Just had Rear Spring TSB done, have question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by downey, Mar 23, 2012.
  1. Mar 23, 2012 at 9:39 PM
    downey
    downey [OP] Active Member
    Montana
    2009 Mag Gray 4x4 TRD-Off Road
    Leer 100r
    I've always been told the right side of the vehicle is to the right of the driver, so the passenger side. Looking at the part numbers for the leaf springs they are:
    48210-35A20 Spring Assy, RR R
    48220-35020 Spring Assy, RR L
    Assuming the R and L stand for Right and Left, shouldn't 48210-35A20 be installed on the passenger side? Mine isn't, 35A20 is on the driver side.
    For those that have had the TSB done, which part numbers are on which side of your truck?
  2. Mar 24, 2012 at 8:34 AM
    magnum922
    magnum922 Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    Just got mine done yesterday. My numbers are below. It is also 2" higher in the back. Dont know why they both say FRLH.
    Rear drivers 48220-35020 FRLH
    Rear passenger 48210-35A20 FRLH
  3. Mar 24, 2012 at 8:38 AM
    magnum922
    also in the bottom right of the sticker the drivers side says 2A18 and the passengers side says 1L27. Dont know what that means either.
  4. Mar 24, 2012 at 4:27 PM
    magnum922
    Anyone know what the frlh means? how about the1l27 or the2a18 on the spring stickers?
  5. Mar 24, 2012 at 4:41 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Fill up the gas tank and check for the lean
  6. Mar 24, 2012 at 6:07 PM
    magnum922
    My tank is full with no lean.
  7. Mar 24, 2012 at 6:08 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Then you're GTG
  8. Mar 25, 2012 at 12:55 AM
    downey
    Montana
    Leer 100r
    I'm 1/2 inch lower on the driver side than the passenger side. I was even before TSB. Gas tank was at half tank when i did measurements.
  9. Mar 25, 2012 at 7:20 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    The taco does lean.... Is the front suspension stock? If not that's why it's leaning. I'll will check my rear springs for you. Also measure from a completely level ground.
  10. Mar 25, 2012 at 3:46 PM
    downey
    Montana
    Leer 100r
    Front suspension is stock. I measured with park trucked in 2 different spots, both times roughly a 1/2 inch lower on driver side. The "lean" doesnt really bother me just wondering if its because the leaf springs were put on wrong sides.
    Magnum 922's leaf springs are on opposite sides as mine.
  11. Mar 25, 2012 at 4:18 PM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Hey guys I am going to the dealer tommorow to look at the rear leafs, if they give me a hard time about it does anyone a link to the TSB that i can print out? I have a legit issue I think my truck bottomed out twice due the leafs. not just lookin for a free parts
  12. Apr 3, 2012 at 10:47 AM
    downey
    Montana
    Leer 100r
    Can anyone else confirm what part numbers they have on each side of truck after TSB?
    My setup after TSB:
    48210-35A20 - Driver Side Rear
    48220-35020 - Passenger Side Read
    Magnum922 posted earlier and his setup is the opposite mine is so I'm still thinking they put the parts on the wrong sides for me.
    Anyone?
  13. Apr 3, 2012 at 12:14 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Downy mine gets done tomorrow, I can let you know tomorrow night if you don't hear from anybody
  14. Apr 3, 2012 at 12:21 PM
    Squirrellydw
    Squirrellydw Well-Known Member
    2012 PreRunner TRD Sport
    what does this do? I just bought a 2012 a few weeks ago.
  15. Apr 3, 2012 at 12:35 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    It adds an extra leaf for people having issues with heavier loads.
  16. Apr 3, 2012 at 12:51 PM
    PHXSDTaco
    PHXSDTaco Member
    Sean
    Phoenix/San Diego
    2012 SR5 TX PRO DC 4x4
    Are the 2012's covered under the TSB now? I have tried looking it up but cant seem to find anything. I would like to get it done if it is.
  17. Apr 5, 2012 at 9:25 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    I am not sure about the 2012's I would start by asking Toyota or complaining to them if you have an issue. I am going to fill up my tank after work to make sure I don't have any lean issues.
  18. Apr 5, 2012 at 9:55 AM
    NEW YORK T100
    NEW YORK T100 Member
    Augie
    Hudson Valley, N.Y.
    2011-4X4 Sport
    Weather Tec Mats,Access Limited cover. OME Lift: 885 Coils with LR Control Arms and Dakar leaf pack.
    Had mine done back in October on my 2011.
    Driver side: 48220-04211
    Pass. side: 48210-04571
  19. Apr 5, 2012 at 10:55 AM
    downey
    Montana
    Leer 100r
    Thanks for the feedback. Looks like part numbers have changed, did a quick search and:
    48220-04211 is now 48220-35020
    48210-04571 is now 48210-35A20
    So your springs are on the opposite sides as mine as well.
    Guess I'll have to call Toyota, thinking they messed mined up.
  20. Apr 6, 2012 at 11:08 AM
    downey
    Montana
    Leer 100r
    Called dealership, confirmed that they did put the leaf spring assemblies on the wrong sides so I have an appointment Monday to get them swapped to the correct sides.
    For reference, the correct setup is:
    48210-35A20 Spring Assy, RR R - Passenger Side
    48220-35020 Spring Assy, RR L - Driver Side
    Thanks to everyone who chimed in!
