Just had alignment and now I have questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AdoptaTaco, May 12, 2010.
  1. May 12, 2010 at 1:39 PM
    AdoptaTaco
    AdoptaTaco [OP] Well-Known Member
    Brandon
    Cincy, Oh
    2010 4x4 Sport DC LB MGM
    5100's F&B, LR UCA's, TSB, Toytec TSB AAL, TRD SE Anthracite Wheels, 285 BFG AT's, Weathertechs.
    Ok so I just had my new wheels and tires installed.. Not sure if it matters but i'm now running the FJ TRD SE wheels and 285/75/16 BFG AT's.. I told the tire installers that I needed 2.4/0/0 just as discussed many times on this board.. Well it seems they got close, but is it close enough?
    Lift is 5100's front rear set at 2.5, TSB and TSB toytec aal and LR UCA's .
    I looks amazing and drives great, so i guess i'm just paranoid..:confused:
    wow pic is small numbers are
    left right
    Toe -.01 -.01
    Camber 0.2 0.0
    Caster 1.9 2.0
  2. May 12, 2010 at 1:40 PM
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    can see the numbers on the pic? (too small)
  3. May 12, 2010 at 1:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    Caster is low. 2.4 is the bottom end of the caster range and you aren't even there...
    Everything else looks pretty close.
  4. May 12, 2010 at 2:03 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Pro grille, remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    If the caster is off by too much, it won't wear tires or anything because caster is basically the forward or backward tilt of the wheel as measured at the mounting points (think of a shopping cart front wheel). But you could notice a squirrelly feeling.
    I used to do alignments, and these don't look too bad, if it feels ok to you.
    The camber and toe look very good, well within range.
  5. May 12, 2010 at 3:52 PM
    AdoptaTaco
    Brandon
    Cincy, Oh
    So do you think that i should bring it back for a 2nd shot :(? I told them I needed 2.4.. I noticed they did adjust my
    LR UCA's.
  6. May 12, 2010 at 4:36 PM
    splitbolt
    splitbolt Well-Known Member
    Arkansas
    2016 TRD OFFROAD DCSB MGM
    What was your initial caster setting on the LR uca?
    Someone correct me, but isn't it necessary to disassemble the balljoints and cam plate if you want to adjust caster and camber. But, by only loosening, camber alone is affected?
  7. May 13, 2010 at 5:56 AM
    AdoptaTaco
    Brandon
    Cincy, Oh
    I had the LR UCA's set to 0 when i installed them, the tire guys actually moved the cam plates 90degrees
