Just had Leer 100xr installed, dome light will not turn on.. Help Please
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrain904, Jun 14, 2017.
  1. Jun 14, 2017 at 3:44 PM
    jrain904
    jrain904 [OP] Well-Known Member
    Just had my Leer cap installed and I did not test the dome light before I left. I have tried turning it on with the truck on and off. Brake light is working just fine. I see four wires coming from light assembly and four wires going into the plug/fuse box inside the cap. I checked the fuses and all look good. Anyone have any ideas so i can try and fix before I visit the installer tomorrow?
  2. Jun 14, 2017 at 3:58 PM
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va but now in the Philippines
    2021 Toyota Hilux Conquest 4x2
    none yet
    Check the dome light? It might run off the switch in the truck that turns on the bed light
    LivinOnEdge likes this.
  3. Jun 14, 2017 at 3:58 PM
    rcansley
    rcansley Well-Known Member
    2022 MGM DCSB MT TRDOR
    Try turning on your headlights, then hitting the dome. To get it to come on without having headlights flipped, you'll need to wire the dome light directly the to battery. Unless your installer was going for extra credit, it's not likely they did that for ya.
  4. Jun 14, 2017 at 4:12 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    My dome light was wired directly to the battery, it should be a constant hot source. I don't know why any installer would tie a dome light into a switchable power source.
  5. Jun 14, 2017 at 4:44 PM
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    Unless you upgrade the 100xr typically just comes with a push button LED..
  6. Jun 14, 2017 at 5:28 PM
    jrain904
    You were exactly right. My headlights must be on for the dome light to turn on. THANK YOU. Anyone care to post pictures and or instructions to wire directly to the battery?
    Doghouse61 likes this.
  7. Dec 14, 2021 at 2:15 PM
    jsackspot
    jsackspot Well-Known Member
    Following up on this old thread— I have the same issue except turning on headlights still doesn’t activate the dome light. 3-outlet attachment shows voltage, the brake light definitely works on the same circuit.
