracle I found out about recon before pulling the trigger on a lifted taco on CL.
    Well, I am writing this forum to ask if I should still get it.
    It's only a 6 inch lift with what looks like slight protruding of the tires (no special fender flares or anything)
    Will I be able to get a recon cert for this? Or will I be constantly wondering about cops pulling me over in Waikiki/Kapahulu?
    My first attempt at buying lifted anything, so big mahalo! for the guidance. aloha~
  5. May 13, 2014 at 11:08 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    Waikiki is the worst place to drive a vehicle without paperwork
  6. May 13, 2014 at 11:15 PM
    ponoG
    ponoG New Member
    Honolulu
    TBD
    no doubt. :rolleyes:
    Wonder if I can just get fender flares and be OK for recon?
    Safety is good for a year from now. (the owner swapped out the muggers for stock rim/tires for that)
    Super black tints, but I can have them removed. That's easy
  7. May 14, 2014 at 11:50 AM
    CBoy808
    CBoy808 The Original Sticker Dude since 2013!
    Tacoma Mall Crawler
    you should check out the recon thread at the top.
    tire tread gotta be covered, need alignment (within 30days they say but as long as its close depending on their backlog you good, can't be from a year ago)
